Logitech Z-5500 Digital Speaker System
Setup & Function
Search Reviews
Setup & Function:
Right out of the box this speaker setup is very easy to put together and install. It took me maybe tops 15-20 minutes to pull out my old system, untangle all of the old wires, and put the new system in place. All of the plugins and cables are clearly marked showing what's what. Logitech also includes enough speaker wire to be able to string your satellites up to 25 feet away, that's a pretty decent amount of wiring for each speaker. This means you won't be stuck running out to the store to buy more speaker wire unless you're trying to hook these babies up in your main family / A/V room.
Something I was VERY surprised at was the style of cable terminals my system came with to hook up the satellites to the amp (built-in to the subwoofers enclosure). After reading numerous good/bad reviews for this speaker setup, the #1 complaint was the use of RCA style input cables on the subwoofer end and standard dual +/- on the speaker end. This means the only way to extend the wires if need be is to cut them and splice them, very ghetto and tacky. Much to my dismay, my system has standard +/- wiring on BOTH ends Makes me love Logitech even more, because they LISTEN to customer complaints and fix the problem ASAP. Good work yet again Logi, still impressing the hell out of me so far!
Here's a picture of what the original Z-5500 sub connection panel looked like:
Click to enlarge
Here's a picture of what mine looks like:
Click to enlarge
This particular setup is a full digital setup if you hadn't already guessed. Logitech has included an awesome breakout box for volume control, input selection, speaker levels, etc. On the back of this fancy backlit box with weighted control knob you will find all of its audio inputs. It features audio input via direct analog cables (what i'm using until my Bluegears HDA card comes in), digital coaxial, and digital optical. It's got an input for anything you want to throw at it, along with a spare inputs on the side of it for hooking up a portable cd player, etc. Right next to the aux input is also a headphone jack, good for us late night gamers that don't want to wake the neighbors with the sound of gunfire.
Click to enlarge
The subwoofer included in this package is among the biggest available in other 5.1 / 7.1 setups. It features a 10" high excursion woofer in a hand tuned ported enclosure which makes it BEAT to high heaven. This sub is so big it actually wouldn't fit under my desk where my Klipsch used to be, I had to put it behind my desk! Compared to my old Klipsch sub, this thing is about twice its size, and the Klipsch pounded! Mounted to the back of this badboy is an oversized heatsink with large fins to dissipate all of the heat that it generates when your blasting the tunes or watching a good action movie.
Click to enlarge Click to enlarge
«Prev 1 2 3 4 5 Next»
23-11-2005, 16:25:33
FragTek
Here's a wee bit of a review on this very awesome new set of speakers I picked up, I hope you find it useful!
Initial Impression:
Before I had any clue the massive size of this speaker setup I thought it would be a decent sized box, weighing maybe 30-40lbs. Boy was I wrong!! I got a call from the store today saying that something had come in for me from Logitech, I was excited that they came a day early (thanks UPS!). When I got down to the store, there was a monster box waiting to be picked up, I asked it was mine and one of my employees told me it was. Holy hell! I didn't take any measurements but the box is at least 3ft x 2ft x 2ft weighing in at a hefty 60lbs! Very impressive.
http://upload.sysxtreme.com/0.X/0.21896/Z-5500_box.jpg
Underneath the brown shipping container is the retail box, very flashy indeed!
http://upload.sysxtreme.com/0.X/0.21896/Z-5500_box2.jpg
Packaging:
The packaging inside of the retail box is second to none... In fact they could probably ship these systems w/o the brown box if they wanted too. Thick custom molded styrofoam inserts are perfectly fitted to every piece in the box making sure nothing can shift in transit. It felt good knowing that as I dug further and further in to the box I wasn't going to find anything out of place or broken, the packaging job was just that good.
http://upload.sysxtreme.com/0.X/0.21..._contents1.jpg
On the top level as soon as you open the box you find some cables, the control center, remote, and the center channel speaker. On to the next layer of styrofoam
http://upload.sysxtreme.com/0.X/0.21..._contents2.jpg
The second layer reveals the massive subwoofer and 4 main surround speakers. Again all wedged nicely in place as not to get damaged. Good job Logitech! I think that it's very important to know that a company doesn't skimp out on proper packaging of their products. I can remember countless times receiving things broken in transit not totally due to the carriers abuse to the package but the underfunded factory packaging. Thanks Logi!
Setup & Function:
http://upload.sysxtreme.com/0.X/0.59...k_oldmodel.jpg
http://upload.sysxtreme.com/0.X/0.59...0_subpanel.jpg
This particular setup is a full digital setup if you hadn't already guessed. Logitech has included an awesome breakout box for volume control, input selection, speaker levels, etc. On the back of this fancy backlit box with weighted control knob you will find all of its audio inputs. It features audio input via direct analog cables (what i'm using until my Bluegears HDA card comes in), digital coaxial, and digital optical. It's got an input for anything you want to throw at it, along with a spare inputs on the side of it for hooking up a portable cd player, etc. Right next to the aux input is also a headphone jack, good for us late night gamers that don't want to wake the neighbors with the sound of gunfire .
http://upload.sysxtreme.com/0.X/0.33...ntrolpanel.jpg
http://upload.sysxtreme.com/0.X/0.39...0_subfront.jpg
http://upload.sysxtreme.com/0.X/0.39...00_subback.jpg
Overall, everything included in the setup is of A+ quality and precision. I have ZERO complaints about anything.
