Enermax MaxRevo PSU Series
"Enermax launches new flagship PSU series MaxRevo."
Published: 27th June 2011 | Source: Enermax |
Enermax flagship PSU series MaxRevo launched
Enermax widely known for their high-end PSUs have launched their new series of PSUs called MaxRevo. This series is specially designed for multi-GPU systems, industrial PC, workstations and servers.
Enermax enters the heavyweight class with its new MaxRevo. It is a new high-performance series with numerous technological innovations of the premium manufacturer. For instance the "Copper-Bridge Array" transmission technology replaces the traditional wires and passes the signal straight and with lower resistance. The result is: up to three percentage increase of the voltage regulation and higher efficiency for clean and stable DC output.
Equipped with six stable and highly efficient 12V rails this power supply delivers more than enough power for all modern servers and high-end systems. Enermax has optimized the topology of its successful Modu87+ and Pro87+ series to further reduce energy losses meaning MaxRevo reaches up to 94% peak efficiency (80 PLUS ® Gold)
Enermax’ new series has two new models that are rated at 1350 and 1500 Watts.
MaxRevo 1350W is now available at a MSRP of £289.90 and the 1500W for £319.90 incl. VAT. Enclosed to every MaxRevo delivery is one free 12cm T.B.Vegas Duo fan (MSRP incl VAT £15,99).
Discuss on the forums.
Resigned myself to having to get a black one and spray it. Nevermind. Got it now.
They make white 690-II windowed panels!?!?![]()
Haven't seen any white window panels in the UK though
I'm still running the old Antec 300 (with Noctua NH-D14 now), but when I go water-cooled, I am going to get the Arc, most likely.
Soon to be released. Looks promising. Hope there will be a window version.
EDIT: To be released in August so yeah...
Corsair Carbide Series™ 500R Mid-Tower Case
Not bad... hope you're right about the side panel. The current panel with the fan ruins it.
From the looks of it, that is really pushing the definition of mid-tower. It looks around TWO 5.25" bays TOO tall.
Lancool K62 is also a nice option, but it will be tricky to get it watercooled.
