Antec P182 Advanced Super Mid Tower
Internals
Published: 28th May 2007 | Source: Antec | Price: |
The interior of the P180 was well built, well designed and had very few major flaws. I'm pleased to say that this has carried over to its younger sibling. The steel innards are solid and there aren't many sharp edges to snag your fingers on while installing your hardware. In terms of the layout, not much has really changed since the original. The P182 still sports the 2 chamber design with the soft edge guards to eliminate as much heat travelling from one compartment to the other.
It still sports the twin exhaust fans on the upper rear and rear upper of the case, ensuring that there's never any hot air left around the CPU area.
The 5.25" and 3.5" bays still use the same rail system that the original had.
The 3.5" bays in the top compartment of the case can be adapted, using the supplied metal clips, to take 120mm fans.
As you can see the basics of the case haven't really changed that much...so what have they changed? Well, Antec have listened to end-user feedback and have altered it for the better in one particular area - cable management. To address this issue, Antec pulled a few neat tricks from up their sleeves. Firstly the mass of thick, loose front panel connector wires that made the case look such a mess have been properly wrapped and given the appropriate block headers. This alone brought control to a lot of the mess that plagued the original case.
Next up Antec decided to poke some holes in the motherboard tray in roughly the right places for the majority of the connectors that you can run behind the tray. They have even cut a slot out the base of the upper section to accommodate cables from down below, such as the PSU and HDD cables. And with that, they have included rings stamped out of the tray itself to hold the wires in place.
Recently I got a chance too look over Antec's new revision of the p180. See how it fairs here
It's a hard case to criticise tbh, although I'm not a huge fan of the looks it's still a nice looking case.
Glad they sorted cable tidying too
looks cool
only one snag,
NO WINDOW!
the only thing that case needs...
and antec STIL dont bother
thats the only reason i wouldnt buy one
black, or shiney gunmetal, with window....
only one snag,
NO WINDOW!
Originally Posted by name='ionicle'
looks cool
only one snag, NO WINDOW! the only thing that case needs... and antec STIL dont bother thats the only reason i wouldnt buy one black, or shiney gunmetal, with window.... |
Originally Posted by name='DavidT'
I assume it would be difficult to get a side window in the 3-layer side panel though. Not to mention, it would defeat the purpose of having the 3-layer panel,as noise would easily make it through the window.
kustom do a P180 with a side window....why cant antec just do one, with either a super thick perspex, or 3 layers of perspex or somthing....with perhaps foam to hold it in round the edges, or ...them rubber things they use on proper windows to hold them in, that would prevent any sound getting out imo
Antec don't do one as it is outside of the remit of the case. They want the P182 to be quiet and cool and a window certainly hinders one part of the brief
yeh, its a shame tbh, a window would look awsome imo
Windows arent exactly in keeping with the looks of this case tbh. I have one and its big selling point for me is the modern, clean look, no OTT features / bling at all
http://www.kustompcs.co.uk/acatalog/Kustom_PCs_Shop_Aluminium_ATX_Cases_1.html#a1007
that is what the case should look like
But why? Unless you've modded the interior really well, it's very very ugly inside
i like the look of the interior tbh...
imagine watercooling in that....
imagine watercooling in that.... ![]() |
Originally Posted by name='donnynsc'
I just bought this case from Overclockers 2 days ago. Still waiting for delivery, hope it really dead silence...
.Inside is horrible, and why would you want to see the PSU compartment which is always just a mess of wires. not only that but that windows is crud. They should have rubber trimmed the cut and put some thinner acrylic on the inside
Maybe if it was painted black like the SE edition, even then, it's more the layout that makes it ugly than the finish.
What they could have done with that window, is make it so that you only see the mobo area, and they should have mounted the window on the inside and made a bevel on it to make it flush with the outside.
Going to have to agree with you on that one, unlike the outside of the case, the interior looks extremely fugly.
