Arctic Cooling Freezer 7 & 64 Pro Coolers
Specifications & Contents Continued
Published: 2nd November 2006 | Source: Arctic Cooling | Price: |
Again, the technical specifications of the Arctic Freezer 64 Pro cooler were taken directly from Arctic Cooling's website, you can find additional information here
*Heat Sink: 104 x 58 x 126.5 mm
*Fan: 107 x 43.5 x 96 mm
*Overall Dimensions: 107 x 96.5 x 126.5 mm
*Rated Fan Speed: 2200 RPM
*Power Consumption: 0.16 Amp.
*Air Flow: 40 CFM / 68 m3/h
*Weight: 528 g
*Noise Level: 0.8 Sone
*Thermal Resistance: 0.18°C/Watt
*Thermal Interface Material: Pre-applied MX-1
*Paste *Warranty: 6 Years
(Accessed 16th October 2006)
Compatibility
Arctic Cooling specifies that the Arctic Freezer 64 Pro is compatible with the following CPU's:
*AMD Sempron, Athlon 64, Athlon 64 X2 and Athlon 64 FX (Socket 754, 939, AM2, and all AMD Opteron processors.
Packaging and Contents
The packaging for the Arctic Freezer 64 Pro is exactly the same as the its Intel brother, so I'll refrain from covering it again.
Included inside the packaging were:
* 1 x Arctic Freezer 64 Pro cooler
* 1 x Installation booklet
* 1 x Arctic Cooling case sticker
Now that we've been formally acquainted with our test subjects, let's have a bit of a closer look.
Link to the review
