Fluid XP+ HP Watercooling Fluid
Testing & Results
Published: 15th January 2007 | Source: Fluid XP | Price: |
First and foremost I was interested to see if Fluid XP+ actually provided any cooling advantages over standard de-ionised water. In case you didn't already know, the thermal properties of water are extremely hard to beat, and in all honesty I only know of a few fluids that have any marginal advantage over water. The test machine specification can be seen below:
Test Setup:
CPU: Intel Core2Duo E6700 Retail @ 3.8ghz (1.6v)
Water Block: Danger Den Maze 4
Pump: Laing D5
Radiator: XSPC R120D
In the interest of a fair comparision the watercooling loop was flushed with water and left to dry over night in-between testing the de-ionised water and Fluid XP+. In addition to this, the water block was not removed from the CPU at any point thus preventing any variation in temperature due to re-mounting.
After taking the difference in ambient temperature out of the equation, the performance difference between Fluid XP+ and de-ionised water was 0oc. This could be seen as disappointing, but what you need to remember is that Fluid XP+ is giving you the same performance benefits of untreated de-ionised water without the algae and corrosion issues.
Conductivity Testing
We've all heard the horror stories of peoples water cooling systems cracking, splitting and generally spewing highly conductive water over thousands of pounds worth of components. This is why most people avoid putting together their own water loops, and instead favor the pre-built systems. As Fluid XP+ is non-conductive this should be a problem of the past. But lets run some tests of our own to see exactly what happens when Fluid XP+ comes into contact with electricity.
The method for testing conductivity is simple: We will be taking an LCD screen, powering it up and submerging it in a container of Fluid XP+.
Click HERE for the video (5.1mb).
While Fluid XP+ did not cause any damage to the submerged LCD screen it did indeed cause the screen to power off. This would imply that although Fluid XP+ is not conductive enough to kill components it still has the ability to short circuit them, temporarily causing problems.
i dont think its worth all that money just for the cleanliness, it didnt make any difference at all to temps. I know its a pain but id rather clean out the loop every couple of weeks than pay £30 a time for some XP
nice writeup mate
nice writeup mate
nice writeup mate |
But ye- its expensive fo sure.
I'd rather spend ~£3 on some water and ~£5 on some Zerex and then be able to re-fill my loop for like 2 years
However it's gotta be useful for those who can't be bothered
Wouldnt it be fair to say that this is more aimed at those who arent in the know and want hassle free solution. Ive never heard of Zerez tbh, or what ratios I'd need to use and stuff like that.
Whenever people see my wc rig they ask wont it break if water spills onto it, so its got its place on the market
However it's gotta be useful for those who can't be bothered |
I can live with my distilled water....
Nah a £5-6 bottle of Zerex lasts me about 3 applications
= 1.5yrs, water = £3 for what 4 years at least
£25 in one go, or ~ £20 over 5 years?
I know which one I'd rather have
= 1.5yrs, water = £3 for what 4 years at least£25 in one go, or ~ £20 over 5 years?
= 1.5yrs, water = £3 for what 4 years at least£25 in one go, or ~ £20 over 5 years? I know which one I'd rather have |
I just whacked a whole bottle of alphacool coolant into 4L of water and use that. Its been running for several months without any buildup of anything. Actually discovered yesterday that some had leaked out of a poorly tightened barb and onto my sound card. Somehow it didnt short anything out
OKOK I give up!
aint buying it tho!
aint buying it tho!
its cheaper in the US, its 10 GBP or 20 US for a bottle, still a lil expensive, iv used MCT-5 and now im on blue penotosin which i love.
I'm sorry to say gang, that this product is NOT safe for electronics. It FRIED my video card, and I made a video of it last night of me pouring it directly into an open power supply. I had 5" flames shooting out of it in 5 seconds or so.
I've contacted the company about it and asked them to relabel it with a warning that is unsafe for electronics, but they've grown somewhat arrogant about it and referred me to their "legal" department.
Do NOT buy this stuff, if it leaks on your cards, POOF. Look around on Youtube, there are plenty of other videos showing the same thing that I witnessed.
Rock on.....
Rock on.....
Post the video tbh
I've contacted the company about it and asked them to relabel it with a warning that is unsafe for electronics, but they've grown somewhat arrogant about it and referred me to their "legal" department. Do NOT buy this stuff, if it leaks on your cards, POOF. Look around on My space, there are plenty of other videos showing the same thing that I witnessed. Rock on..... ![]() |
If you really want true non-conductivity then pump dielectric oil round your rig, or that stupidly expensive stuff that 3M make. I still wouldnt want to test it out by dripping it on an open PSU tho...
