Lian Li TYR PC-X2000 Chassis
Packaging & Contents
Search Reviews
When I took delivery of the chassis, the first word that sprung to mind was large! The box stands very tall when compared with others, and it is quite eye catching due to this. The front of the box features the chassis in all it's glory with pictures of the main features to the side. On the box sides, the chassis interiors are pictured with more information in text underneath. All in all, the external packaging is very descriptive, and uses real images of the chassis. I was eagerly anticipating viewing the contents after reading all the hype on the box.
X2000 Box Front X2000 Side of box
The box comes with two pre-cut carrying handles, which is.....handy. Sorry, I couldn't resist. The chassis is wedged between two foam inserts and wrapped in a plastic bag. Everything fitted snugly and there were no loose items within the box. Removing the chassis from the external packaging took some effort, due to the size of the box.
On removing the chassis from the box, I found that the cardboard carton containing the screws etc was placed inside of the chassis and secured with a tie wrap to stop it bouncing around within the chassis.
Contents carton removed Contents secured
Closer inspection of the contents within the little box revealed a plethora of screws, bolts and assorted items. I have included a list of the accessories below:
* A buzzer with motherboard header.
* 16x Motherboard stand-offs, 30x screws and a screw driver
* 7x PCI card holders with thumb screws
* 2x Clamps for cable management
* 26x HDD, 6x PSU & 8x CD fixing screws
* 6x Spare thumb screws
* 1x Mounting bracket for SSI CEB/EEB
* 2x Long SATA cables, 6x Normal SATA cables
* A plastic box for keeping spare screws etc.
* 6x SATA Drive Rails
Screws & Fittings SATA Cables
SATA Drive Rails SATA Drive rail detail
On the whole, the chassis and extras were well packaged and secured safely in the box. The printed information on the exterior of the box is concise and highlights the major selling points. There was also an instruction pamphlet, with clear and legible text and images, and some promotional materials in the box.
Let's now take a closer look at the chassis, starting with the externals on the next page.
«Prev 1 2 3 4 5 6 7 Next»
23-09-2008, 07:40:21
TopSecret
With sublime styling and some welcome features, the X2000 is the latest offering from Lian Li. Is it up to their usual standards?
http://www.overclock3d.net/gfx/artic...135622773s.jpg
Find out in our in-depth review.
23-09-2008, 07:54:51
Rastalovich
That just wreaks class tbh.
I think the minor niggles are perhaps something that can be overcome - but I do hear that for £305 u really shouldn`t have to, or there should be options included in the kit to assist u.
Ur damn lucky to get ur mits on that, it looks a pleasure to build in and work in.
The only thing I really don`t like are/is the i/o on/off section. The rest of the case features can be forgiven with the style and such, placing the things on the top is perhaps weird. However, I don`t think it`s designed to go under a desk, more to stand on it`s own in a room as a feature. A piece of furniture to comment upon. I`d imagine with it stood on the floor, the buttons/ports are very accessible.
Very nice review, I`d get them, not for the price they are atm tho.
23-09-2008, 08:06:31
Diablo
Looks brilliant, oozes style and great review. However, I have concerns about the lack of 5.25 bays. I personally have a dvd burner, blu-ray burner, fan controller (I know this isn't such an issue with this case), floppy disc drive, pico itx pc and a draw full of screws and bits.
Even if I got rid of the bay full of stuff and the fan controller, I'm still one bay over the limit. If I was going to spend £305 on a case, I would expect enough room to stick in more optical drives. What if you were to buy a 5.25 res?
Other than that though it looks great, but I can't help feeling that its targeted markets such as HTCP (too big) or performance (not enough expansion) have been missed.
23-09-2008, 10:15:09
Rastalovich
Do u think that if u can lash out £300+ on a case, u`d be able to buy a BR/DVD/RW single unit ?
23-09-2008, 10:27:53
Diablo
Granted you could (I have), but what if you like to be able to do direct read/writes from one disc to another.
