Hiper launches new PSU: M1000 80PLUS Bronze certified!
"Hiper adds a 1000W PSU to their M power supply line"
Published: 30th November 2008 | Source: Hiper |
Hiper launches new PSU: M1000 80PLUS Bronze certified!To meet the increased power demand of latest GPU technology, HIPER introduces the new PSU M1000. Already it has been certified 80 PLUS® Bronze by www.80plus.org. The Hiper M1000 performs extremely well and exceeds the 80PLUS requirements by far. Also this model, which is the first one of the new M series with a new logo and packaging, has the new cable harness design of the current Type M series and comes with the semi-modular concept with ExTenders™. This grants easy assembling and a clean looking PC interior.
The high quality product M1000 has also been tested by NVIDIA for 3-way SLi and comes with a 5 years RTB warranty. The Hiper M1000 will be available soon and represents best price/performance ratio at probably the lowest RRP of all A-brand 1KW PSUs with 80 PLUS® Bronze certification: US$ 189 / € 142 / £ 118 (excl. VAT).
read our review :eek:
I sit really that bad and is there no fans that are any good for this, what temps can I expect @1.4v/4ghz
currently@ 47C idle AND A BOUT 66C Full Load
can you see a way of putting a simple WC setup on the CPU such a s 240 cm rad pump and block????
For your setup those temps look really high....
My QX6800 is at 3.8Ghz atm with 1.48v and I idle at 28-32*C and load at 59-62*C. This is one a PA120.3. Meaning I have a hotter CPU and smaller rad. :S
And just why are you so adamant about the Skeleton despite all it's flaws? Dont get me wrong, if you really do like it go for it, but it's an absolutely immense downgrade from the class and construction of a SilverStone or Lian Li.
[IMG]http://i374.photobucket.com/albums/oo187/D-Cyph3r/Viridis/viridis2.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v642/bigayd/openwindow.jpg[/IMG]
preferebly drop it out of one too
And why would you consider the Skeleton, it's an absolutely terrible case. :S