I would LOVE to publish the video, I'm looking into that now. It's three videos that are 15 meg each...gotta find a way to make one long one and stream it, like youtube. I'm looking into that tonight.
Lol, an open psu has 240v going through it. it is much more sensitive than a 12v gfx/mobo.
With all due respect, puring liquid into a device that holds enough voltage to kill you is monumentally stupid, I don't think they can re-lable a product to cater for people who will endanger their own lives.
This product is advertised on low conductivity, not no conductivity. Care has to be taken when using it, same as anything else in a computer application.
This product is advertised on low conductivity, not no conductivity. Care has to be taken when using it, same as anything else in a computer application. |
I've actually used this stuff for quite a few of my builds and have even got it on a graphics card and a motherboard in the past. Providing you notice it early and cut the power straight away, all it ever took was a few hours with the hairdryer to get it working again.
Originally Posted by name='Jim'
QFT.
I've actually used this stuff for quite a few of my builds and have even got it on a graphics card and a motherboard in the past. Providing you notice it early and cut the power straight away, all it ever took was a few hours with the hairdryer to get it working again. |
If a leak is caught early on, a small amount of coolent shouldn't be a problem.
Honestly, for that price, it should be Jesus Juice. Most of the coolants in the market are already non-conducive so I wouldn't be hecked to pay that much for this.
If you're new to water cooling, your worry should be in checking, double checking, and triple checking for leaks first, also get those screw-nuts that attach tubing with holes to ensure tight and secure connections.
-HypoG
-HypoG
Kempez
With respect as well......you're wrong on a few points.
"With all due respect, puring liquid into a device that holds enough voltage to kill you is monumentally stupid, I don't think they can re-lable a product to cater for people who will endanger their own lives.
This product is advertised on low conductivity, not no conductivity. Care has to be taken when using it, same as anything else in a computer application."
1) Using this product in a computer with the risk of it leaking is monumentally stupid. Yes. Power supply or not, shorting anything inside the case will endanger you, AND the equipment.
2) No, it is NOT advertised as "low conductivity", it's PLAINLY labeled on the bottle "NON CONDUCTIVE", and even on their website they brag about it being safe to use in computer equipment with NO chance of an electrical short.
3) If you notice, the bottle's plastic, so pouring it into a live power supply is NOT dangerous, unless you're careless enough to spill some on YOU. Then yes, you needed a dose of reality anyhow, BUT, you're insulated from the hazard, so the "people who will risk their own lives" is completey blown out of proportion.
It almost sounds like you work for the company, why else would you endorse a product PROVEN to cause electronics to EXPLODE? Mind you, there were 5" inch FLAMES coming out of this thing. And, exactly how is one supposed to be right there the second a leak occurs?!?!?! That's purely ignorant. I came downstairs one morning from sleeping all night while it was running the nightly backup, and the video card was fried. What is one supposed to do to protect the flawed reputation of this company, never take your eyes off the computer?!?!?!?!?!?
Please, be reasonable. The product sucks. If you want to use it go ahead, it's your money. I'm just warning the folks that DON'T want to spend time with a hair dryer OR time in the return line PRAYING for a refund that this product is NOT what it's clearly labeled INCORRECTLY to be.
Your call.
Your call.
I could sit here and pick holes in arguments as you seem intent on. But I'm not going to.
I will, however, give you this advice:
Publish your video and post your warning. Then Leave it at that.
Trying to pick holes in an admin's opinion will not end well.
Ham
I'm not here to agree with an admin. I'm here to voice an opinion based on fact.
If the admin thinks the already published videos out there are wrong, that's his opinion. He's welcomed to it, as I AM MINE.
If he wants to censor others opinions, then this whole site and forum are a waste of time.
I thought we were all exchanging ideas and experiences? How about focusing on the facts and leave the judgment at the door.
'nuff said.
'nuff said.
Well you've voiced your opinion. Now publish your proof.
Posting using enlarged text, capital letters and copious amounts of punctuation is not going to help you at all.
Can't post the proof. I just got a message "You are only allowed to post URLs to other sites after you have made 15 posts or more."
So be it.
I'm over this censorship. If you want to buy this junk and burn up you're rig, have at it.
I'm done trying to HELP you all avoid a catastrophe.
Later.
So be it.
Later.
Post the link with the http:// and if nessicary the .com/co.uk removed. Nothing you have said has been censored, your being hampered by the spambot protections, yes. But no-one is censoring your posts.
With pleasure.
The quality of it SUCKS, I was going to do a good one this weekend with some professional equipment that I didn't have with me at the time I took this one. BUT, you asked for it so I'll post it now.