Sound Quality:
WOW! This system is LOUD and has NO distortion at levels so high I can't go any further because my eardrums are pounding so hard. The high's are crisp, the mids are loud and distortion free, and the bass... oh the bass This thing delivers more bass than anything imaginable in PC speaker setup. It rattles all of the walls and can be heard pounding away half a block away when it's cranked up to "annoy the neighbors" mode. In game, the sounds are so surreal! It makes you feel like you're sitting right in the middle of the action, every footstep and gunshot is pronounced perfectly from whatever direction it occured. Gunfire is enough to make u shit yourself, the sub is just perfect for ultra-realistic gunfire. I LOVE IT!
There's not a single thing I don't like about the entire setup. I could have had a small small bone to pick with the speaker wire issue, but Logitech fixed it already, HAH! That's what I call service.
Conclusion:
I would have to say that this is by FAR the best bang for the buck in the full digital surround sound setup range if you get it somewhere selling far under MSRP. The MSRP is something like $400 for the setup but I snagged it from Newegg for just over $200. If you need a new speaker setup, look no further. Your money is WELL spent on these speakers.
10 of 10 - Editors Choice Award - SX Seal of Approval
http://upload.sysxtreme.com/0.X/0.65...5500_setup.jpg
23-11-2005, 17:14:17
Dav0s
maybe u can kill me in cs now frag
ow do they compare to a good set of hedphones?
23-11-2005, 17:49:49
FragTek
TBH Dave it's kind of hard to compare headphones to speakers. My personal preference is speakers over headphones, many people are biased towards headphones. I just don't like having anything bother my head while I'm playing. I like cranking up the speakers and immersing myself that way.
I think it's all personal preference tbh.
23-11-2005, 18:10:41
hawkinsa21
What can I say Frag??? <- - if this smily had a wheelchair, I'd be a dribbling spaz..... no offense to spaz's, but jesus wept on the cross for christiandom, this setup is 1337 as f00k!!
Excellent review Frag, appreciate the time you've put into this mate, wicked pictures and simply nicely done and layed out... That is one HUGE setup!!
Everything looks in place and very shiny, and no distortion at levels your ears can bear is immense, I know you have a setup of Technics mate, and if your anything like me, you've beaten the shit out of your eardrums over the years, so I expect you can listen louder than your average virginal eared person...
Love the remote.... I know what speakers I'm getting next for my 5.1 for PC, I have the Creative 5100 series currently attached to my xbox, so these are next on the list
Perhaps this is some comeback on your underclocking Opty??
If I could rep you I would big time , ps - Logitech :0wned: everything else on the market!!!
23-11-2005, 18:18:36
FragTek
Thx for the props mate, these speakers are indeed teh 133333337ness!
I can't imagine how awesome they will sound once my new card gets here
23-11-2005, 19:08:00
WC Annihilus
Damn those speakers look nice!
I prefer headphones just because I don't want my parents to be yelling at me for having loud shooting and swearing blaring by the kitchen. Also makes good for playing at bout 3 AM without them knowing .
24-11-2005, 00:31:14
bloodthirst
jesus fragtek they sound fucking good, im sure it makes dimebag daryll's killer guitar work 100 times better
24-11-2005, 06:44:11
Eguy
Didn't I tell you bro, they kick fucking ass as hell!!!!! BTW mine are like that too with the speaker wire, think they got enough complaints about the shitty plugs
Kick ass bro!
24-11-2005, 13:00:06
FarFarAway
Nice Frag!! Wish I could pimp a 5.1setup but nooo way wcould the missus watch TV at the same time so 5.1 headphoines it is for me
Good choice mate: bet they sound awesome!!
24-11-2005, 13:36:02
FragTek
Yeah I love em Eguy, they sound great... Glad to see you got the newer revision with the +/- terminals too
@Kemp: Bummer man, but there are some awesome 5.1 phones on the market!
25-11-2005, 07:34:48
PV5150
Nice one Frag, it looks kick arse. Also, that sub looks totally solid and grunty. Nice review
25-11-2005, 09:02:02
FragTek
The sub is just so insanely kick ass words can't even describe it peevles...
25-11-2005, 16:56:23
Eguy
Frag is right, there is no words to describe the sub, and the whole set is so entirely heavy I remember when I got it the UPS guy said WTF is in here!!!! :rollingla
28-11-2005, 16:48:23
FragTek
rofl eguy, that's what everyone at the store was asking me when it came in... they're like what in the fuck did you buy this time? haha
29-11-2005, 01:31:29
Eguy
:rollingla :rollingla :rollingla :rollingla :rollingla !!!!!!
The problem with them is they are so lound you can get in serious trouble, I was reading a review where they guy said that his neighbors called the cops and reported that the music was too loud and they threatened to sue ROFL. I had a neighbor yell at me when I had my Z-5300e's and they aren't even close to the Z-5500's
18-01-2006, 22:05:26
setite
that is why you need to move to the desert in vegas ... i have a home system that is huge.... its too old for me to know how powerful it is... but the sub is a 15 with a huge cabinet... and i have TRIED to bother my neighbors... you can't do it here
