Silverstone Grandia GD02-MT Case
The Media Centre Functions
Search Reviews
As the GD02-MT is classified as a HTPC (Home Theatre PC), it's important that we discuss the case's Media Centre abilities. The most obvious starting point would be to discuss the 4.3" LCD touchscreen, which is located on the front panel. The screen has a native resolution of 800x600 and can be used to directly control media playback, as well as display media information and system settings. In addition, it can also display news feeds, weather amongst other things.
Using the screen requires a graphics card with two VGA or DVI outputs, and you connect the main monitor to the primary output and the case screen to the secondary. You then need to set the graphics card to dual monitor output. Once this is done. you install the supplied iMON software, and select which monitor the iMON software will run on. To be able to use the screen as a controller, you then need to calibrate the screen by touching points displayed on it. Set up was easy, and it worked well on Vista 64, which has had some problems with previous versions of the iMON software.
GD02-MT LCD Screen Setup Screenshot GD02-MT LCD Screen Calibration Screenshot
The iMON software is easy to navigate and alter to your preferences. The display has various background colours available, and you can alter the font type too. It's worth spending five or so minutes messing around with settings that best suit your preferences. Once the software is installed and configured, the screen is ready to use. The touch functions can be used to open and control shortcuts, media and settings. It really does work well and is a welcome addition to the case.
As mentioned, the screen also displays system properties and media information when in normal mode. For someone who is nearing middle age like myself, the displayed information would be too small in a lounge environment to be abe to read, unless you were sat a couple of feet away. That's the only gripe I would have for the display as it works flawlessly and lifts the case from being a vanilla PC enclosure to a true HTPC capable case.
GD02-MT LCD Normal Display mode GD02-MT LCD screen at work, whilst playing an audio track
Not content with just providing just a LCD screen, Sliverstone have also provided a remote control with the GD02-MT. You can use the remote to fully control your HTPC, and it has such features as:
  • Virtual keyboard, with onscreen character/command selection
  • Mouse emulation, using a joypad and button on remote
  • Configurable Application shortcuts, hotkeys and macros
  • Full media playing control
  • Live TV control (channel changing, recording and playback)
  • Power system On/Off
GD02-MT Remote Control GD02-MT Remote Control Picture2
It really has everything you would need to take control of your HTPC, and you should not need a keyboard and mouse. Inputting text can be a slow process witht the virtual keyboard, but I was surprised at how well the mouse emulation works.
GD02-MT Mouse emulation joypad close-up GD02-MT Remote shortcut buttons
Using the remote is simple and prety foolproof. I tested it out using Vista's in built Media Centre with my Hauppage TV card, and it worked extremely well. I have the Microsoft MCE remote controller and found the supplied Silverstone one to be more intuitive and pleasurable to use. For those who wish to use a HTPC without having to store a keyboard and mouse, the remote can be used to replace both, but it does take more time to perform functions such as web browsing etc.
iMedian HD Software
Bundled with the latest version of the iMon software is the iMedian HD application, which is basically a poor man's relative of the Windows Media Centre. From here you can view live and recorded TV, view or listen to media, view pictures and listen to the radio. For those without Vista Home Premium , Ultimate or XP MCE, it gives you a convenient way to mange all your media. If you do have the afore mentioned versions of Windows, the in built Media Centre is a much beter alternative.
If the PC you build using this case is to be used as a HTPC, then all of the above provide a great way to control and manipulate your media. I found everything above to be really simple to set up and use.
So now let's move on to testing the case...
«Prev 1 2 3 4 5 6 7 Next»
16-11-2008, 11:09:58
TopSecret
Silverstone's new media centre friendly case gets put under the microscope today in our full review.
http://www.overclock3d.net/gfx/artic...161342648l.jpg
Read the full article here.
16-11-2008, 12:04:07
Luigi
Nice review there, Similar to what ive got atm, the thermaltake DH104...
I found the LCD to be a real dissapointment, took me ages for it to actually find my media, and then I had to use the desktop app to get at it as the LCD didnt find it :S
Anyway, nice one once again stuart!
16-11-2008, 17:06:57
TopSecret
Thanks mate.
16-11-2008, 20:11:58
Rastalovich
Great review. Dont see enough of these reviews about.
Fair comment with the construction points and limitations.
Personally I think the prices of these scare people. They look good, have some nice gimmicks, but when all the screws are taken out - it's a pc case. For the same price u can get one of those oversized LL server eatx thingies.
17-11-2008, 03:06:16
PV5150
Great review as always Stuart, and I'm inclined to agree with Rast's comments above. A thoroughly enjoyable read though
17-11-2008, 10:25:19
TopSecret
Thanks alot fellas, glad you liked the review. I was concerned over the price too, till I found out the price of small LCD's alone. I was shocked to hear how much they retail for (around £150ish). Considering this, I don't think that the price for the case was unfair. As Rast mentioned though, the LCD's are quite gimmicky and the novelty would soon wear off.
17-11-2008, 11:36:19
Luigi
Thats exactly what I found, it was also rather frustrating getting it to diplay my music
It seems crazy they cost so much, I looked into it a while ago, you can get a reasonable desktop LCD for the same cost.
17-11-2008, 12:15:03
Rastalovich
A good gimmick would be for the lcd to display what something like vlc or mediaplayer displays, like the scope/equalizer/album info etc etc - or equally an itunes output, that'd be something apple would jump on (for their pc-itunes ofc )
(this is where u step in and say they do )
17-11-2008, 12:21:00
TopSecret
They do
It has a graphic equaliser function, with the track name etc. when playing music. I don't think it shows the album art though or works with iTunes.
17-11-2008, 12:36:10
Rastalovich
Yeah it's their "own thing" type of equalizer aint it. I reckon some1 should be bold and map exactly what the players display.
17-11-2008, 16:10:42
Kerotan
Good review, but I think you should change the load/idle temp graphs so they both scale in x from 0 to 70, as at first glance I thought you were getting lower load temps! I dunno whether I could be fussed with an LCD tbh, does add a bit of wow factor to the case though.
11-04-2010, 14:47:45
dwf1
"Take, for example, the very limited space between the PSU and the hard drive when installed. I cannot understand why Sliverstone did not pick up on this when the case was still in the design stage."
Don't you think a 750 watt ps is overkill? 400 should be more than enough for a htpc and you can find a smaller size ps that won't have the space issues. IMHO Thanks for the review the build is helpful b/c I am about to use a simular case if not the same.
