Ultra Products Releases Power Partner
"Ultra Products releases their supplementary power supply"
Search News
  • Scrolling Image
  • Scrolling Image
Ultra has announced the release of their Power Partner supplementary power supply.
If your current power supply is not enough for your most recent upgrades, but you just can't justify replacing your main power supply unit, then Ultra has a solution for you!
The Power Partner is a 325W power supply that fits into a 5.25" bay. It can provide power to additional graphics cards and even features the most current 8-pin PCI-e connector. The Power Partner provides both +12V and +5V rails and provides two 4-pin peripheral power connectors, so it can be used to power opticals, hard drives, water pumps, TEC coolers... the list of uses is nearly endless!
Installation is easy and the unit can be implemented in nearly any system. Simply route the power cord in through a slot in the back of the case, slide the Power Partner into a 5.25" bay, connect the main connector in-line between your current power supply and the motherboard, connect the Power Partner's power connectors to your graphic cards, peripherals or whatever else you need to deliver additional power to and you're set! No more having to worry about how much overhead your power supply may have left.
AC INPUT
115V/230V 6A/4A 60/50Hz
MAX OUTPUT
CURRENT
+5V
+12V
5A
26A
325W
Max
Combined
Watts
325W
Total Output Power:
325W (Full Load, Nominal Input Voltage)
Efficiency:
73% Typical at Full Load and Nominal Input Voltage
Input
AC Input Voltage: Automatic Full Range (115-230 VAC)
AC Input Frequency:
50-60Hz
AC Input Currents:
· 6A (RMS) at 115VAC input
· 4A (RMS) at 230VAC input
Connectors Available
1 - 24-Pin Motherboard Connector
2 - 4-Pin Molex Connectors
2 - 6-Pin PCI Express Connectors
1 - 8-Pin PCI Express Connector
Additional Features
  • Supports AMD and Intel Motherboards
  • Low Acoustic Noise
  • Meets ATX Version 2.03, and
    ATX 12V Version 1.2 Specifications
  • Short Circuit Protection
  • In-Rush Current Protection
  • Thermal Overload Cutoff Protection
  • MTBF > 100,000 Hours at Full Load,
    110VAC and 25°C Ambient Condition
  • FCC and UL Recognized
 Product Page
Discuss in our Forums
«Prev 1 Next»
30-10-2007, 07:06:27
K404
http://www.theinquirer.net/gb/inquirer/news/2007/10/29/amd-day-monday-november-19th
OK, its the Inq but heres hoping things start getting interesting!
Im gonna fight the urge to buy an 8800GT and see what the new ATI cards are like in the real-world
30-10-2007, 08:18:05
bazx
lol theres a real world:D
30-10-2007, 08:24:54
K404
Real-World= FUD, but we all know company slides and benchmarks are generally fantasy!
