Arctic Audio Relay Review
Installation
Published: 7th November 2012 | Source: Arctic Cooling | Price: |
Installation
Even if you want to use the Wireless option you need to connect the Audio Relay to your network with the ethernet cable to begin with. This brings up a browser window with a few screens. Once you've selected your language the next screen shows the IP and firmware of the AR.
Next you can choose what it appears as on your network. Although the default name is clear enough. After that you can either leave it as it is, or (as is more likely) if you wish to use the wireless just select the wireless option.
The final screen offers the wireless networks the device has recognised. You can connect by choosing it here and inputting the password, or by utilising the WPS buttons on your router and the Audio Relay. Once it's all connected just choose your audio in WMP or compatible program and stream it to the AR.
I hate to be "that guy," but we Mac users have had this functionality for... 8 years at this point, with the airport express.
+1 hates Apple.
Mac and interessted in hardware? Fits not good together in my oppinion. Mac destroys any freedom, you're even loosing the warrenty if you're swapping your HDD.
![]() +1 hates Apple. |
And, you can replace hard drives and RAM without voiding any warranty, as long as you don't mess anything else up when you do it.
Want to enjoy your playlists anywhere in the house? The Arctic Audio Relay might be just the ticket.
Continue Reading
