Arctic Cooling Accelero S2 - Passive Graphics Cooler
Test Results
Search Reviews
Test Results
Here are the results of my testing on the Arctic Cooling Accelero S2 vs the very slightly modified stock cooler:
Idle Temperature (°C)
Load Temperature (°C)
Stock Cooler
45 58
37 47
artic cooling s2 results
These are some pretty impressive numbers for the Arctic Cooing Accelero S2. 8°C cooler at idle and 11°C cooler at load is awesome.
What you also have to consider is that the S2 is a totally passive solution, albeit your case airflow has to be decent to achieve a good result.
Noise
Usually I would tell you about my thoughts on noise but there is little to say other than there is no noise from this cooler - totally passive.
In the future I will have sound testing equipment to test out more coolers, but I don't think this is necessary here!
«Prev 1 2 3 4 5 Next»
21-05-2007, 11:26:49
FarFarAway
GFX card too hot? Annoyed at fan noise?
Arctic Cooling may have a solution
21-05-2007, 11:32:14
DavidT
Awesome Review
And WOW, 37C using an entirely passive cooler? That's pretty damn nice!
How heavy is that thing btw? I looks like it would put a lot of stress on the card.
21-05-2007, 11:35:17
FarFarAway
I know I was quite honestly shocked. I had to check and double check the figures
21-05-2007, 11:35:28
Ham
Jeeze thats big. You rekon it could cope with the load of an 8800 though kemp? Maybe if you added a fan?
21-05-2007, 11:36:41
FarFarAway
Well the S1 has 4 heatpipes and an add-in fan module so i would guess you'd be ok.
21-05-2007, 23:41:54
PV5150
Wow that is insanely large, but awesome temps. Great review as usual Kemp
20-12-2007, 15:34:28
fenacv
