Scythe Infinity Conroe HeatPipe CPU Cooler
Published: 12th September 2006 | Source: Scythe | Price: |
Having tested and owned a lot of heatsink coolers in my time, I have to say that the Scythe infinity tops them all. The quality of the heatsink build is second to none, whereas often you get some shabby workmanship at some point on a heatsink. I could not find any on the Infinity - this thing really is top notch.
Did I have any criticisms of the Scythe? Well: it's a little too big so that has to be taken into consideration if you have a small case or a tight setup in your case.
Listed at £32 @ SpecialTech, it could be considered expensive to some, but I think this is awesome value for a cooler that represents today's pinnacle of air cooling. This cooler will easily outperform a low-mid range watercooling setup...it's that good.
I am giving the Scythe Infinity an Editors Choice Award for absolute top quality and awesome cooling. Highly recommended.
Pro's
+ Awesome Cooling
+ Great build quality
+ Gorgeous looks
+ Easy to install
Con's
- Big
- Could be considered expensive
Thanks to Scythe for providing the cooler
Ger review Kemp, and super nice cooler I might add. I'll make sure to start recommending it as one of the best
Another great review. Keep it up
Check it here
