BitFenix Recon Fan Controller Review
Software and Browser operation
Search Reviews
BitFenix Recon Review
Software and Browser Operation.
On page 4 we saw how to use the Recon as a conventional ,if not advanced, fan controller, and if you only ever wanted to interact with the controller in this way you'll find it to be a a well balanced well thought out bit of kit.  It is however capable of so much more.  As the introduction suggests, the Recon is web connectible and as such can be used via a web browser local to the PC in which it is housed, or from a remote interface with web access
The instructions make mention of an installation CD, however, in reality what is found inside the box is a small slip of paper directing you to a download on the BitFenix website.  Once installed the program enables  you to access the functions of the fan controller from pretty much anywhere in the world.
Once the Browser interface is accessed the operator can control the higher level functions of the Recon.  In Manual mode, clicking and dragging the slider on the Graphical equaliser style display alters the speed of the fan in pretty much real time (we experienced a 1-2 second delay).  In auto mode things gt quite surreal, with the sliders moving up and down of their own accord as the speed of the fans increases and decreases in accordance with the preset temperature thresholds as described on the last page.  The image below left shows the controller in manual mode with the speeds by the operator.  The image below right shows Auto mode.  Here we see the fan speeds are low indicating that the need to increase them has not yet been felt necessary by the sensor threshold.
BitFenix Recon Review     BitFenix Recon Review
The web Browser also enables the user to set up to 3 presets.  This is done by first setting the profile desired and then saving it by means of a single click into the chosen Preset position.  These saved presets can also be named to help better remember their purpose, as in the image below left we have named this profile "silent running" as the majority of fans are set to their minimum speeds.  below right we see the operator selecting P1 as a profile as indicated by the highlighted area of the screen.
The real ace in the hole for BitFenix though is the ability to access the Recon remotely from any web connected device, and that includes smart phones.  Don't go thinking you need a specific make and model of phone, or version of android or other OS and the like to download and run a compatible app, because you don't.  The Recon is web connected, so all that's needed is a bit of a fiddle around with your firewall settings and the port forwarding on your router and access can be gained simply by keying in the PCs IP address.  The Image below left shows how the interface presents when accessed via a mobile device.  I think you'll agree the interface is quite self explanatory, but just in case we've pulled a page from the BitFenix site to help detail the finer functions.  The mobile interface is in essence a smaller version of the main browser interface, but loses none of the functionality.
«Prev 1 2 3 4 5 6 Next»
12-11-2012, 05:15:20
tinytomlogan
http://www.overclock3d.net/gfx/artic...110316423l.jpg
Here we take a look at the Recon, a 5 channel fan controller from BitFenix. But what would happen if all these Web connected Recons become self aware? Granted probably not world domination. Maybe just a lot of very cool PCs.
Continue Reading
12-11-2012, 05:39:11
SPS
The feature-price ratio looks spot on. I think this will do well for Bitfenix.
12-11-2012, 05:40:06
SieB
Might replace my NZXT Sentry mix for one of these
12-11-2012, 06:37:44
Pendragon
I have often looked a fan controllers and thought that the cheap ones were too simple and the ones with the features I would like are far too expensive. This is the first one I have seen that fits the best of both. £30 quid is worth a punt, even if it's not quite what you want or need.
12-11-2012, 12:49:37
CPMFW
nice review as always
it looks really good and for that price its a real billy bargain
12-11-2012, 12:56:05
rossi94
Well done tom
12-11-2012, 14:51:41
Master&Puppet
I was so excited about the launch of this. And then I saw 10W per channel. I cried.
13-11-2012, 16:44:46
G-Dubs
@rossi94, Wasn't Tom, was me, but thanks for the compliment none the less
@master&Puppet. Nowt wrong with 10W per channel. What was it you were hoping to do but now can't?
13-11-2012, 16:51:27
rossi94
Sorry, messed that up but nice review, thank you G-Dubs.
13-11-2012, 19:03:04
yassarikhan786
Nice review Gary. I really like the web based options.
14-11-2012, 07:13:10
Master&Puppet
Nothing wrong with it per se - but I was looking to run my pumps off a fan controller so 10w wasn't going to do it for me.
It was back in April when I was looking at this and the rumours for the Recon were 25-30W per channel if remember rightly so I was disappointed when it launched with 10W. I ended up going for a Lamptron Touch.
12-12-2012, 03:11:12
rasta111
I've always been a fan of BFs watercooling line, so a fan controller @ a descent price with descent features works for me. I've gone through 4 controllers in 3 years & now have an AEROCOOL X-VISION, which has good features but the temp sensors are horrible. I guess the RECON is my next target.
