ASUS Xonar DX 7.1 PCI-E Sound Card
Installation & Drivers
Search Reviews
Installation was a breeze as should be expected but one thing I did want to try was NOT connecting the requested power supply via floppy power cable. I’m a sucker for doing exactly the opposite that hardware manufacturers recommend. Anyone who had a 680i board will know adding the ‘extra’ molex power to the board made no difference whatsoever so I wondered if this card followed suit. Not so I’m afraid as the card would not work without it – which is why Asus remind you to plug the power cable in both in the Quick start up guide and before installation in Windows so ensure you have a spare floppy power cable before buying this card. I should also note at this point that although the card is a PCIe x1 card it will work with other pci express ports should you not have access to the x1 port. This was tried and tested in a 2nd PCIe x 16 port which worked without problem. For this installation I will however be using the PCIex1 slot which resides directly below the 16x PCIex16 GPU slot. I couldn’t use PCIe x1 slot above the GPU as the Xonar DX is too long and wouldn’t fit due to the DIMM’s interfering with the soundcard placement – something you may want to investigate you as this is common on most motherboards which have a PCIe x1 slot in the uppermost position.
I decided to install and test the card on a Windows Vista based setup as Vista compatibility is something that creative drivers struggled with. Suffice to say the driver and software installation went without a hitch (after I had plugged in the power cable!). The same procedure was used with XP and again, no problems were encountered when following the installation guide. Both 32bit and 64bit Windows operating systems are supported. No major problems are being reported on the Asus support forum for windows users, which again is testament to the excellent drivers provided.
With only one set of drivers on the Asus support website (dated 13/02/2008) it appears that Asus are happy with the first release and as such no further drivers have yet been released to the public. Unfortunately no drivers for Linux were on the supplied support and drivers CD nor the Asus website which is echoed in the system requirements so Linux users should look elsewhere for a soundcard as the Xonar DX plainly does not have Linux support which is disappointing.
Xonar DX Audio center
Asus Xonar DX Audio Center
The Xonar DX Audio Center is the brains of the card where you control all the settings and configurations to your preference. In its most basic form you can change the output volume along with ‘SVN’ which is a noise balancing feature and the obligatory mute button. There are also five DSP modes which change the acoustics of the card depending on what type of media you are working with, music, Hi-Fi, Movie, Game and GX.
Main
Asus Xonar DX Main Screen
After pressing the Menu arrow, the ‘LCD’ reveals a wide range of settings. In the main screen you have the option to set the audio channels(2,4,6,8) , the sample rate(44.1Khz through to 192Khz) and your speaker configurations( Headphones 2,4,5.1,7.1 FP headphones and FP 2 Speakers). Unfortunately the speaker test would not work with Vista to the way Vista stacks the audio but worked fine in xp so you will have to test your speaker setup by other means if using vista. You would also configure your S/PDIF out configuration in this screen. The 7.1 virtual Speaker Shifter is a clever little utility that allows you to arrange the positional audio of your speakers according to their physical placement which is very useful if you cannot use the standard surround setup. Dolby Pro Logic IIx is also catered for in this section with music or movie configurations.
Mixer
Asus Xonar DX2 Mixer Asus Xonar DX Recorder
The Mixer screen allows the user to configure all the faders for each speaker in your setup depending on the speaker configuration in the Main panel as well as controlling your recording devices.
Effect
Asus Xonar DX Effect
The effect window allows you to experiment with your preferred reverb effect which include the Bathroom, Hall, underwater and music pub as default with an optional 20 others selectable with the drop down menu. These effects can be further tweaked using the Graphic Equaliser ranging from -20 to +20dB with 12 of the most common presets and a user defined one allowing you to save/load your favoured settings.
Karaoke
Asus Xonar DX Karaoke
I always find playing around with the karaoke section of soundcards utilities fun and this was no different. Options here include key shifting which adjusts the key of your audio allowing it to be matched to your singing style. Vocal cancellation is dependent on your chosen audio tracks– sometimes it works OK but others not which while disappointing at times is hardly a fault of the software as it appears to be effected by each individual track and not the mixer. The mic echo further enhances the quality of your singing skills. While I wouldn’t use this in a professional capacity it is fun, especially if you have children or for that drunken house party!
FlexBass
Asus Xonard DX FlexBass
This section covers control of your bass. Depending on your preference you can set the crossover frequency from 50Hz to 250Hz as well as selecting your individual speaker sizes as well as your headphone cans be them ear bud type or full coverage which is a nice customisable feature to have.
AEC
Asus Xonar DX AEC
AEC (acoustic echo cancellation) allows the user to properly configure the microphone. This panel allows the user to cancel echo and adjust microphone volume to properly configure the voice communication setup. Once you enable this setting the Audio Center automatically switches to a 2 speaker, voice processing mode and also suspends any sound effects which save a lot of hassle for that quick VOIP call.
VocalFX
Asus Xonar DX VocalFX
This panel is perhaps the most fun and adds that novelty factor to the whole package. You can change your voice here to sound like the sinister low pitch stalker or to a character from Looney tunes. Great fun if you want to disguise your voice from your clan mates and family alike when using VoIP. Presets include Monster, cartoon, male and female. You can also configure your ambience again with the 4 presets, Bathroom, Hall, under water and music pub.
Also included on the support CD is PMP lite – a piece of software that allows you to convert your audio files to various formats as well as having a useful utility which allows the user to add their own ambience to the file. While basic it is very easy to use and I’m sure would be utilised quite often. Especially useful is the Dolby headphone setting which converts your stereo audio to a virtual 5.1 soundstage – impressive indeed.
