Lian Li TYR PC-X2000 Chassis
Cooling & Noise Testing
Search Reviews
Testing
To get a feel of how the case performs and feels when in use I built up a system within the X2000. Building the system was quite easy and took me a little less time than normal. The only niggly bit was fitting the DVD drive, and even then it wasn't a major issue. This was due to having to route the cable behind the drive and through the hole in the drive bay. The components used were as follows:
Asus P5Q
Coolermaster Silent Pro M 700w PSU
Intel Core 2 Quad Q9550 - with Arctice Freezer 7 Pro HSF
Corsair Dominator PC-8500 4GB
ATI Radeon HD4850
2x 500gb Seagate Barracuda's in RAID 0 Array
Asus 20x DVD-RW DL
Windows Vista Ultimate 64 Bit
For the purposes of testing, I ran everything at stock settings using the built in fan controller. The controller has three settings, low medium and high. To measure the full range of system temperatures, I used Everest Ultimate Edition. The temperatures recorded were:
Motherboard
CPU
CPU Core 1
CPU Core 2
CPU Core 3
CPU Core 4
GPU Diode (DispIO)
GPU Diode (MemIO)
GPU Diode (Shader)
I tested while the system was at idle and the CPU & GPU fans were running at stock speeds. This should give a good indication of how effective the different fan settings were on the X2000 with the supplied case fans.
As you can see from the results, there was a drop in all temperatures when changing from low to high fan speeds. We shall discuss this more in our conclusion.
Let's now discuss the noise levels at each fan speed. As Lian Li have labelled the case as a HTPC/Gaming solution, we have taken into consideration whether the noise generated would be acceptable when being used as a HTPC.
At low setting the noise is no more than a background hum, and I could hear the hard drives a lot more than the fans.
At medium setting, the fan noise was a little louder, but would be acceptable for a HTPC, where noisy cooling would not be acceptable.
At high setting, the fan noise was distinctly audible and may not be acceptable for a HTPC, as the noise could be heard in quiet moments of a movie.
So now we move on to our conclusion.
«Prev 1 2 3 4 5 6 7 Next»
23-09-2008, 07:40:21
TopSecret
With sublime styling and some welcome features, the X2000 is the latest offering from Lian Li. Is it up to their usual standards?
http://www.overclock3d.net/gfx/artic...135622773s.jpg
Find out in our in-depth review.
23-09-2008, 07:54:51
Rastalovich
That just wreaks class tbh.
I think the minor niggles are perhaps something that can be overcome - but I do hear that for £305 u really shouldn`t have to, or there should be options included in the kit to assist u.
Ur damn lucky to get ur mits on that, it looks a pleasure to build in and work in.
The only thing I really don`t like are/is the i/o on/off section. The rest of the case features can be forgiven with the style and such, placing the things on the top is perhaps weird. However, I don`t think it`s designed to go under a desk, more to stand on it`s own in a room as a feature. A piece of furniture to comment upon. I`d imagine with it stood on the floor, the buttons/ports are very accessible.
Very nice review, I`d get them, not for the price they are atm tho.
23-09-2008, 08:06:31
Diablo
Looks brilliant, oozes style and great review. However, I have concerns about the lack of 5.25 bays. I personally have a dvd burner, blu-ray burner, fan controller (I know this isn't such an issue with this case), floppy disc drive, pico itx pc and a draw full of screws and bits.
Even if I got rid of the bay full of stuff and the fan controller, I'm still one bay over the limit. If I was going to spend £305 on a case, I would expect enough room to stick in more optical drives. What if you were to buy a 5.25 res?
Other than that though it looks great, but I can't help feeling that its targeted markets such as HTCP (too big) or performance (not enough expansion) have been missed.
23-09-2008, 10:15:09
Rastalovich
Do u think that if u can lash out £300+ on a case, u`d be able to buy a BR/DVD/RW single unit ?
23-09-2008, 10:27:53
Diablo
Granted you could (I have), but what if you like to be able to do direct read/writes from one disc to another.
