Nexus Edge Review
Published: 22nd April 2010 | Source: Nexus | Price: £135 |
Nexus was founded in 2000 by a group of experts specialising in heat conductivity and noise reduction. Over the last 10 years the founders have worked closely with many of the large companies in the industry to build up a vast knowledge of thermal characteristics and conductivity. This has enabled nexus to produce a wide range of products with a focus on great thermal performance and low noise.
Enter stage right the Nexus Edge which offers, in their own words, "great airflow, silence and plenty of space for a whole lot of HDD's and optical..." So lets move on and see the on paper specifications:
Model number: | EDGE |
Motherboard size: | ATX, Full ATX, Micro ATX, Full ATX |
Padding: | Noise absorption wave foam |
PSU: | Not included |
Case fans: | 3x 140mm | 1000RPM |
Front ports: | E-SATA, 2x USB 2.0, MIC and AUDIO |
5.25" bay exposed | 8 tool less |
3.5" bay exposed | 1 tool less |
3.5"bay hidden | 9 tool less |
Expansion slots | 7 tool less |
Case size: | 64,2 x23,9 x 57,6 (L x W xD) |
| Front cover: | Aluminum + ABS |
| Chassis material: | SECC 1.0 t |
| Water-cooling: | 4 pipe holes for liquid cooling |
| Feet: | Rubber adjustable feet |
Head over the page for our first look of the Edge.
PS: Is the Corsair HX1000 supposed to make a low hissing sound when the hard drives are working. Its there all the time but it gets louder the more the PSU is being used.
For the money there are much better options.
Gosh this case is ugly.
Name me one with 9hdd mounts out of the box then. Its NOT a gaming case.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-172-LL&utm_source=froogle
Even though i love lilis id seriously consider one of these as its a fantastic case and looks to be better on the sound with all that dampening foam!
Also, to be very honest, I have worked with better quality cases than this, there are a lot of sharp edges, which I would have expected better for a case of this price, and the design is only average.
I have missed out on a Lian Li V2100 on eBay, which I would have love to have instead.