Well, it STILL got kicked out. Just go to youtube and type in fluidxp+ in the search window. Mine's the fourth one down. It's the dark one...again...sorry about that, I would have preferred to post a better one.
I entirely agree with ITGUY that the product is falsely advertised, as far as I know, the only liquid that is non conductive is the 3M stuff.
At the end of the day water and electrics don’t mix; it is at the users risk of component failure. I don’t think lives are at risk at all. Someone would have to be very unfortunate to suffer a fatal injury from a liquid leaking in his or her pc.
These companies selling these liquids are lying to their customers, and the customers have to be pretty naive to believe that the liquid is entirely non-conductive.
Imo reviewers of these liquids need to make it clear to their audience that the liquids are not non-conductive. The water coolant should be marketed as non-corrosive coloured coolant that may or may not boost performance over de-ionised water.
Ed
edit:
Good vid from petra tech shop:
http://www.youtube.com/watch?v=O-yT7cvfo3o&feature=channel_page
Ed
edit:
What, products are being advertised in a way that makes them seem better than they really are? When did this start happening?
That's what advertisment is about. Non conductive means non conductive to a given current, not non conductive to all currents, amps, and voltage. It's like water proof watches. They are water proof to X depth/pressure.
That's what advertisment is about. Non conductive means non conductive to a given current, not non conductive to all currents, amps, and voltage. It's like water proof watches. They are water proof to X depth/pressure. |
Theres me thinking that everyone knew that at 12v like its been said its very hard to kill stuff unless your just unlucky.
Ive had mobos, ram, gfx cards you name it ive had it soaked but not a 240v psu theres a slight difference between 12v and 240v like the small matter of living.
I agree with daza. 12v doesn't even get through a very thin layer of plastic where a friend of me had 230v go through an insulated screwdriver.
I also agree that advertising as non conductive is plain wrong. As seen on the petras tech shop video, distilled water was even less conductive than the branded coolant, of which he did not mention the brand name sadly.
Any way you put it, I think you have been a bit too ... persistent making your point here ITGUY. I was anything but happy to see a post like yours trying to make your point against kempez. Yes he may be wrong on some points, but try bringing that in a reasonable way without larger fonts and capital letters. Yet I'm going to reply to it:
1) You say it's monumentally stupid to use this product in your PC. So is mixing computer components with water, and yet about 80% of the people on this forum do it without problems?
2) agreed. The bottle clearly said 'non conductive' on another youtube vid.
3) Yes the bottle is plastic, but would probably zap you right away when put to a clear 230v / 5A source. The miracle protecting you is the fact a pouring liquid consists of seperate drops which have holes between them that barely conduct. That's why p*ssing an electrified fence usually ends well.
Just a further observation, how many people are running their PSU with no casing, directly below a very leaky barb? In addition, unless you happened to be using a non earthed PSU and be touching the PSU at the time, I think the worst that would happen is a load of sparks and a blown fuse at the plug.
I would like to say from an OC3D perspective: we do not censor opinions of our readers/members, we do stop people breaking our T&C's and rules. No censorship has taken place on this thread and nor will it, unless rules are broken.
Marketing is marketing, people who are watercooling should know better than to trust anything they put near their PC's. The science of it is simple and irrefutable and once you expose any liquid to the world it's likely to become conductive in some way.
Either way, don't mess with liquid and PSU's unless you are mad or....well: Jim
Nah, he just messes with psu's, heavy crossload and extremely high ambients
At some level there probably is some truth to FluidXP's "non-conductive" claims. I'd imagine that if the fluid was not exposed to air (e.g straight from manufacture to air-free loop) then it may be totally non-conductive. Obviously that's going to be impossible, but I reckon thats how FluidXP manage to maintain their claims.
At the end of the day, if you're going to be cooling your PC with fluid then you should be aware of the risks and not stupid enough to assume that a magical bottle of fluid is going to save your life and your system if you spring a leak.
Its the commercialisation of water cooling that is the most dangerous thing of all, not the products used.
Bah........
Non conductive is non conductive look at the fans they put in coolant.
Add dust to the mix for you dirty boys and then THATS where the problem is.
Long and short of it is in a controled enviroment OR small leaks in a clean machine is fine.
If your not happy with this stuff youll be happy with nothing else on the market so go get that AC7 back out the box.
Ill sit here at 4.5ghz@32c with a pair of 4870s at 30c..... quieter + cooler.
You just have to look after it right.
Watercooling isnt a monster, its a woman, treat it right youl have hours of freaky fun, use and abuse, it will go perform better with your best mate instead
If watercooling is a woman, I really really need to get laid cause I cant push my 9950 on air beyond 3ghz
-HypoG
-HypoG
Link
