A+ Case El Diablo ATX Case
Test Setup
Published: 17th November 2007 | Source: Nanopoint | Price: £75 |
So, with all that cooling hardware, how did El Diablo perform?
The test system specification was as follows:
Motherboard - Asus P5K3
CPU - Intel E4300
Graphics - 8800GTS
HDDs - 2x Hitachi 80GB SATA2 configured in RAID0
PSU - Nexus 500W modular
CPU - Intel E4300
Graphics - 8800GTS
My main aim during the test was to ascertain just how effective El Diablo's cooling is.
Note, all componentry was cooled by the stock cooling solution/s.
Idle tests involved taking 5 temperature readings over a period of 10 minutes, the system was at zero load during these measurements, temperatures were measured using Asus' onboard probes using the Asus Probe software.
Load tests were carried out with two instances of Prime95 running, again, 5 readings were taken over a period of 10 minutes, the first of the 5 readings was taken after the system had run Prime95 for 30 minutes.
Results
Note - ambient temp. was measured at 26 Degrees C.
There's no doubt in my mind that the substantial cooling solution provided by the 200mm and 280mm has contributed to a cool running test setup.
On the basis of thermal performance alone, given the relatively high ambient temps. this case is a good performer.
Now let's move onto the conclusion.
If you like your case to have a presence, take a look here because this case has it in spades!
Nice job dude. Looks like a solid case.
Just if they'd made it out of alu!
Gratz on the 1st review too
not a case i'd personally go for
but good job on reviewing it, made a good read
Case is quite ugly, good if your a fan freak though
Just if they'd made it out of alu! ![]() Gratz on the 1st review too ![]() |
What a stellar effort on your first review mate. You covered all of the main features/cons and provided good images to reinforce them. Well done ...keep up the great work.
The case actually looks interesting, and those larger fans seem to keep things well cooled. I'm a sucker for an aluminium case, but the steel used here is reflected in the price.
Thanks for the feedback Peevles.
For the price the case has plenty to offer in terms of cooling features.
Good work mate, very nice first review there
Im still pretty undecided on the looks side of the case though
My current short list for buying a case is either the el diablo or the NZXT blackline in blue. Any preferences people?
Oh, and im afraid you didnt note that the door is on the left, major irritation, and by the looks, only open 90 degrees.
Lo matey...hope you enjoyed reading the review
Yes, the door opens up to 180° degrees...I think the image which depicts the case with the door open shows that the hinge is on the left-hand side...
Tough decision tbh as I've not seen a NZXT case in the flesh....I hope the review helps you to make your mind up either way.
