BLAST FLOW Siberian Rev2 Modular VGA WaterBlock
Search Reviews
How many times have you been faced with the realisation that when it comes time to upgrade your system, it also means that you may have to upgrade your water-cooling hardware? Now we all know that waterblocks, and in particular graphics card waterblocks, can easily cost a small fortune. Surely there has to be a better way than having to budget for a new waterblock when you decide that you need the latest graphics card!
Well fear not, there is a solution! Thankfully, a company has come up with such a radical, yet simple way of offsetting the purchase price for additional hardware. And that company is BLASTFLOW. BLASTFLOW are an London, UK based company specifically targeting the high-end water-cooling enthusiasts with innovative designs, and an equally high attention to detail.
Around September of 2007 rumours began to circulate that BLASTFLOW were working on something quite revolutionary, and most certainly evolutionary. The humble waterblock as we know it is about to change significantly for the first time in many years.
BLASTFLOW Siberian waterblock
Let's see what BLASTFLOW have to say about themselves:
BlastFlow is a manufacturer of watercooling solutions for Extreme Gaming PCs and Workstations based in London that has branched out from Vadim Computers - High End Custom PC makers. We are not just another manufacturer, we are a team of PC Gamers and Enthusiasts that have been using watercooling in our own systems long before joining BlastFlow. Our mentality is simple - to invent and manufacture products that we will use ourselves, as this is not just our work - it is our hobby and passion and the few products we develop are all made with the gamer's need in mind!
It's certainly nice to know that a company producing hardware for high-end water-cooling setups is equally as passionate about what they produce, as what we are about what hardware we choose to purchase.
Anyway, enough of the chit-chat, let's have a look at the BLASTFLOW Siberian Modular VGA WaterBlock specifications.
Specifications
The BLASTFLOW Siberian Modular VGA WaterBlock's specifications were taken directly from BLASTFLOW's Product Page.
Technical Data
The Blastflow Siberian is made out of CNC machined high grade copper and 5mm acrylic cover.
Dimensions: 107x72x14.9mm
Thickness of the main area: 13mm (single slot)
Weight: 361g (with no connectors)
Connectors: Standard 1/4" BSP thread (not supplied)
Fittings:
- 4 m2x20mm bolts (for 8800GTX/Ultra/GTS640)
- 4 m2x16mm bolts (for the rest of the cards)
- 4 m2 nuts
The idea behind making a VGA waterblock modular is certainly a valid one from an economic point of view. If you decide to change your graphics card in the future then all that is required will be the appropriate 'cooling plate' for your new card. Longevity and increased compatibility are the key features here.
«Prev 1 2 3 4 5 Next»
11-03-2008, 11:27:35
PV5150
It's back and better than ever...
[IMG]http://www.overclock3d.net/gfx/articles/2008/03/09070406968s.jpg[/IMG]
Review linkage
11-03-2008, 12:19:52
Mr. Smith
Nice block, I almost got a rev1 a while back and they were going for £100.
I love the modular idea, detach block from GPU leaving loop in-tact, whack on new gpu plate, reattach block... Awesome. No draining the loop, no messing around.
THe only problem is you depend on blast flow staying in business and producing new plates for new gpus...
11-03-2008, 12:47:11
Kempez
Looks a nice block but I don't like the huge size of it (vertically)
11-03-2008, 14:00:13
nunzio
why cant they make a 2900 fitting :(
18-03-2008, 21:48:33
PCFlip
I see that you stated that they are working on a 98x2 block but what about a 3870x2 block? or the upcoming 4###x2 series, can you see if they have any plans for this and I would assume that it would use two Siberian blocks. Thanks
18-03-2008, 22:36:45
ali_james
I'm not sure if it was covered in the review.. but can you use the memory cooling plates without the w/c block? I was thinking of going for the 8800GT plate to use along with my AC Accelero 'cos the horrible little memory sinks kept on dropping off.
Cheers!