Overall the software package is well thought out and can be quickly picked up and adjusted by novice and pro alike. All the basic setting you would expect from a 7.1 card are there along with some useful, advanced and novelty additions you would only expect to see on more expensive cards.
«Prev 1 2 3 4 5 6 7 Next»
06-05-2008, 06:44:51
w3bbo
With the Xonar DX 7.1 soundcard, have Asus managed to trim the excess fat from it's bigger brother without sacrificing perofrmance? Or have they put the DX on a diet so harsh it can't hold it's own weight with the new influx of audio solutions...
http://www.overclock3d.net/gfx/artic...175110203l.jpg
Asus Xonar DX Review
06-05-2008, 07:03:23
!TIMMY!
Nice review webbo.
Good move by Asus tbh, but they need to be on top of the driver support!
Creative could slip further down the pan.
06-05-2008, 07:23:26
Rastalovich
Nice review, good to see some soundcard action.
Manufs need to make these cards with; front panel support; connection for internal HMDI support; low profile; solid drivers for XP/Vista 32/64bit - as almost a standard.
Asus are not particularly some1 I`m wanting to either look for support or driver upd8s. They`re are exactly Creative in that department, but they don`t personally fill me with enthusiasm either. That`s just me, I don`t buy their products when there`s a viable alternative for just that reason.
£60 is an ~ok~ price for me. I`d be happier if it settled around £40-£50, but that`ll take some time.
Like to have a comparison playoff with ASUS, Auzen, Creative - and let`s say an Abit IP35 Pro onboard, as a look into the qualities, drivers, performance and price.
For the +/- using Vista 64bit and these choices, I`m edging towards taking the soundcards out of the systems tbh.
06-05-2008, 08:32:30
w3bbo
I was a little hesitant about the price too but when you consider you are virtually getting a D2X (minus the frills) for half the price then it works out at a half decent price point. What most should consider I guess is the need for high performing audio over 'adequate' onboard solutions. IF all you do is surf the net then I guess onboard is fine but if your PC is a multimedia gateway then a dedicated solution is much better imo.
I am also concerned about driver support but we can only hope Asus keep on the ball with this one, either way it surely can't be as bad as Creative.
07-05-2008, 15:26:15
Kerotan
Excellent Review, much respect webbo: Wu-Tang Clan FTW!! I have a cheapo soundcard right now but if I'm looking to upgrade I'll definatley consider this, but tbh I don't know how much benefit I'd get running through the Aux on my 2.1 system, I wish 2.1 was listed as an option on my sound control panel but sadly I'm stuck with 2.0 or virtual 5.1
07-05-2008, 17:11:01
ionicle
good review
looks like a niceish card actually
and as for the comment about all the connectors being gold, you make a good point, but on the alternative side, green, pink and blue looks rather tacky ...
gold looks profesional, even if you dont know where to plug your wire
08-05-2008, 04:30:48
w3bbo
Do you use headphones at all m8? If so then I'd says it's worth it.
Originally Posted by name='ionicle'
good review
Yeah I agree gold looks better(and results in a better connection) and I didn't actually have any trouble connecting the audio up but I could forsee that in the average Joe setup with his case sat in the shade below a desk it would be nigh on impossible to get the right connector in the right hole (!) ahem. It would have been nice of Asus to include the led port lights its bigger brother has. Asus arn't the only ones guilty of this and although it's only a minor point, I thought it was a point worth making nonetheless.
Thx for your kind comments guys - my first review (of many hopefully) on OC3D
08-05-2008, 06:26:58
cybermaniac
ne1 recommend any DTS enabled cards?
08-05-2008, 06:47:42
w3bbo
Xonar D2X?
16-05-2008, 21:42:56
TamaDrumz76
Cool review, interested in the newest model. Always nice to have alternatives from the Creative crap... Well, not crap. Hardware is ok, but software/drivers suck. I think Auzentech has a great card which is based on the Creative chip, but costs just as much as the most expensive one too.
03-01-2009, 16:37:40
escort97
I know this is reviving an old review/thread but i have been wondering for a while now if yall had to do anything special to get the certain sound settings in BF2 while using this card I've never been able to get them with out an error.Its never let me choose x-fi and ultra.
Reading this review when it came out helped persude me to choose this card instead of a xtreme gamer, I've just never been able to get the Bf2 settings right with any option config.
04-01-2009, 11:33:11
w3bbo
Change the settings in BF2 config. It's the only way you get Ultra settings to work but I have my doubts whether it actually does anything anyhow as I couldn't tell the difference between ultra and high
05-01-2009, 14:48:16
escort97
Do you mean in the config files themselves or in the BF2 menu, because when I try the xfi option it just tells me I don't have one. Ty for replying.
05-01-2009, 17:32:27
w3bbo
You wont get ultra settings on any card as it can only be enabled via the config files.
Your soundcard however should be recognised as an XFI, the review sample was.
05-01-2009, 18:17:19
escort97
Yeah, that's the problem mine dosent get recognized as an xfi with or with out the gx enabled on the asus control panel, I don't know if its the card itself or what its currently set at hardware and high in the BF2 menu, is there a big change between that and xfi mode with the EAX enabled? Thanks again
06-01-2009, 05:36:48
w3bbo
What operating system are you using?
EAX can only be emulated in vista thorugh Alchemy software and the Asus exquivelant. The sounds are pretty much the same. Perhaps the easiest place to test it is in two areas.
Kubra dam - go into one of the tunnels and everything should echo/reverb.
Karkhand - Iirc you can here the occassional dog barking and a bell occassionally ringing.
The main effects though are the echo's that I could discern and a clearer more 'atmospheric' sound. There is little to choose between the XFI EAX and Xonar GX though so I wouldn;t lose sleep over it, especially as BF2 is now an aging game by todays standards anyway.
