Lian Li PC-B71
Packaging & Externals
Published: 18th January 2010 | Source: Lian Li | Price: £250.28 |
Packaging
The box is much larger than you may first expect, and is a fair indication at the size of the surprise it is concealing. The whole box is printed with the main feature being a photo of the B71 itself, to the left of the photo there is smaller pictures containing the main features of the case. The case inside is protected by polystyrene end caps and a thick plastic bag to help keep it safe whilst it is in transit. Our case, despite its size, arrived fine so the packaging works and given its size the box is somewhat lighter than you may first think.
Externals
Once you remove the packaging you can get your first look at the externals. The first thought that came to my mind was that its good to have a Lian Li to test finally. The Black Aluminium brush exterior, large plain side panels, clean and crisp lines seem to make me feel at home as it's details like these that, at least personally, I have come to love and expect. The front is dominated by the front grill, which in fact a door to the hot swap hard drive bay. More about that later. One feature I am pleased to see is the optical drive cover which used to be a £15 upgrade option on older Lian Li's. I for one hate the look of a DVD drive exposed at the front of my case, so not having to buy the bezel is a welcomed surprise.
Let's move over the page and take a look at the finer details of the B71.
im abit conserned about the hot swap bays tho, as the green color of the back plate might get in the way when you're modding?
well love the review and the youtube videos! great idé with the new "Lian Li B71 - What Mods Are Possible?" want to see more of those in the future.
Cheers //// Apans
There's a couple of images missing the larger versions on page 4 and I want to look at em
On my next big rebuild (i.e. socket change, totally new system, happens every 4-5 years or so), I'll seriously consider this. Can't quite justify dropping £250 on a case right now when the P182SE does me fine.
I liked how you try to get across what good case cooling is. I never would have expected it to perform so well if I'm being honest. Perhaps I underestimated Lian Li, though I've been after one of their cases for a while, but ended up with two Antec cases instead, mainly due to price.
Continue Reading
