NoFan CR-80EH Passive Heat Sink Review
Performance and Testing
NoFan CR-80EH Review
The CR-80EH isn't designed to be used as an overclocking cooler and so to test it in the usual way would be cruel, unkind and most likely short lived.  So in order to examine the thermal characteristics of the CR-80EH we've designed a set of tests that will best demonstrate its capabilities in a real world environment.  In addition, and to act as a basis for comparison we've paired the same set up with the small Scythe Katana4 CPU cooler and placed the set up in our usual Storm Trooper test rig, and also with the passive cooling provided by the FC9 case we reviewed a while back.  We will not be using a GPU with these tests as we will be using the on board Graphics capabilities of the AMD A8-5600.  As with all our tests we use OCCT to measure with a 30 minute test period between a 5 minute run in and a 10 minute cool down.  Max temps are recorded along with the ambient temperature enabling us to determine the Delta temperature.  As always anything exceeding a max temp of 80 degrees will stop the test and register as a fail.
Test 1:  A measure of the temps with the system at idle. A few browser windows open but nothing really going on that will stress the system.
Test 2:  Playback of a full screen HD Video using the On board graphics of the A8-5600. As it's quite likely that the CR-80EH is going to be used in the sort of dorm room or HTPC set up where low noise is important we figured an HD video would be the sort of task it should expect as its bread and butter and as such it should be expected to be able to cope with the heat created.
Test 3:  OCCT stress test.  No overclock, just a straight stress test with everything at stock.  A bit unfair on the CR-80 perhaps as it's not really intended to be able to cope with the sort of temps that stress testing develops, but hey, we're OC3D, so we're going to do it anyways!
As we can see from the results below the CR-80EH made a fair fist of things, passing all but the stress test in a passive case (No surprise there).  Stress test results aside, we were rather impressed with the cooler's ability to keep the temps tamed during HD video playback. In passive mode the CR-80EH was able to hold the temp below 44 degrees, with this figure improving once a few case fans were added, bringing it down to just over 38 degrees.  These results vary from those achieved when we tested the bigger version indicating that either the 80EH is less reliant on through case airflow or that perhaps the through case flow was slightly higher with this testing.  Either way what needs to be taken away is that having at least some through case flow will improve results and that as we always say, mileage will vary.  While on the subject of through case flow it's essential that we consider the effects that a total lack of airflow will have on the other hardware in your case Especially Mosfets, exposed VRMs and perhaps the NorthBridge area, as lack of cooling to these components will see them getting seriously hot.
«Prev 1 2 3 4 5 6 Next»
27-05-2014, 05:50:35
tinytomlogan
http://www.overclock3d.net/gfx/artic...062535885l.jpg
NoFan Now offer a fanless CPU cooler. Silent cooling with improved compatibility, Let's see if it's up to the job.
Continue ReadingQuote
27-05-2014, 06:42:51
Feronix
Oooh been interested in this thing for a while. The 80 Watt TDP that it's rated for is pretty high.
Brb, making coffee. Should be a good read Quote
27-05-2014, 06:51:35
Wraith
Nice write up Gary, but that cooler! It's mahooosive, like you reported though it's very niche but I could see this being the perfect silent solution for a AM1 HTPC build, or any HTPC build for that matter.Quote
27-05-2014, 06:52:02
barnsley
I'm still not a fanhttp://static-cdn.jtvnw.net/jtv_user...1a4c-28x28.png of no fan solutions but I hope it'll get better and better to the point where fans are the thing of the past. This is hopefully the start of this.Quote
27-05-2014, 06:55:22
SuB
Obligatory OMG THAT BOARD IN THAT CASE (sorry had to :P)
Bit unhinged on the language on this one?
Interesting concept, I bet they're an absolute arse to manufacture!Quote
27-05-2014, 13:59:13
smilertoo
what would be the point of this if you still need a case fan to remove the hot air? wouldn't an AIO or Noctua with the worlds slowest fans do as well? it's a shame they can't find a way to use a side panel as a big passive heatsink.Quote
27-05-2014, 14:20:00
MadShadow
Great review! I like how it got a "silence award". Its like giving a bicycle a "dual wheel" award. I mean, what else can a low-performance product achieve? I'm not criticising, just thought it was funny Quote
27-05-2014, 22:07:41
kittysniper
@maddenshadow not to criticize either, but so does a motorcycle and it is superior to a bicycle in almost every way, I think the point of the article is to compare products of similar function and give us better understanding between them.Quote
04-06-2014, 10:49:12
Kyiagi
i like the shape of this thing if u have horizontal case.. u can cook bacon in it! So you still have to use case fans to cool it, so not fan-less at all Quote
04-06-2014, 11:06:56
tinytomlogan
You can have a totally passive rig no problemQuote
08-09-2014, 23:41:27
User1
Do you recall what dimensions the fan was on the backside of the case? I need to mostly know the width so I can determine what to order for my case. It looks like you may have a slim fan from Cooler Master on the back, which run from 15 to 25mm. Thanks in advance for any help you may be able to offer.Quote
09-09-2014, 06:38:57
tinytomlogan
In that case its a normal 25mm thick fan - just remember CPU placement isnt the same on all motherboardsQuote
09-09-2014, 07:35:53
RizeAllard
Not a bad performance but I would rather use a noctua cooler with fans wit L.N.A. I feel more confortable with active fans than no fan at all...Quote
09-09-2014, 11:03:42
User1
Thanks for the timely reply. I'm hoping the distance is on my board's-ASRock B85M-ITX LGA 1150 (http://www.newegg.com/Product/Produc...82E16813157390) mobo socket will be be about the same as yours in the review from the edge of the board's I/O shield/ports. However, the socket on my board is an intel (vs AMD on yours) and is moved up and away from the PCI-ex slot.
What board did you use in the review?
I plan to piece together a passive system using the Thermaltake Core V1 case for gaming (http://www.newegg.com/Product/Produc...82E16811133260). In regards to cooling, I'll still be running the 200mm front (stock fan) and two Noctua 80mm fans in the rear that should run fairly silent (However, I think the 25mm thinkness of the fans may not work, but the 15mm thick Cooler Master 80mm fans should work). Processor will be an intel 4130T (30 TDP) w/a CR-80CH NoFan CPU cooler, ASRock B85M-ITX LGA, MOBO, Power Color R9 270 passive GPU card, Corsair 512GB SSD and Seasonic 520 watt PSU. I run this rig similarly right now in the Cooler Master 110, but prefer to have the PSU mounted below my MB and I should be able to fit the CPU cooler from NoFan with the added head room. Ideally I'll have a cool running and nearly silent system without all of the excessive fan noise that I get now with my CM110.Quote
