A+ Case Black Pearl WCR Edition ATX Case
External Appearance
Search Reviews
Appearance
As you'd expect from a case designed for the enthusiast, the Black Pearl WCR Edition is BIG. Measuring in at 210x600x590mm (WxHxD) this unfortunately meant that the case wouldn't fit in our photo studio. So, you'll have to excuse the state of the grass outside OC3D HQ as this is the only place with suitable light conditions we could find!
APlus Case Black Pearl WCR Front
APlus Case Black Pearl WCR Front APlus Case Black Pearl WCR Front
Right from the very first look it is possible to see that this case was designed with quality as a top priority. A single curved sheet of aluminium has been used to construct the front, top, bottom and back of the case, giving it a modern and seamless appearance. Unlike many other aluminium cases, the Black Pearl is not flimsy and has panels almost as thick and solid as you'd expect to find on a case made from steel.
A total of 7 external 5.25" drive bays have been provided for maximum expansion. A+Case have fitted the top two of these bays with spring-loaded, stealthed CD-Rom drive covers and the lowest bay with a 5.25" to 3.5" converter bracket complete with aluminium floppy disk bezel.
The reflective black plastic console at the lower half of the case contains contains the LCD screen for the integrated 4-port fan controller along with the power/reset switches and an illuminated A+Case logo. This is a nice touch and certainly adds a degree of style to the front of the case, however I can see the fan controller and plastic power switches being seen by some enthusiasts as a 'tacky', and quickly replaced with a custom solution.
APlus Case Black Pearl WCR Top APlus Case Black Pearl WCR Top
The top of the case is where the 'WCR' part of the Black Pearl's name starts to come into effect with A+Case providing two 120mm fan grills at the back for fitting a dual radiator. The spacing between the screwholes on the two grills is 17.5mm, which should be suitable for most radiators. However, through our own testing we've found that neither the XSPC R120-D nor the ThermoChill PA120.2 fit correctly.
Next to the radiator grills are two circular holes suitable for routing tubing (up to a 1/2" diameter) outside of the case. However, each of the radiators tested with the Black Pearl actually blocked a large portion holes, in some cases rendering them totally unusable. We also considered that possibly the holes were designed for the radiator barbs to fit snugly into, but once again the spacing between the barbs on all of the radiators tested did not match up with the holes on the Black Pearl.
At the front of the case are two USB ports, a firewire port and two 3.5mm audio jacks all hidden behind a flush aluminium flap.
APlus Case Black Pearl WCR Back APlus Case Black Pearl WCR Back
APlus Case Black Pearl Fan APlus Case Black Pearl WCR Back
Around the back of the case we can see that A+Case have opted for a BTX-style layout with the PSU at the bottom and the motherboard up-side-down at the top. This offers many advantages thermally, but can be an awkward layout for installing water cooling components. A+Case have also provided two spaces for 80mm fans to be installed just above the PSU, and a 120mm fan complete with meshed grill is already installed close to the CPU area in the middle of the case.
A single spring loaded thumbscrew is all that secures each of the case doors. Once unscrewed, simply pull the thumscrew towards you to release the door which can then easily be lifted out.
APlus Case Black Pearl WCR Bottom APlus Case Black Pearl WCR Bottom
The underside of the Black Pearl WCR is certainly sorted for ventilation, with a total of 6 small grills spanning the length of the case. Some kind of filter over these grills would have certainly been benficial as fans inside the case are quite likely to draw dust up from the surrounding surface.
APlus Case Black Pearl WRC Side APlus Case Black Pearl WRC Side
Rather than going for a standard acrylic window, A+Case have decided to use an aluminium mesh. This still offers good visability for showing off the components inside the case, but once again comes at the cost of drawing in extra dust. Thankfully the mesh window is not bonded to the case, with A+Case using only 3 screws to secure it. This also opens up the possibility that A+Case may decide to sell a pre-cut acrylic window seperately.
Let's move on and see what the inside of the case has in store...
«Prev 1 2 3 4 5 Next»
18-06-2007, 08:30:05
Jim
"Looking for a high-end water cooling ready case and have plenty of cash to splash? Well then maybe A+Case have the answer as we take a look at their Black Pearl WCR in our UK exclusive review."
http://www.overclock3d.net/gfx/artic...142301383s.jpg
A+ Case Black Pearl Review
18-06-2007, 08:32:56
PV5150
Mmmm looks like home already. Great review Jim!
18-06-2007, 08:41:43
robump
Well that looks familar.
A lian li v2000 modded a bit.
Looks professinal though, very expensive though.
Rob
18-06-2007, 08:47:38
PV5150
Rob
Ay I'd say more like a Silverstone TJ-07, but slightly cheaper
18-06-2007, 09:15:24
robump
Id would still go for v2000 looking at the hard drive bays.
Inside a TJ07
http://www1.oc.cn/img/2006/0602/silv...e_tj07s-23.jpg
Inside a V2000
http://i41.photobucket.com/albums/e2...0b_TestFit.jpg
Inside the A+ case
http://www.overclock3d.net/gfx/artic...101612328l.jpg
But anyways open to discussion.
Looks like a bit of a comination, they look t of made the hard drive bays removeable.
Rob
18-06-2007, 09:26:08
Ham
Looking forward to revision OC3D jimbo
18-06-2007, 09:30:53
Jim
LOL yeah. Move that radiator to the front of the case, space out the tubing holes a bit more and you have a 10/10 case imo!
18-06-2007, 09:34:08
Ham
Heh, and its big enough too fit an SS in the bottom!
18-06-2007, 09:50:08
Jim
The thickness of the alu and the construction is prolly enough to carry a SS weight too without bowing.
18-06-2007, 09:51:54
FragTek
It would still be in the best interest of the modder wishing to employ internal phase to lay down a thin sheet of steel in the bottom to distribute the weight of the compressor.
18-06-2007, 10:11:22
PV5150
Inside a V2000
Inside the A+ case
Rob
LOL I own a TJ-07 But anyway, yeah it's prolly a combination of the two. The HDD cages are exactly like the ones in my TJ-07, excapt they cater for more HDD's. And the problem that Jim showed in the review with the radiator depriving you of PCI slots for sound cards etc, the TJ07 doesn't have because it really only caters for 6 HDD's in the bottom anyway. Which ultimately provides more headroom in the top of the case for another rad should the need arise. But it's still a very nice case, and an excellent effort in designing a highly flexible one at that.
18-06-2007, 10:18:19
Ham
If i was modding one too accommodate a unit id do that, but it would be removable. Its nice too know that the alu would still be strong enough though.
20-10-2007, 04:58:17
Razvanell
Aplus Case Black Pearl custom made.
20-10-2007, 05:00:34
Jim
Very nice mate! Who made that PSU backplate for you?
20-10-2007, 05:39:44
PV5150
Visually stunning setup mate Well done on an uber looking rig
20-10-2007, 07:10:38
Brooksie
That thing is sweet
22-10-2007, 08:03:17
Razvanell
10x! Hard work. Q6600 @ 3,6 GHz (G0) stable on EVGA Black Pearl @ 35 C.
