Scythe Infinity Conroe HeatPipe CPU Cooler
A closer Look - The Scythe Infinity
Published: 12th September 2006 | Source: Scythe | Price: |
We've seen the packaging, now is the time to take a look at the cooler itself...
The base
When I first ripped of the plastic covering on the base I was a little disappointed:
Model Name:
Infinity CPU Cooler
Model Number:
SCINF-1000
Manufacturer:
Scythe Co., Ltd. Japan
Compatibility:
Intel:
Socket 478 all speeds
Socket T / (LGA)775 all speeds
AMD:
Socket 754 all speeds
Socket 939 all speeds
Socket 940 all speeds
Socket AM2 all speeds
Combined Dimensions:
125 x 116 x 160mm
Fan Dimensions:
120 x 120 x 25mm
Fan Noise Level:
23.5dBA
Air Flow:
46.5CFM
Fan Speed:
1200rpm (±10%)
Weight:
960g
Installation Manual:
Infinity CPU Cooler Manual (English / French / German)
Fan and Noise
As I don't have a dba meter at the moment, I will have to judge the noise by my own ear. As stated in the testing procedure in the following pages, I am using an Antec P180b for the review. The fans are set to medium which is audible, but only a whisper.
With the fan going full pelt, the Infinity is just audible over the rest of the system when overclocked. At idle you cannot hear it. To me this is awesome for a cooler boasting the cooling prowess that the Infinity does, as you can see in later pages.
If you're a fan of quiet in your case, then you will be happy with the Infinity sitting in there, I am confident of that.
Check it here
