Noctua NT-H1 Thermal Paste
Packaging and A Closer Look
Search Reviews
Packaging
Noctua's NT-H1 comes professionally and thoughtfully packaged, just as we'd expect it to. The packaging provides a plethora of technical information and details on the rear and the front shows off the tube of thermal paste well in the typical brown and blue Noctua theme.
NH-1 package front NH-1 package rear
I'm not going to go into any detail about the syringe of Noctua NT-H1 simply because it is only thermal grease afterall. I don't want you falling asleep on only the second page of the review. Let's have a little bit of a closer look at the Noctua NT-H1 thermal paste...
A Closer Look
While most typical thermal greases use silicon grease as a base medium, the new breed of thermal greases like Noctua's NT-H1 and Tuniq's TX-2 can be significantly different. I have decided to use 3 other thermal greases that I had kicking around at home to reinforce this further. Pictured below are: Noctua's NT-H1; Thermalright grease; Arctic Silver 5, and XSPC's thermal grease.
Thermal paste specimens Thermal paste test specimens with goop
Ceramic based thermal greases which can usually be identified by their white appearance tend to be very easy to spread, but over time can tend to leech a 'watery' type of fluid if left on the shelf. Metal-based thermal greases like AS5 and the XSPC thermal grease contain metal particles (usually silver), and can be a little viscous which may make application a little tricky when trying to get a consistent spread of grease. In my experience, metal-based greases can tend to dry out a little over time when left on the shelf. I'm not 100% sure what the makeup of Noctua's NT-H1 is but it's probably the easiest to handle and apply straight out of the tube of the 4 syringes shown above.
Water leaching test
In a little test I placed 4 small dobs of the thermal grease on a sheet of A4 copy paper and left them in the open air over night. In the image above you can see the end result. Both the Thermalright (second from left) and XSPC (far right) suffered from a major loss of their binding agent. They had also dried out quite significantly as a result. The Noctua NT-H1 ( far left) and AS5 (second in from right) on the other hand managed to keep the loss to a minimum. If you look closely, the NT-H1 actually experiences the least amount of loss when compared to AS5. One could hypothesise that this may be an indicator of some sort as to how the thermal pastes would perform over time, and that the Noctua NT-H1 may be the most stable and consistent thermal grease of those tested.
Anyway, let's see how we're going to test the heat transfer properties of each grease on the next page...
«Prev 1 2 3 4 Next»
18-05-2008, 06:24:52
PV5150
Noctua's NT-H1 is one of the new breed of thermal greases. How will it perform when compared to some of the alternatives out there?
http://www.overclock3d.net/gfx/artic...140806995s.jpg
Noctua NT-H1 Review
18-05-2008, 13:43:15
Bungral
Good stuff..
A little curious how it holds up to MX-II.
Nice review though
18-05-2008, 14:12:39
llwyd
Used a fair bit recently and its nicer than AS5 to work with by a long way. Probably wouldnt go and buy it but it's a good compliment to noctuas coolers
19-05-2008, 11:36:41
Hassan
seems ok to me but one question that is eating me away:
is it better that the arctic 5?
