Noctua NH-U12P CPU Cooler
A closer look
Search Reviews
Noctua NH-U12P CPU cooler - Close up
On closer inspection, the Noctua NH-U12P is a very well made bit of kit. Constructed in Aluminium with an nickel coated base, the heatsink is a little more compact than the Scythe Infinity we have also previously looked at. The heatpipes are connected to the base in sets of 4 and loop up though the fins in that way.
noctua NH-U12p
noctua NH-U12P hsf
The advantage that the HN-U12P has over some of the competition is that it's side-on profile is relatively narrow. This means that you might be able to squeeze it into a setup which has varying levels of clearance around the periphery of the CPU socket. With some coolers this can be an issue because the profile/size of the cooler is standard regardless of the orientation of the cooler.
heatpipes
nh-u12p heatpipes and base
As you can see, the whole thing is very well constructed and looks very solidly built. The fact that it's all silver is also a bonus in the looks stakes.
nh-u12p top
The top is stamped with a Noctua logo which is a nice touch.
NH-u12p bottom finish
The base is, as you can see, very reflective with no discernible machining marks on it. It's very flat and I made sure of this by testing with a flat piece of glass and a drop or two of water.
Onto testing setup...
«Prev 1 2 3 4 5 6 Next»
19-11-2007, 10:38:45
FarFarAway
We take a good look at Noctua's latest cooler and see how it performs
Link
19-11-2007, 11:49:50
Bungral
Nice one Kempez.. Does that out preform the giant Thermaltake?
Also is there a %age score?
19-11-2007, 11:50:19
FarFarAway
There should be...
21-11-2007, 08:10:06
Imrahil
what about getting the NT-H1 on the base and retesting it?
I'd be glad to see what it actually does.
Imrahil
21-11-2007, 13:39:39
FarFarAway
The review was conducted with AS5 to give a fair comparison with all of the other coolers tested. When I install a new test rig next I am sure I could test it tho
21-11-2007, 18:05:58
Imrahil
No Chance to rerun the test with the Noctua itself and NT-H1 instead of AS5?
I'd think that would be the easiest way
Imrahil
21-11-2007, 19:12:12
FarFarAway
Imrahil
It would be easy except the tests are run and done. I'm sure we can review NT-H1 on it's own, but this review was of the NH-U12P, not NT-H1
29-03-2008, 07:03:48
Help
Hello!
I'm new here and it's quite a big forum so i haven't found any thread about this yet so i'm asking u guys here instead. Does someone know what hight the Noctua NH-U12P CPU Cooler have from the motherboard to the fan (free space) cus that knowledge would really help me during if i can buy it or not. U see i have a motherboard full with this cooling metal stuff (sorry for the bad english) i'm from sweden, culdn't find a word for it :S Well i hope i can get an answear here cus i can't find it anywhere.
Thanx in advance? = ) bye
29-03-2008, 09:15:41
FarFarAway
The clearance from the mobo to the bottom of the fan is about 37mm
29-03-2008, 09:16:54
Rastalovich
31-03-2008, 12:56:28
Help
Thanx alot my friends. That helped me sorter this out quite easy = )
Bye! And thanx again!
