Scythe Ninja Mini CPU Cooler
Testing
Search Reviews
Testing
Cooling Performance
You can see from the graph below that the Scythe Ninja Mini provides better temperatures across the board than the Intel reference cooler. Not that this comes as a shock to anyone! I would have no hesitation whatsoever in recommending the Scythe Ninja Mini for use in an HTPC setup, or even in a medium to full-tower for that matter.
Scythe Ninja Mini Cooling performance chart.
(Ambient temperature 23.9 - 24.4 Deg C)
Let's have a look at the noise readings...
Noise
The Scythe Ninja Mini is quiet by my standards when using the default 80mm fan and I would have no qualms about recommending this heat sink to those who prefer silence. In fact, I found the pitch and noise from my Palit 8600 GT graphics card was more noticeable than the fan on the Scythe Ninja Mini.
Noise Level chart
Now that we have thoroughly analysed the Scythe Ninja Mini CPU Cooler let's head over the page to see how it performed as a whole in our performance testing today...
«Prev 1 2 3 4 5 6 Next»
04-12-2007, 05:30:48
PV5150
Looking for a decent CPU cooler for your HTPC build? The Scythe Ninja Mini is well worth a look.
http://www.overclock3d.net/gfx/artic...073011298s.jpg
Check out the review
04-12-2007, 06:02:25
BUFF
Seems to have more than a few references to Scythe Kama Cross rather than Mini Ninja (I guess cut'n'past review format) incl. the award "Today I have decided to award the Scythe Kama Cross CPU cooler Overclock3D's "Recommended' award for its performance in todays review."
04-12-2007, 06:09:49
PV5150
Woops my apologies...fixed :iamwithst
04-12-2007, 07:54:57
weihk
i have one of those too!
lovly piece of kit, and i've fitted it in a HTPC too
and for anyone wanting to get one but think you might cut your fingers into million pieces.
you simply dont place your fingers where the push pins are, get a flat head screw driver, go from the top of the cooler, on all 4 corners there is a slot on those fins where you can see the push pin from the top.
on those push pins, theres a groove on top, simply use flat head screw driver, push it down till 'click', job done.
same as for unlocking the pin to remove, use flat head screw driver, twist it, and pull off.
pic of it fitted inside a HTPC (excues the 'cable managment')
04-12-2007, 08:07:04
Rastalovich
What the fudge ! weihk u just scared the heck out of me with the cableness !
Don`t like 775 twisty clip in thingies >.<
Anywho, nice review m8, looks like a great choice for htpc or even a regular pc if u`r scared of heights.
Don`t personally like the price, I think Scythe products are overpriced in the UK in general tho. Imo.
Took a note of the 775 retention bracket, and I notice they`ve stripped the curves from the central section. This is a good thing, I`ve just had to hack a section away on one due to caps.
04-12-2007, 10:21:27
Mr. Smith
Nice job fella, well written as usual
One thing though, I really think graphs should start from zero (the noise level graph), I find those styles of graphs to be misleading at first glance. Often people see a graph; higher is better 'woah, that one is loads better' when in reality the difference is small.
Obvously this is my personal opinion, not sure how other people feel but whenever I see this type of graph used on review sites I instantly become suspicous, as if the site was trying to mislead the reader (not that you would ever do that mate).
