Lian Li PC-B71
Published: 18th January 2010 | Source: Lian Li | Price: £250.28 |
Lian Li PC-B71
Lian Li was founded way back in 1983, but it wasn't until 10 years later that their first aluminium case was released. Lian Li have always been popular with system builders and enthusiasts looking for quality, this popularity has grown hand in hand with the case modding community which in recent years has grown tremendously. One of the mile stones for Lian Li was the release of the V2000, with its clean crisp lines it was sure to be a winner. Much of the V2000's success came from its popularity with 'modders', water cooling was becoming very popular and easier to source parts the space in the lower section of the case was a firm favourite to put a radiator an pump. The water cooling popularity of the V2000 even to some respect led to similar designs from Silver Stone with the TJ07. Today how ever we are lucky enough to be looking at the Lian Li PC-B71 full tower case, here are some specifications from the Lian Li website:
Case Type : Full Tower Chassis Dimensions : 220mm x 595mm x 590mm (W,H,D)
Front bezel Material : Aluminium
Colour : Black
Side Panel : Aluminium
Body Material : Aluminium
5.25" drive bay (External) : 5 ( one for 3.5 inch converter)
3.5" drive bay (External) : 1
3.5" drive bay (Internal) : 10
Expansion Slot : 7
Motherboard : E-ATX, ATX, M-ATX
System Fan (Front) : 2 x 140mm blue LED fan (1200RPM)
System Fan (Top) :
System Fan (Rear) : 2 x 120mm Ball-Bearing Fan (1500RPM)
I/O Ports : USB2.0 x 4, IEEE1394 x 1, ESATA x 1, HD+AC97 Audio
Without further ado let's head over the page to get our first look at the packaging and the case.
im abit conserned about the hot swap bays tho, as the green color of the back plate might get in the way when you're modding?
well love the review and the youtube videos! great idé with the new "Lian Li B71 - What Mods Are Possible?" want to see more of those in the future.
Cheers //// Apans
There's a couple of images missing the larger versions on page 4 and I want to look at em
On my next big rebuild (i.e. socket change, totally new system, happens every 4-5 years or so), I'll seriously consider this. Can't quite justify dropping £250 on a case right now when the P182SE does me fine.
I liked how you try to get across what good case cooling is. I never would have expected it to perform so well if I'm being honest. Perhaps I underestimated Lian Li, though I've been after one of their cases for a while, but ended up with two Antec cases instead, mainly due to price.
Continue Reading
