AquaXtreme MP-05 Pro Water Block
Specifications
Search Reviews
Specifications
The following information has been taken directly from CoolTechnica's website:
Features
• The inlet is located directly above the CPU die area for flow-impingement action to create very high levels of turbulence.
• The new and improved Copper 110 base plate of the MP-05 Pro Limited Edition features 432 Micro Pins covering the CPU die area. This design maximizes the surface area exposed to coolant while improving turbulence where it's most needed.
• MP-05 Pro Limited Edition CPU Water Block comes with N02 X REV.2 Nozzle accelerator mid plate made out of Clear Polycarbonate or Black Acetal (Delrin).
• Outstanding performance with only two barbed fittings.
• MP-05 Pro Limited Edition CPU Water Block comes with 1/2" High-Flow inlet and outlet barbed fittings by default.
• S/S 304 Universal Socket Mounting Adapter is compatible with most modern motherboards featuring mounting holes around the socket area.
Compatability
The Universal AquaXtreme™ MP-05 Pro Limited Edition comes with all the necessary mounting hardware for the following CPU sockets:
• Socket 462 (AMD Socket A) via the 4-holes through the motherboard method. Important Note: AMD 462 Socket lug mounting is not supported.
• Socket 423 (Intel Willamette P4), Socket 603/604 (Intel Xeon) via the 4-holes through the motherboard
• Socket 478 (Intel Northwood P4/EE) via the 4-holes through the motherboard by removing the black plastic heatsink retention frame.
• Socket 754/939/940 (all AMD Athlon64 series) via the 2-holes screwing into the socket back-plate method
• Socket 775 (Intel Socket T Prescott-style LGA) via the 4-holes through the motherboard method
Layout
AquaXtreme MP-05 Layout
From the top down we have:
• Universal Mounting Hardware.
• 9/16-18 straight threaded inlet and outlet ports for High-Flow barbed fittings with O-Rings.
• Black Acetal (Delrin) Top.
• N02 X Accelerator Nozzle Mid Plate made out of clear polycarbonate or black delrin.
High-precision CNC machined Copper 110 Base Plate featuring 432 Micro pins and fine channels.
«Prev 1 2 3 4 5 Next»
19-09-2006, 06:01:58
Jim
"Looking for the ultimate water block but on a budget? Today we take a look at the AquaXtreme MP-05 to see if it fits the bill!"
Linky
19-09-2006, 06:08:29
FragTek
Nice block but I can't believe that they didn't clean it out before shipping it to you, that's a good way to screw up an expensive pump getting nasty debris in it.
19-09-2006, 06:35:17
FarFarAway
Looks a very nice block, shame about the shortcoming of the packaging and care taken during manufacturer
19-09-2006, 07:32:32
Ham
Sorry if its in there & i missed it but what do these retail at?
19-09-2006, 07:42:15
ai_01
awesome review as usual, that would suck h/e if u didnt open the block
19-09-2006, 08:06:00
Jim
Thx for pointing that out - added to conclusion
19-09-2006, 08:47:16
specialtech
great review, yet again!!! well done
Shame about the negative points, we can actually get hold of these but sadly the bad points are putting me off
19-09-2006, 17:08:47
NickS
I love mine. Mine came slightly dirty as well but a few hrs in vinegar solved that . Great review XMS.
19-09-2006, 17:12:21
Jim
Yeah, I used Arcticlean to sort mine out - but vinegar would probably have been better.
In a way it's good to know that i'm not the only person to have a dirty MP-05 block - so now it can't be shrugged off as an isolated incident.
19-09-2006, 18:11:20
FarFarAway
While the block is a good performer: they will have to improve their quality testing. I am totally unimpressed with manufacturers who let QT slip and there is simply no excuse. I don't think I would recommend people to buy this over a Swiftech Storm - as I know Swiftech's QT is at a very high standard.
19-09-2006, 18:29:18
SuB
nice review, didn't know the core2's put out that much heat! lol
Shame about the manufacturing fall downs though.
19-09-2006, 19:03:07
FarFarAway
They do @ 3.8GHz @ 1.65v
20-09-2006, 02:21:15
Jim
Yeah they can be hot buggers when you start pumping the voltage thru. I think the IHS on mine is slightly concave anyway - time to lap
26-01-2007, 02:25:15
FrOzE
Hi...
Wanna ask wat addictive was used in the setup..?
The red addictive.
26-01-2007, 04:10:03
Jim
Originally Posted by name='FrOzE'
Hi...
The red addictive.
Hiya,
That is actually UV Red tubing available from dangerden.com (and lots of stores that stock Danger Den products).
