BitFenix Hydra Pro Fan Controller Review
Up Close: Packaging and Contents
Published: 31st August 2012 | Source: BitFenix | Price: £24.98 |
As with many BitFenix products the Hydra Pro comes packaged in a simple black card box. The exterior of which gives us a representation of the face plate of the controller along with details of specification and key features.
Inside we find that the controller is simply encased in a plastic bag and sandwiched between to polystyrene end-plates. Aside from a set of locating screws the only other contents of the box is a simple instruction sheet. Remember though that this is just a simple 5 channel fan controller, we're not expecting oodles of temperature sensors and an instruction booklet!
Looks good in the CM Storm Trooper
haha it did make me giggle that, we do like to jest the newbies :P you'll be able to soon
Anyway, the fan controller is a steal for the price. Sure, no fancy functions, but basic good ones. It can handle one of those monster 1,6 amp Delta fans just fine.
i really like the simple look of it.
Will be using a NZXT Switch 810 White. So, I have the issue of the front fan on my 360 rad being blocked by the plate in the 5.25" cage (As TTL shows in his review). I am planning to dremel out a bit of that to allow unrestricted airflow. But, with this fan controller, I wonder if it would fit in that 5.25 bay partially taken up by the rad and fan. Then just tuke all the wires in behind. I am wondering if the PCB board and connectors would have enough space. Be great use of that bay.
Thanks,
Whaler
I have one question on this as I contemplate my new build. Hopefully someone will have an idea...
Will be using a NZXT Switch 810 White. So, I have the issue of the front fan on my 360 rad being blocked by the plate in the 5.25" cage (As TTL shows in his review). I am planning to dremel out a bit of that to allow unrestricted airflow. But, with this fan controller, I wonder if it would fit in that 5.25 bay partially taken up by the rad and fan. Then just tuke all the wires in behind. I am wondering if the PCB board and connectors would have enough space. Be great use of that bay. Thanks, Whaler |
Yea that would work - I have the lamptron touch which looks like it has a very similar profile. You should have 1-2" spare behind the fan controller's PCB to fiddle with wires. It will be a little bit tight to work with the wires whilst the radiator is in but I think it would work.
Whaler
I only wish that they both came with a double handful of splitters so you can use the full potential of the design. As it stands, you're only able to use 1 fan per channel, and each channel can easily handle 4 to 12 fans (typical .25 amps (Corsair AF-120 Perf. Series). So thats 12 of Corsair's highest flow/static pressure fans on each channel (.25a x 12 = 3a - each channel handles 3.75a). That's a (theoretical) total of 60 fans! Yes, I'd say these are good for large water cooling setups.
Able to handle 30W and control 5 channels, the Hydra Pro forms part of the new range of fan controllers from BitFenix
Continue Reading
