Asus Xonar HDAV 1.3 Slim PCI Soundcard
Test Setup and Software
Search Reviews
Testing Methodology
To test the Asus HDAV 1.3 Slim I will be using the following methodology.
Tests
Gaming tests (FPS)
Subjective Listening:
Blu Ray Playback (Region B UK Discs)
DVD Playback
Music (digital out only)
Unfortunately due to the lack of analogue out, I could not perform the usual RightMark benchmarks. Any other 'real world' benchmarks regarding sound are so dependent on other factors I felt that it was not reliable to include them.
Test Setup
I feel it is very important to get the test setup correct when testing items such as a High Definition capable sound card. As such, the following setup will be used:
PC Setup
Intel Q6600 @ 3.3GHz
Abit IP35 Pro
8GB OCZ ReaperX PC6400 @ 1000MHz
MSI 8800 GTX
Lite-On SATA DVDRW (model LH-20A1S)
Seagate 7200.10 250GB HDD
Coolermaster Real Power Pro 1000w PSU
Asus HDAV 1.3 Slim
Belkin AV Home Cinema Surge Protector - 7 Socket
Dell 2407 WFP (QED QUNEX HDMI/DVI-P Cable 3MTR)
AV Setup
Yamaha DSP-AX863SE AV Amplifier
Mordaunt Short 906i Floorstanders (Bi-Amped, silver coated oxygen free copper)
Mordaunt Short 905i Centre Speaker (Bi-wired, silver coated oxygen free copper)
Mordaunt Short 905i Bipole Rears (300 strand oxygen free copper)
BK Electronics XLS200 DF (Mark Grant Canare LV775 10MTR)
Panasonic Viera TH-42PZ80B Plasma
Sennheiser HD555 Headphones
Additional Cabling
2 x Tacima CS929 6 Way Mains Conditioner
Chord Company Silver Plus HDMI Cable (1.5MTR)
QED Performance HDMI-P Cable (1MTR)
This setup will enable full 1080p signal to be passed to the plasma TV and a high def audio signal to be bitstreamed for processing by the AV Amplifier for maximum quality. It will also ensure that I get high quality sound from all of the the sources used in the PC.
Software
The usual Asus driver software is supplied with the HDAV 1.3 Slim, but with the HDMI twist on it. As such, I will point you in the direction of a previous review for a more in-detail look at the features. The differences with the HDAV 1.3 Slim is the HDMI features.
HDAV softwarre
Here you select the channels , the PCM format and and HDMI format. For HD audio you need 8 channels, 192 KHz PCM and 7.1 out. Note that if you have this enabled and play stereo music, the stereo music will only output in 2 channel format, as it should do.
The Asus software is easy to use, responsive and fairly intuitive and I much prefer using it to the terrible X-Fi Creative software.
ArcSoft TotalMedia Theatre
ArcSoft TotalMedia is also provided by Asus. This software enabled you to playback Blu Ray discs, including choosing the way you want to output the audio.
It's worth noting that Asus do not supply a version of the software that works properly with Vista SP2 in the box currently, but I believe will provide an update (to TotalMedia Theatre 3), and update the software included in the bundle at a later date.
After receiving the latest update from Asus, I managed to select the correct audio output that would give me HD Audio:
TotalMedia Theatre (3) is a nice bit of software and I had no issues using it with the sound card once Asus provided the update for me. It's good to hear Asus will provide users with an update and hopefully if you decide that the HDAV 1.3 Slim is for you, they will have updated the copy on the disc.
«Prev 1 2 3 4 5 6 Next»
04-09-2009, 04:22:41
FarFarAway
Featuring full bitstreaming HD Audio and only digital connections on-board, will the slim version of Asus's HTPC sound card be a winner?
Link
04-09-2009, 05:33:10
Rastalovich
+ Fantastic high Def sound
+ Decent enough value for money
Think these are the key things. Good to see that the pass-thru is not molested. Tipping the balance is the bundle.
U spend cash on a card that u may think is borderline too much and it hasn't got a good bundle and it makes it worse.
It has a front panel header on the pcb, does that qualify as atleast half a point deduction from it not having an analogue output ?
Great review, like to see u get ur hands on a mobo with ALC889a, like a Gigabyte flavor, just to see how u like it in comparison.
04-09-2009, 06:22:22
FarFarAway
Yeah it gets half a point but I don't think a full point is warranted.
If a company wants to provide me with an ALC889a mobo I could review the audio, but I don't think they'd just be after an audio review
12-09-2009, 18:27:34
Rastalovich
Just an FYI (and tbh I can't believe it worked first time myself).
Got a thread to post in it's own right which may come sometime sunday, but:
Take 1x Abit IX48 GT3 (Onboard RealtekHD, just ALC888), DTS 5.1/7.1 available.
add 1x Quality built (even with loud cooler) EN9800GT gracious prize from ASUS
Throw in, Vista 64 bit, Q6600/4g.
Connect the spdif (optical) out from the onboard to the spdif (yep the gfxcard actually has an optical input aswell as a header for coax).
Download VLC, take a cheap 5m HDMI cable and connect it from ur Samsung L32 (setup as a 1920x1080i resolution), and hmmm we have audio whilst watching Matrix Revolution
Excuse the bumpage, but this hasn't worked since...
EDIT: Linky to HDMI cable £10 - http://www.amazon.co.uk/Labgear-Premium-Gold-Plated-Cable/dp/B000GHOT86
19-05-2010, 05:03:03
hadesan
Might be my next addition to the HTPC...
