Antec P182 Advanced Super Mid Tower
Externals
Externals
From the outside this case looks identical to the P180. There is an special edition variant of the P182 which has mirror finished side panels, but unfortunately that version wasn't available for this review. The P182 is certainly a very sleek looking case, with no obvious blow holes on the front or side panels. The finish is what Antec refers to as 'gun metal black', which to me at least is a rather dark grey. To illustrate this I placed one of the panels from my original P180B next to the P182. As with the original, its panels consist of the 3-ply metal-plastic-metal that was designed too keep the case as quiet as possible.
p182_over p182_panels
Here we see the front door of the P182, hiding away all the normal front panel features except for the USB, firewire and audio connectors. Along with the external connectors is the lock, so that if you wish you can stop people accessing what hides under the door. All things considered, it's pretty plain - sporting only an embossed Antec into the top right.
p182_front
Under the door we see a well thought out bay design, with 4 x 5.25" bays at the top and a single external 3.5" bay in the middle. Also we see on the front the grilled doors that open up to reveal the P182s dust filters. Personally I think these are a neat addition as they do stop an awful lot of dust. The only down side being that you have to clean them regularly.
p182_front_open p182_front_filters
The side panels are very minimalist. Simply the metal, black panel surrounded by the slightly duller plastic for the lower tier. There are no fan holes or vents on either side.
p182_side
Moving to the rear of the case we come encounter some of the first changes that Antec have made to warrant the P182 name. The case retains its well thought out rear layout, whilst making some improvements. Firstly, Antec have mounted the speed control switches for the two exhaust fans into the back of the case. Thus making it far, far easier than the previous model to adjust fan speeds. The second change to the back panel is the addition of pre-cut holes, complete with grommets, to accompany water cooling tubing. Essentially it allows the user to run their lines to an externally mounted or free standing radiator.
p182_back p182_back_switches
p182_back_water
As with its elder brother, the P182 looks rather ravishing. It maintains its smooth all over approach whilst adding to the existing functionality of the original design. Let's take a look at the innards of the case...
«Prev 1 2 3 4 5 6 Next»
23-05-2007, 06:48:11
Ham
Recently I got a chance too look over Antec's new revision of the p180. See how it fairs hereQuote
23-05-2007, 06:54:46
FarFarAway
It's a hard case to criticise tbh, although I'm not a huge fan of the looks it's still a nice looking case.
Glad they sorted cable tidying too Quote
23-05-2007, 09:12:34
ionicle
looks cool
only one snag,
NO WINDOW!
the only thing that case needs...
and antec STIL dont bother
thats the only reason i wouldnt buy one
black, or shiney gunmetal, with window....Quote
23-05-2007, 09:19:54
DavidT
Originally Posted by name='ionicle'
looks cool
only one snag,
NO WINDOW!
I assume it would be difficult to get a side window in the 3-layer side panel though. Not to mention, it would defeat the purpose of having the 3-layer panel,as noise would easily make it through the window.Quote
23-05-2007, 09:23:48
Ham
you got it there. From modding my P180b i can tell you its a total pita too cut.Quote
23-05-2007, 09:51:57
ionicle
kustom do a P180 with a side window....why cant antec just do one, with either a super thick perspex, or 3 layers of perspex or somthing....with perhaps foam to hold it in round the edges, or ...them rubber things they use on proper windows to hold them in, that would prevent any sound getting out imoQuote
23-05-2007, 09:53:40
FarFarAway
Antec don't do one as it is outside of the remit of the case. They want the P182 to be quiet and cool and a window certainly hinders one part of the briefQuote
23-05-2007, 09:55:42
ionicle
yeh, its a shame tbh, a window would look awsome imo Quote
23-05-2007, 10:13:12
llwyd
Windows arent exactly in keeping with the looks of this case tbh. I have one and its big selling point for me is the modern, clean look, no OTT features / bling at allQuote
23-05-2007, 10:36:58
ionicle
23-05-2007, 10:38:10
FarFarAway
But why? Unless you've modded the interior really well, it's very very ugly insideQuote
23-05-2007, 10:40:17
ionicle
i like the look of the interior tbh...
imagine watercooling in that.... Quote
23-05-2007, 10:43:11
donnynsc
I just bought this case from Overclockers 2 days ago. Still waiting for delivery, hope it really dead silence... Quote
23-05-2007, 10:48:18
Ham
With the fans on low its very quiet. But you'll bee some biggass air coolers cos theres not that much flow. Or water.Quote
23-05-2007, 10:48:31
llwyd
Inside is horrible, and why would you want to see the PSU compartment which is always just a mess of wires. not only that but that windows is crud. They should have rubber trimmed the cut and put some thinner acrylic on the insideQuote
23-05-2007, 10:52:07
DavidT
Going to have to agree with you on that one, unlike the outside of the case, the interior looks extremely fugly.
Maybe if it was painted black like the SE edition, even then, it's more the layout that makes it ugly than the finish.
