Arctic Cooling Accelero S2 - Passive Graphics Cooler
A Closer Look - the cooler itself
Published: 21st May 2007 | Source: Arctic Cooling | Price: |
The cooler is pretty huge it has to be said. The older Arctic Cooling solutions were more wide than high but this beasty is pretty tall and you should certainly check if you have a smaller case to make sure it will fit.
Having said that it is also pretty good looking for a cooler and stands out when installed.
As you can see there are two copper heatpipes that reach right to the top of the cooler extending from the base where they go into a solid copper base 2.4mm thick. The fins have a large surface area for heat dissipation, with adequate (case) airflow.
The only complaint I would really have is that the plastic top and bottom add-ons are a little..well: tacky for want of a better word. It's not a huge complaint but it's worth noting
As you can see (apart from my clumsy fingermark), the thermal paste is pre-applied to the base of the cooler and looks to be good stuff. I am using this it is as standard in the review so we get a good idea of what the cooler is like when used in a "straight out of the box" situation.
NB: I did re-smooth the paste over before installing!
The finish on the cooler looks to be pretty decent although bearing in mind I could only get a picture of part of it as the paste was in the way.
Awesome Review
And WOW, 37C using an entirely passive cooler? That's pretty damn nice!
How heavy is that thing btw? I looks like it would put a lot of stress on the card.
I know I was quite honestly shocked. I had to check and double check the figures
Jeeze thats big. You rekon it could cope with the load of an 8800 though kemp? Maybe if you added a fan?
Well the S1 has 4 heatpipes and an add-in fan module so i would guess you'd be ok.
Wow that is insanely large, but awesome temps. Great review as usual Kemp
hey, I found that is on sale here! just $18.70
http://www.pricebat.ca/Arctic-Cooling-Accelero-S2-Passive-VGA-Cooler-for-Select-NVIDIA-ATI-Series.p_10061171/
Arctic Cooling may have a solution
