Alpenfohn K2 Review
Up Close: Packaging and contents
Published: 18th July 2012 | Source: Alpenfohn | Price: £64.99 |
The K2 comes in an un windowed cardboard box resplendent with it's own pop out carry handle. As usual the box has pictures of the cooler inside as well as giving details of specification and features. Opening up the packaging is reminiscent of opening up a Russian doll, as there are boxes within boxes requiring a bit of a think as to how to get the contents out.
Contents wise, aside from the cooler itself we get 2 fans, 1x140mm and 1x120mm. The fans are nicely made and are finished in that soft touch plastic that I can't help but find very tactile. Also included are all the mounting screws and necessary brackets as well as a multi-socket back-plate. Spring-clips to secure the fans, a molex adapter, instructions and a small syringe of TIM complete the package.
the fight, but the nominal usage looks good. the fans are quite different with the 2-tone
feature. thanks again
airdeano
some of the older coolers were tested in different cases (wich is ridiculous btw) so i would change the following text, since it's misleading:
"To provide continuity the test set up is as always " -Best Regards |
ie: the cases used made no difference from one to another how the heatsink performed.
I'm kind of surprised to see that the K2 falls behind the "big boys" significantly, while other reviews place it straight above the NH-D14!
Benchmark tests were done during case changes and were always within tollerances of each other.
ie: the cases used made no difference from one to another how the heatsink performed. |
dude, it was just a friendly suggestion, no need to delete my posts, because you ran out of arguments.
Top of the range dual tower heatsink from German manufacturers Alpenfohn but will K2 be a mountain or a molehill?
Continue Reading
