Lancool PC-K62 R Review
Published: 6th April 2010 | Source: Case King | Price: £94.99 |
Lancool is not a name that immediately springs to mind in the UK hardware scene, a lesser known fact is that Lancool is actually a subsidiary of Lian Li. Where as every case that is released under the Lian Li banner will be all aluminium the Lancools are steel. Steel generally means a lower price case, and the Lancools generally are a fair bit cheaper than its rival Lian Li model.
An introduction is probably the most difficult part of the review to write, trying to find some waffle about the company or the product without giving too much away is hard. At the end of the day we are all here to find out if Lancool can build a budget case but still meeting the standards we expect from a Lian Li.
The K62 is exclusively available from Case King one of the largest etailers and distributors in Europe.
Here are some specifications I took from the Case King website for those among you that want to read them.
| Model | PC-K62R1 |
| Case Type | Advance Mid Tower |
| Dimensions | 214mm x 496mm x 498 mm (W, H, D) |
| Front bezel Material | Plastic |
| Color | Red |
| Side Panel | SECC Steel |
| Body Material | SECC Steel |
| Net Weight | 9.55kg |
| 5.25" drive bay (External) | 5 |
| 3.5" drive bay (External) | |
| 3.5" drive bay (Internal) | 4 |
| Expansion Slot | 8 |
| Motherboard | ATX / M-ATX |
| System Fan (Front) | 140mm Red LED Fan x 1 |
| System Fan (Top) | 140mm Fan x 2 |
| System Fan (Rear) | 120mm Red LED Fan x 1 |
| I/O Ports | USB2.0 x 2 / HD+AC97 Audio |
Lets whip over the page for a look.
Brilliant review as always.
QuoteThis is a very well made case, and with the red rather than plain old black its worth EVERY penny. If it had water support it would be worth £20 more imhoQuote
Quote|
Originally Posted by name='Dublin_Gunner'
I have the black version of this case, and its excellent. Completely tool less, and keeps everything nice and cool. However, it does indeed have 2 rubberised holes for watercooling tubes in the rear.. So stating no watercooling support isn't exactly correct..
mediocre...no internal radiator support
i beg to differ a 280 stealth radiator will fit up top with fans mounted inside between the space between top of mobo and bottom of rad.
good review though tom i have the black version(being sprayed inside atm) and they are good casesQuote
THREAD REVIVAL FTW lol mediocre...no internal radiator support .. i beg to differ a 280 stealth radiator will fit up top with fans mounted inside between the space between top of mobo and bottom of rad. good review though tom i have the black version(being sprayed inside atm) and they are good cases |
So I chose the easy option, that and the fact none of my rads would fit so I didnt know 100%
. im just waiting for the case to get back from being sprayed inside.
should be back in 2weeksQuote
Continue ReadingQuote