My only point is that if I spent £300+ on a case, I'd want it as close to perfect as possible and having to make do with only 2 5.25" bays and a 3.5" isn't my cuppa. Perhaps they could have got rid of the 3.5 external for a third 5.25" (I seem to be the only person who still needs an fdd)
24-09-2008, 04:35:45
Socks
Morning guys, I love the look of this case but theres just too many things wrong with it.
A: They should have used black pcb boards for the sata section
B: Used black internal cables for the usb etc
C: Fan controller is in a completely ridiculous place, do something mad, touch screen it and make it flat with the case.
D: The price!!!!!!! DAMN!!! could go on holiday for that.
Nice case, not enough features for what they are asking rrp.
And im with you on that drive bay res, what if you do buy one (which most people do) then your screwed for placement of another bay. ( I only have 1 dvd drive and a fan controller and the fan controller is only there as I lost a bezel, ROFL)
But I do like the case, espcially the way they have coloured the inside which is one thing I think all companys should do.
24-09-2008, 05:04:30
Diablo
I wish I had hot swap bays, they do look like a great idea, only thing is you need to take the side panel off, it would have been better to stick holes in the side so you could connect or reconnect. Agree on the black PCB...that would look great.
24-09-2008, 05:23:57
BloomerzUK
Nice review.
Typo on last paragraph on last page: Lain Li
24-09-2008, 05:24:18
ionicle
gorgeous looking case
amazingly designed
reeks quality as the rest of ya have said
very good review, very thorough
shame bout the price
24-09-2008, 05:27:49
Diablo
Originally Posted by name='BloomerzUK'
Nice review.
Maybe we'll start seeing Lain Li cases, from the guys that brought you Ronex watches
24-09-2008, 06:54:03
TopSecret
Corrected the typo, thanks
When I reviewed the case, I was concerned about the lack of drive bays, but unless Lian Li (got it right this time) had made the case taller or wider then they would be struggling to get any in. I think Lian Li have used every bit of available space they could in the design. Also as this is partly being touted as a HTPC, there isn't really a great call for massive amounts of 5.25" drive bays. I have the Antec Fusion HTPC case and that has just one 5.25" drive bay and it works brilliantly. I do agree that Lian Li could have done some things differently and the scores given do reflect this.
I have been using the rig built up since Saturday now, and I am still loving using the case, flaws and all. I tried the rig in my lounge last night and it looks superb stood next to my LCD TV. I had a spare TV card and got it running under Vista Media Centre. As my LCD is black with a small silver bezel, the case tied in and looked really cool. Even the missus agreed, which is no small feat
24-09-2008, 07:17:39
Rastalovich
That`s the purpose I think judging by the design. Not necessarily a work-horse pc or anything. Sure u could serve off it, arrange masses of storage. Then network off of it all over ur complex.
24-09-2008, 07:42:29
Diablo
Is it big enough for an Eatx board? If it is, then it would be pretty good for a server. But as a HTCP case, looking around, although it isn't small form factor, it seems to be the price a lot of other high end HTCP cases go for. If you could stealth it a bit (Maybe hide it behind a big speaker etc.) it would very good.
24-09-2008, 07:59:10
Rastalovich
Sure I`ve seen a pic on the LL site, on actually on that embedded video, with an eatx in it.
24-09-2008, 08:03:47
Diablo
On that basis, it would be a good choice for a water cooled server, quiet, not too big (compared with rack mount or blade) and really good quality. Plus the minor niggles wouldn't affect it.
24-09-2008, 08:09:14
TopSecret
Why would you want to stealth it? Part of the appeal is in it's styling. If you have a big enough LCD screen and matching AV equipment, then it looks the mutts nutts
24-09-2008, 08:11:45
Diablo
Sorry, I was thinking in terms of my setup, with all of the AV boxes in a neat pile on shelves, which wouldn't really fit this box. Then again that room has the last of the CRTs in the house, so with a huge TV it could look really stylish.
25-09-2008, 10:37:52
Mr. Smith
Gorgeous case, I'd rather have the X500, that is more my size... Nice review.
17-10-2008, 06:59:23
Lynx
Err.
That thing is HUGE.
As they have made all these different compartments, there's no where to hide most of the mobo's cabling!
Bad design, they should have though it though.