Maybe if it was painted black like the SE edition, even then, it's more the layout that makes it ugly than the finish. What they could have done with that window, is make it so that you only see the mobo area, and they should have mounted the window on the inside and made a bevel on it to make it flush with the outside. |
ah well, just me who thinks it looks half decent on the inside then
but then again, i think thermaltake's look ok on the inside...
however, i do like my lian li now
with a window, especially
that is what the case should look like ![]() |
I agree with Yeungster, that just ruined the case :| I mean just look at it
That case deserved better
Not too keen on the window aswell, Much better without it. You can see the pics of mine here:
http://www.oc-arena.co.uk/pics/ANTEC%20P182/
Rate my cable managment aswell. I'll get some new pics as its even better now
Antec 182 is hightly rated by CustomPC. I was very keen bout casing with windows in the past, but, guess I'm just not bothered anymore, thus I bought this case
I only skimmed the article. What's the price point on this bad boy? I really like a sleek windowless unit. That's for the kiddies...
Ryan
Ryan
Ryan |
http://www.us.ncix.com/products/index.php?sku=24122&vpn=P182&manufacture=ANTEC&phpuuid=71C1398E-5912-963A-2C8D11DC1D614AD6
I do like the looks of this case. And i can live without the window on it.
Anyone know if it will fit an 8800gtx???
I'm pretty positive i would fit a GTX Xh
Without a doubt. And if for some reason you can't, you can just remove the hard drive cage to make some space.
Yes, it will definitely fit a 8800GTX.
Mine is BFG 8800GTX OC2 card, fit like a dream. Middle HD case need to remove for installation, can put back after the GTX is in place.
I removed my middle HD case anyway, coz it can't slot in after I fitted the 120mm front case fan.
Mine is BFG 8800GTX OC2 card, fit like a dream. Middle HD case need to remove for installation, can put back after the GTX is in place. I removed my middle HD case anyway, coz it can't slot in after I fitted the 120mm front case fan. ![]() |
Originally Posted by name='OV3RCLOCK3R'
Mine fits even with the front fan installed
Took my HDD cage out and mounted my DDC + watertank
.Guess I am. Anyway, I don't really need tht middle case, might as well put it away.
Will the
H20-220 Apex™ Ultra
Fit into this case and will the rad fit on back without obstructing anything?
H20-220 Apex™ Ultra
Yes, you should be able to fit that kit in, although you may need to do some modding of the case to get it snug.
I was just wondering where the pump would go and how the rad on the back would fit.
Would it not get in the way of the motherboard external connections or can I mount it so its above the case ?
Originally Posted by name='tsinc80697'
What type of modding you think?
I was just wondering where the pump would go and how the rad on the back would fit. Would it not get in the way of the motherboard external connections or can I mount it so its above the case ? |
Not sure if you've got one already but I have a P182 here for sale for like £50 o.n.o if you're interested
Originally Posted by name='llwyd'
External rear mounting of the radiator IS an option, but you would need to put some effort into making effective and spacious brakets. The top is plastic and so easily cut to accommodate a radiator OR you can mount the radiator on feet on top of the case and run the hosing to it via the two pre-cut holes in the back of the case.
Not sure if you've got one already but I have a P182 here for sale for like £50 o.n.o if you're interested |
Can the radiator only be mounted on the back and not the top ?
Definitely interested if its in good condition and comes with all the parts like new. Was just about to buy one over the next few days if it can fit a water cooling setup without too much hassle.
Can the radiator only be mounted on the back and not the top ? |
rear mounting would probably be the most effort as the radiator needs to be a good 6"+ away from the back of the case. mounting it on top would be my first choice (although I ran it with the radiator sat on some feet on the desk next to the pc) as it leaves the case untouched for the future and keeps it away from warm exhaust from the GPU and PSU
Thanks alot llwyd, sorted out a case from him and he helped me with a watercool build!
Should have rep on here, unless Im blind !
Should have rep on here, unless Im blind ! |
lol suppose I am then!
Get back to work anyway ! :P
