AeroCool X-Predator Evil
Introduction and Tech-Spec
 AeroCool X-Predator Evil Black/Orange
The XPREDATOR Evil Black edition is a newly designed case from AeroCool, Wearing the Black PGS  (Performance Gaming System) badge it forms part of their Ultimate Gaming Series range. The X-predator is available in 4 different colour combinations.  Plain Black, Black with Green accents, White with Black accents, and lastly Black with Orange accents which is the "Evil Black" edition reviewed here.
Undeniably a full tower case, with some retailers dubbing it a Super tower.  The case measures 600mm in height, being 234mm wide and 555mm deep.  The case is able to take pretty much any Motherboard you care to throw at it, from ATX, up through EATX all the way up to the giddy heights of XL-ATX boards such as the Assassin and UD9.
Technical Specifications
Case TypeFull Tower
MaterialSECC 0.8/1.0mm
Compatible MotherboardsFlex ATX / ATX / Micro ATX / E-ATX / XL-ATX
Chassis Dimensions600(H) x 234(W) x 555(D)
Drive Bays6 x 5.25" (External) / 6 x HDDs (internal) / 1 x 3.5" (External)
Expansion Slots10 Slots
Max length space available for PCI cards330mm
I/O Ports1 x USB 3.0 / 3 x USB 2.0 / e-SATA / Mic & headphone (AC97 & HD audio)
Fan controllerControls 6 fans simultaneously with max combined wattage of 20W
Cooling optionsFront - 1 x 23cm fan Orange LED (included), Back - 1 x 12/14cm fan (optional), 4 x 12/14cm fans or / 1 x 18/20cm fan (optional), Top - 1 x 23cm fan (included), Bottom - 1 x 12/14cm fan (optional)
200mm Fan Specs
Rated voltage12V
Operating Voltage Range10.8 - 13.2V
Starting voltage8V
Rated Current0.15A +10% Max
Label Current0.24A
Locked Current0.24A +10% Max
Power Consumption Speed2.88W+10%Max
Fan speed750 ±100RPM
Max AirFlow49CFM
Max Static Pressure0.54mm-H2O
Noise27dBA
MTBF25,000/hrs
Warranty24 months
EAN barcode4710700956472
«Prev 1 2 3 4 5 6 Next»
31-10-2011, 09:33:40
tinytomlogan
Here we take a look at the X-Predator "Evil Black" edition. A Huge Beast of a case from AeroCool.
Continue ReadingQuote
31-10-2011, 10:00:24
SieB
I don't like the look of the toolless fittings on the optical bays and the side panel doesn't look good either with those fan grills on it. Besides that though it looks like a decent case. Quote
31-10-2011, 10:11:36
badtaylorx
this thing would look er with some of those cougar fans in it!!!Quote
31-10-2011, 10:46:51
daniSAUR
The only thing I like with the case is that funky air-vent at the top.
Not to my taste really.Quote
31-10-2011, 11:27:04
yassarikhan786
I agree with you. I've seen that air-vent thing before on a scratch build by someone on another forum.Quote
31-10-2011, 11:59:03
| raVen |
I hate this orange!BTW case looks too aggressive for me, side panel window should be plain without fan mounts.Quote
31-10-2011, 13:12:45
yassarikhan786
I think the white version with the black accents would look the dog's danglie's as Tom would say .Quote
31-10-2011, 13:16:32
| raVen |
Or Black with green accents Quote
31-10-2011, 13:45:09
Ghosthud1
i would buy it solely on the looks.Quote
31-10-2011, 14:12:40
Ravious
Its a good looking case but it isn't something I would have my components in.Quote
31-10-2011, 14:18:31
murphy7801
I think the words ugly and uninspired come to mind.Quote
31-10-2011, 17:06:15
Alicarve
i quite like the look of this case, good review btw
gary a new reviewer?Quote
31-10-2011, 21:56:57
Zeals
Not exactly my cup of tea and despite being it's size, I don't think it will support any of those thick XSPC RX radiators on the top, but correct me if I am wrong.
Also what's with the sudden re-emergence of the word plethora?Quote
01-11-2011, 06:48:51
VengeanceUK
see, i actually quite like the look of it,
and with all the orange accents would have been a good base for tinytoms's begal project lolQuote
01-11-2011, 15:45:02
Master&Puppet
Wow, bit like marmite this case!
I think it looks absolutely awesome, it's right up my street looks wise.Quote
11-11-2011, 03:35:02
lolplox
can it fit a black ice gtx280? with maybe push/pull config? or is that too thick?Quote
12-11-2011, 08:26:57
Skeksix
I have recently seen this case in the flesh during my quest to find a case ready for my lazy style of water cooling and I must say as cases go it is pretty nice. Orange is not really my thing but it was really pleasant to see a company mixing thinks up a bit rather than painting everything a single colour.Quote
14-11-2011, 11:15:43
DiggyDiggyHole
Is it me, or does this look like a bigger version of the Alienware Area 51? Now, if only those fan vents where set to a motor and a thermal sensor, now that would be amazing. Also a motorized door on the front, then they could just put Alienware's case to absolute shame. Quote
