NoFan CR-80EH Passive Heat Sink Review
NoFan CR-80EH Review
Silent running has long been one of the holy grails of PC ownership. On occasion we come close, and indeed when reviewing can often be heard to use phrases such as "Practically silent" and "almost inaudible".  Practically silent, though undoubtedly appreciated, is not the same thing as silent.
We reviewed the NoFan CR-95 back in November 2011 and, it's fair to say, were more than pleasantly surprised.  That said, one of the few criticisms we had of it were the interference issues it caused with RAM heatsinks and PCI slots.  In response to this NoFan have released the CR-80EH, with its innovative cone shape aiming to improve compatibility whilst at the same time providing zero noise cooling all-be-it with a slightly lower TDP of 80 Watts.
 Intel LGA1150/1155/1156
 AMD FM1/AM3+/AM3/AM2+/AM2
 Max TDP 80W
 Dimensions 155mm x 113mm
 Thermal resistance @ 25°C ambient 0.58 °C/W
 Weight 300 g
 Dissipation area 98,157 mm²
 Maximum RAM height 32 mm
 Acoustic noise level 0.0 dBA
«Prev 1 2 3 4 5 6 Next»
27-05-2014, 05:50:35
tinytomlogan
http://www.overclock3d.net/gfx/artic...062535885l.jpg
NoFan Now offer a fanless CPU cooler. Silent cooling with improved compatibility, Let's see if it's up to the job.
Continue ReadingQuote
27-05-2014, 06:42:51
Feronix
Oooh been interested in this thing for a while. The 80 Watt TDP that it's rated for is pretty high.
Brb, making coffee. Should be a good read Quote
27-05-2014, 06:51:35
Wraith
Nice write up Gary, but that cooler! It's mahooosive, like you reported though it's very niche but I could see this being the perfect silent solution for a AM1 HTPC build, or any HTPC build for that matter.Quote
27-05-2014, 06:52:02
barnsley
I'm still not a fanhttp://static-cdn.jtvnw.net/jtv_user...1a4c-28x28.png of no fan solutions but I hope it'll get better and better to the point where fans are the thing of the past. This is hopefully the start of this.Quote
27-05-2014, 06:55:22
SuB
Obligatory OMG THAT BOARD IN THAT CASE (sorry had to :P)
Bit unhinged on the language on this one?
Interesting concept, I bet they're an absolute arse to manufacture!Quote
27-05-2014, 13:59:13
smilertoo
what would be the point of this if you still need a case fan to remove the hot air? wouldn't an AIO or Noctua with the worlds slowest fans do as well? it's a shame they can't find a way to use a side panel as a big passive heatsink.Quote
27-05-2014, 14:20:00
MadShadow
Great review! I like how it got a "silence award". Its like giving a bicycle a "dual wheel" award. I mean, what else can a low-performance product achieve? I'm not criticising, just thought it was funny Quote
27-05-2014, 22:07:41
kittysniper
@maddenshadow not to criticize either, but so does a motorcycle and it is superior to a bicycle in almost every way, I think the point of the article is to compare products of similar function and give us better understanding between them.Quote
04-06-2014, 10:49:12
Kyiagi
i like the shape of this thing if u have horizontal case.. u can cook bacon in it! So you still have to use case fans to cool it, so not fan-less at all Quote
04-06-2014, 11:06:56
tinytomlogan
You can have a totally passive rig no problemQuote
08-09-2014, 23:41:27
User1
Do you recall what dimensions the fan was on the backside of the case? I need to mostly know the width so I can determine what to order for my case. It looks like you may have a slim fan from Cooler Master on the back, which run from 15 to 25mm. Thanks in advance for any help you may be able to offer.Quote
09-09-2014, 06:38:57
tinytomlogan
In that case its a normal 25mm thick fan - just remember CPU placement isnt the same on all motherboardsQuote
09-09-2014, 07:35:53
RizeAllard
Not a bad performance but I would rather use a noctua cooler with fans wit L.N.A. I feel more confortable with active fans than no fan at all...Quote
09-09-2014, 11:03:42
User1
Thanks for the timely reply. I'm hoping the distance is on my board's-ASRock B85M-ITX LGA 1150 (http://www.newegg.com/Product/Produc...82E16813157390) mobo socket will be be about the same as yours in the review from the edge of the board's I/O shield/ports. However, the socket on my board is an intel (vs AMD on yours) and is moved up and away from the PCI-ex slot.
What board did you use in the review?
I plan to piece together a passive system using the Thermaltake Core V1 case for gaming (http://www.newegg.com/Product/Produc...82E16811133260). In regards to cooling, I'll still be running the 200mm front (stock fan) and two Noctua 80mm fans in the rear that should run fairly silent (However, I think the 25mm thinkness of the fans may not work, but the 15mm thick Cooler Master 80mm fans should work). Processor will be an intel 4130T (30 TDP) w/a CR-80CH NoFan CPU cooler, ASRock B85M-ITX LGA, MOBO, Power Color R9 270 passive GPU card, Corsair 512GB SSD and Seasonic 520 watt PSU. I run this rig similarly right now in the Cooler Master 110, but prefer to have the PSU mounted below my MB and I should be able to fit the CPU cooler from NoFan with the added head room. Ideally I'll have a cool running and nearly silent system without all of the excessive fan noise that I get now with my CM110.Quote