What they could have done with that window, is make it so that you only see the mobo area, and they should have mounted the window on the inside and made a bevel on it to make it flush with the outside.Quote
23-05-2007, 10:55:30
donnynsc
Fortunately mine hasn't got a window. LOLQuote
23-05-2007, 10:58:32
ionicle
ah well, just me who thinks it looks half decent on the inside then
but then again, i think thermaltake's look ok on the inside...
however, i do like my lian li now
with a window, especiallyQuote
23-05-2007, 12:05:58
Yeungster
No offence, but that looks bloody terrible! It doesn't suit the case at all, and looks like a bodge jobQuote
23-05-2007, 16:36:48
Bogel
I agree with Yeungster, that just ruined the case :| I mean just look at it That case deserved better Quote
23-05-2007, 17:27:15
OV3RCLOCK3R
Not too keen on the window aswell, Much better without it. You can see the pics of mine here:
http://www.oc-arena.co.uk/pics/ANTEC%20P182/
Rate my cable managment aswell. I'll get some new pics as its even better now Quote
23-05-2007, 19:07:11
donnynsc
Antec 182 is hightly rated by CustomPC. I was very keen bout casing with windows in the past, but, guess I'm just not bothered anymore, thus I bought this case Quote
23-05-2007, 20:38:47
FghtinIrshNvrDie
I only skimmed the article. What's the price point on this bad boy? I really like a sleek windowless unit. That's for the kiddies...
RyanQuote
23-05-2007, 20:42:48
DavidT
Ryan
About $140 US
http://www.us.ncix.com/products/index.php?sku=24122&vpn=P182&manufacture=ANTEC&phpuuid=71C1398E-5912-963A-2C8D11DC1D614AD6Quote
24-05-2007, 04:52:39
nunzio
I do like the looks of this case. And i can live without the window on it.Quote
26-05-2007, 23:03:41
xh131t10n
Anyone know if it will fit an 8800gtx???Quote
27-05-2007, 00:15:21
MikeEnIke
I'm pretty positive i would fit a GTX XhQuote
27-05-2007, 00:42:20
DavidT
Without a doubt. And if for some reason you can't, you can just remove the hard drive cage to make some space.Quote
27-05-2007, 05:04:56
Yeungster
Agreed. Although I haven't got a GTX, I've read that by removing the middle HD cage, it'll fitQuote
27-05-2007, 06:09:17
donnynsc
Yes, it will definitely fit a 8800GTX.
Mine is BFG 8800GTX OC2 card, fit like a dream. Middle HD case need to remove for installation, can put back after the GTX is in place.
I removed my middle HD case anyway, coz it can't slot in after I fitted the 120mm front case fan. Quote
27-05-2007, 08:51:50
OV3RCLOCK3R
Mine fits even with the front fan installed Quote
27-05-2007, 11:43:51
Ham
Same here, he must be using a 38mm 120.
Took my HDD cage out and mounted my DDC + watertank.Quote
27-05-2007, 20:29:00
donnynsc
Guess I am. Anyway, I don't really need tht middle case, might as well put it away. Quote
16-11-2007, 07:07:13
tsinc80697
Will the
H20-220 Apex™ Ultra
Fit into this case and will the rad fit on back without obstructing anything?Quote
16-11-2007, 07:37:31
Ham
Yes, you should be able to fit that kit in, although you may need to do some modding of the case to get it snug.Quote
16-11-2007, 07:38:58
tsinc80697
What type of modding you think?
I was just wondering where the pump would go and how the rad on the back would fit.
Would it not get in the way of the motherboard external connections or can I mount it so its above the case ?Quote
16-11-2007, 07:57:40
llwyd
External rear mounting of the radiator IS an option, but you would need to put some effort into making effective and spacious brakets. The top is plastic and so easily cut to accommodate a radiator OR you can mount the radiator on feet on top of the case and run the hosing to it via the two pre-cut holes in the back of the case.
Not sure if you've got one already but I have a P182 here for sale for like £50 o.n.o if you're interestedQuote
16-11-2007, 08:00:13
tsinc80697
Definitely interested if its in good condition and comes with all the parts like new. Was just about to buy one over the next few days if it can fit a water cooling setup without too much hassle.
Can the radiator only be mounted on the back and not the top ?Quote
16-11-2007, 08:03:55
llwyd
good lad. add my msn if youre able - llwyd(at)overclock3d(dot)net
rear mounting would probably be the most effort as the radiator needs to be a good 6"+ away from the back of the case. mounting it on top would be my first choice (although I ran it with the radiator sat on some feet on the desk next to the pc) as it leaves the case untouched for the future and keeps it away from warm exhaust from the GPU and PSUQuote
16-11-2007, 09:37:48
tsinc80697
Thanks alot llwyd, sorted out a case from him and he helped me with a watercool build!
Should have rep on here, unless Im blind !Quote
16-11-2007, 09:41:22
llwyd
under avatar = Reputation: Moderator Quote
16-11-2007, 09:42:21
tsinc80697
lol suppose I am then!
Get back to work anyway ! :PQuote
