Lian Li TYR PC-X500 Chassis
Published: 14th October 2008 | Source: Lian Li | Price: £250 |
IntroductionHere are the X500's specifications from the Lian Li website:
Case Type: Super Mid Tower Case
Dimensions: 230 x 380 x 585 mm ( W, D, H)
Front bezel Material: Aluminum
Color: Black
Side Panel: Aluminum + Sound Insulation Material
Body Material: Aluminum
5.25" drive bay (Ext): 2
3.5" drive bay (Ext): 1
3.5" drive bay (Int): 4
Expansion Slot: 7
Motherboard: M-ATX, ATX
System Fan (Front): 2 x 120mm Fan ( 1020-1200-1500RPM, Factory set to mid speed)
System Fan (Rear): 2 x 120mm Fan ( 1020-1200-1500RPM, Factory set to mid speed)
I/O Ports: USB2.0 x 4, IEEE1394 x 1, E-SATA x1, HD+AC97 Audio
Great review fella :worship:
But I never buy anything but LianLi anymore.... All aluminium cases are easier to cut/modify and extremely lightweight.
Very good and balanced review btw.
-Bubba
The Tyr cases, eventhough "fitted" for watercooling, is better suited for regular cooling (fans) than water. If you do want water theres allmost no room inside for pumps, radiators, reservoirs. Though, you don't have to cut holes for hoses if you've got an external kit anyway :D.
-Bubba
I am sorely tempted to try and get a 240mm rad in on a CPU only loop:D I recks it would go in the somewhere.
-Bubba
Wrote to LamLi but no reply (have had this case about 3months)
Would also like to know how to connect three way fan controller switch ?
many thanks
alan
Great review as always m8.
[CENTER]
[IMG]http://www.overclock3d.net/gfx/articles/2008/10/13150608115l.jpg[/IMG][/CENTER]
Read the review to find out