My only point is that if I spent £300+ on a case, I'd want it as close to perfect as possible and having to make do with only 2 5.25" bays and a 3.5" isn't my cuppa. Perhaps they could have got rid of the 3.5 external for a third 5.25" (I seem to be the only person who still needs an fdd)
24-09-2008, 04:35:45
Socks
Morning guys, I love the look of this case but theres just too many things wrong with it.
A: They should have used black pcb boards for the sata section
B: Used black internal cables for the usb etc
C: Fan controller is in a completely ridiculous place, do something mad, touch screen it and make it flat with the case.
D: The price!!!!!!! DAMN!!! could go on holiday for that.
Nice case, not enough features for what they are asking rrp.
And im with you on that drive bay res, what if you do buy one (which most people do) then your screwed for placement of another bay. ( I only have 1 dvd drive and a fan controller and the fan controller is only there as I lost a bezel, ROFL)
But I do like the case, espcially the way they have coloured the inside which is one thing I think all companys should do.
24-09-2008, 05:04:30
Diablo
I wish I had hot swap bays, they do look like a great idea, only thing is you need to take the side panel off, it would have been better to stick holes in the side so you could connect or reconnect. Agree on the black PCB...that would look great.
24-09-2008, 05:23:57
BloomerzUK
Nice review.
Typo on last paragraph on last page: Lain Li
24-09-2008, 05:24:18
ionicle
gorgeous looking case
amazingly designed
reeks quality as the rest of ya have said
very good review, very thorough
shame bout the price
24-09-2008, 05:27:49
Diablo
Originally Posted by name='BloomerzUK'
Nice review.
Maybe we'll start seeing Lain Li cases, from the guys that brought you Ronex watches
24-09-2008, 06:54:03
TopSecret
Corrected the typo, thanks
When I reviewed the case, I was concerned about the lack of drive bays, but unless Lian Li (got it right this time) had made the case taller or wider then they would be struggling to get any in. I think Lian Li have used every bit of available space they could in the design. Also as this is partly being touted as a HTPC, there isn't really a great call for massive amounts of 5.25" drive bays. I have the Antec Fusion HTPC case and that has just one 5.25" drive bay and it works brilliantly. I do agree that Lian Li could have done some things differently and the scores given do reflect this.
I have been using the rig built up since Saturday now, and I am still loving using the case, flaws and all. I tried the rig in my lounge last night and it looks superb stood next to my LCD TV. I had a spare TV card and got it running under Vista Media Centre. As my LCD is black with a small silver bezel, the case tied in and looked really cool. Even the missus agreed, which is no small feat
24-09-2008, 07:17:39
Rastalovich
That`s the purpose I think judging by the design. Not necessarily a work-horse pc or anything. Sure u could serve off it, arrange masses of storage. Then network off of it all over ur complex.
24-09-2008, 07:42:29
Diablo
Is it big enough for an Eatx board? If it is, then it would be pretty good for a server. But as a HTCP case, looking around, although it isn't small form factor, it seems to be the price a lot of other high end HTCP cases go for. If you could stealth it a bit (Maybe hide it behind a big speaker etc.) it would very good.
24-09-2008, 07:59:10
Rastalovich
Sure I`ve seen a pic on the LL site, on actually on that embedded video, with an eatx in it.
24-09-2008, 08:03:47
Diablo
On that basis, it would be a good choice for a water cooled server, quiet, not too big (compared with rack mount or blade) and really good quality. Plus the minor niggles wouldn't affect it.
24-09-2008, 08:09:14
TopSecret
Why would you want to stealth it? Part of the appeal is in it's styling. If you have a big enough LCD screen and matching AV equipment, then it looks the mutts nutts
24-09-2008, 08:11:45
Diablo
Sorry, I was thinking in terms of my setup, with all of the AV boxes in a neat pile on shelves, which wouldn't really fit this box. Then again that room has the last of the CRTs in the house, so with a huge TV it could look really stylish.
25-09-2008, 10:37:52
Mr. Smith
Gorgeous case, I'd rather have the X500, that is more my size... Nice review.
17-10-2008, 06:59:23
Lynx
Err.
That thing is HUGE.
As they have made all these different compartments, there's no where to hide most of the mobo's cabling!
Bad design, they should have though it though.
