Peak Products Unleashes Starpex
"Peak Products, announces Starpex, the first-ever full-size, wood, PS2 / PS3 Guitar controller "
Published: 23rd July 2008 | Source: Peak |
Peak Products, announces Starpex, the first-ever full-size, wood, PS2 / PS3 Guitar controller with the look and feel of an actual guitar. Starpex boasts an instrument-quality, high-gloss lacquered finish with a hardwood body, neck, and headstock handcrafted by a leading guitar manufacturer giving the authentic guitar experience that Guitar Hero™ and Rock Band™ enthusiasts crave. Other unique features include.
Full Guitar Hero and Rockband Functionality for PS2 and PS3 – Starpex is compatible with both PS2 and PS3, and allows users to experience the full list of game play features in both Guitar Hero and Rockband, including toggle effects switch and solo button functionality.
Unique Speed Star Power / Overdrive Button provides the fastest and most accurate access to Star Power and Overdrive. Additionally, built in tilt sensor technology allows users to access Star Power and Overdrive in a more traditional way. Optimized Whammy Bar maximizes comfort, provides better feel, reduces fatigue and provides a higher level of durability. High Quality Ten Fret Button Design features optimal button travel for enhanced feel, reduced fatigue, and higher score potential. Ten fret buttons means that players have the option of using traditionally positioned fret buttons, or rock out with solo buttons high up on the neck which also provide critical soloing capabilities in Rockband. Enhanced Strum Bar gives the perfect balance of tactile and audible feedback to maximize enjoyment and scoring.
Connectivity Options – Dual wired / wireless capabilities allow players to use a 15’ wired cable or a 2.4 Ghz wireless connection (both included).
Forward - Thinking Compatibility – Starpex’s modular design allows users to easily separate the electronic components from the body of the guitar which will allow for further customization including new guitar bodies, pick guards, and more.
“With well over 11 million copies of Guitar Hero/Rock Band sold on the PlayStation consoles, we see a tremendous opportunity in bringing Starpex to market” says Jamie Leece, Vice President for Peak Products. “Never before have Guitar Hero/Rock Band enthusiasts been able to shred with a hardwood, handcrafted authentic guitar controller that’s built with the look and feel of a real guitar. This will change the way the games are played.”
The Starpex will be available in Circuit City and various retailers with an MSRP of $179.95 in late August. For more information on Peak Products visit here.
Has this just gone to far? Tell us what you think on our Forums.
Temperatures will play a big role, too high and they'll ruin your components.
Stability however, is essentially, having the PC do power-hungry tasks, such as playing games or running orthos, and not having the machine reboot on itself.
I'm sure someone else will be able to explain it better than i.
First of al you need to know your PSU can afford for over[IMG]http://oldforums.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG][IMG]http://oldforums.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG][IMG]http://oldforums.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG][IMG]http://oldforums.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG] so vit sit here : http://extreme.outervision.com/psucalculatorlite.jsp
Temp of the components depend on what cooling you got so keep an eyes on temp mean keep your voltages for your CPU, Ram...ect under control.
stability, is making sure your operating system can cope with doing anything and everything, while under stress, while your component (cpu) is overclocked
if, while overclocked, due to high temps, the core not being able to keep up, or any other number of reasons, the operating system becomes unstable, then you need to lower the clock speed to a point where the operating system, at peak usage, can do everything without burning out your cpu, or other components...
if that makes sense?
Yes that makes sense thank you. I appreciate all your help everyone.
Bear in mind that if prime95 or orthos throws a huge error at you, then your system is not stable. I assume the same is true for orthos, as I use prime, but I know that prime will stop running stress tests and tell you if the system is not stable. It knows what it should calculate, and if it calculates it wrong then it is not stable, I believe.
So I have a 485 W power supply. I have an AMD 4600+ Athlon X2, a single 8800 GT, two 2GB Corsair DDR2 PC-6400, and a MSI K9N Platinum motherboard. How can I tell how much power this is using of my power supply? I basically want to know how much power I have left and how to calculate how much power a fan would take for example. I need to get some more cooling for my case in order to overclock and don't know how to add up the power specs. Thanks.
There is no way you can tell for sure.. unless you have one of those gadgets that you plug the PC into then into the wall to monitor the power the PC uses.
I very much doubt you are using anymore than 350watts. And adding a few fans won't make little to no difference in power usage.
Fans won't make much difference to power consumption at all really. I run a 750 Watt psu with a power consumption monitor on the back, which rarerly goes past 200 (doesn't seem right, does it?) and I run a quad-core, 2 hard-drives and an 8800GTS. Adding fans won't be a problem for you. Just don't max out your power-usage on an un-branded psu... bad things can happen :yumyum:
alright thanks.
The fans and power required. How do I know how much power I am going to need to run all of my components. I just bought some new Corsair RAM as well and don't want to over do it. Especially when I start overclocking. Is there a way to add up all the voltage required by my components?
Thanks everyone
