Razer Dual Release At WCG 2007 Finals
"Razer unveiled two new products at the World Cyber Games (WCG) 2007 Grand Finals."
Search News
  • Scrolling Image
  • Scrolling Image
Official Press Release
Yesterday, Razer unveiled two new products at the World Cyber Games (WCG) 2007 Grand Finals: the Lycosa and Piranha.
Razer Lycosa
The Lycosa is gaming keyboard designed to provide the gamer with speedy, full control at their fingertips.  Each key is fully programmable and the keyboard is able to save up to 10 different gaming profiles.  One of the more interesting features is a gaming mode which disables the Windows Start button, ensuring the gamer will never accidentally minimize in the middle of a heated battle.
The Lycosa will utilize Razer's 1000Hz Ultrapolling™/1ms response time and Hyperesponse™ technologies and features non-stick rubber backlit keys, providing quick action and superior response.  The TouchPanel™ media keys provide the gamer with constant control over the functions of their chosen media player.
Specifications
- Keytop with non-slip rubber finish
- Backlight illumination with WASD cluster lighting option
- Fully-programmable keys with macro capability
- Gaming cluster with anti-ghosting capability
- Slim keycap structure with Hyperesponse™ technology
- TouchPanel™ easy access media keys
- Gaming mode option for deactivation of the Windows key
- 10 customizable software profiles with on-the-fly switching
- 1000Hz Ultrapolling™ / 1ms response time
- Earphone-out and microphone-in jacks
- Detachable wrist rest
- One integrated USB extension port
- Approximate size:
  469mm (length) x 168mm (width) x 15mm (height) – without wrist rest
  469mm (length) x 221mm (width) x 15mm (height) – with wrist rest
The Lycosa will be available in November of this year with a MSRP of $79.99 in the US and €79.99 in Europe.
Lycosa Product Page
Razer Piranha
The Piranha, Razer's newest communications headset, is designed to provide clear stero sound and powerful bass, giving the gamer a superior audio gaming experience.  The sleek ergonomic design ensures hours of comfort and functionality, with a glowing Razer logos to add a touch of style.
Being a communications device, the Piranha sports a noise-canceling microphone, enabling the issuing of commands free of background noise.
The Piranha also features an inline volume control with a microphone mute button, providing the gamer with control over what they hear and what is heard.
- Stereo sound with true-to-life audio quality with superior clarity and bass
- Adjustable, noise-filtering microphone for clearer in-game communication
- Comfortable, ergonomic and adjustable earphones suitable for prolonged use
- In-line remote control with convenient volume and microphone muting adjustments
- Single-sided cable for  hassle-free usage
- Durable braided fiber cable protection
- Compatible with VoIP communication applications like TeamSpeak, Ventrilo and Skype
- Compatible with most major operating systems
- Usable with CD, DVD and digital audio players (via 3.5mm minijack)
Audio Specifications:
Headphones
Freq. response: 18 – 22,000 Hz
Impedance: 32 Ohms
SPL (@ 1 kHz, 1 Vrms): 114 dB
Cable: 3.0 meters
Microphone
Freq. response: 80 – 15,000 Hz
Sensitivity (@ 1 kHz, 1V/Pa): -38 dB
Impedance: Approximately 2 kOhms
Pick-up pattern: Uni-directional
The Piranha will be available sometime this month with a MSRP of $79.99 in the US and €79.99 in Europe.
Piranha Product Page
Discuss in our Forums
«Prev 1 Next»
04-10-2007, 09:03:58
redwing
Am I correct in assuming you have not re-installed vista since changing the motherboard?
The problem with that is that each motherboard has/requires certain drivers and your vista installation will not have the drivers for the new motherboard, and is probably trying to load the old drivers and causing the lock up.
You might be able to boot in safe mode and remove the old drivers (run device manager) and/or simply install the new drivers over the top, not sure.
At this point I would normally do a re-install. If you have another drive to use then you can install on that drive and later access everything on the old one. It does mean you need to re-install all your software and find/copy the old settings etc from the old one, it's a real pain in the butt.
Don't jump right into that solution though as someone else might have a better solution that doesn't involve a re-install.
Yes your right ive not reinstalled Vista yet since changing the motherboard ive just literally changed the board and started and put the vista disc in . What you say definetly makes sense about the drivers im just useless at this sort of thing . Ive only tried this after a guy i paid to build the PC made a real crap job of it so i thought id try myself not changed anything before .
so is it best to run in safe mode and try to delete the old drivers ? i know its prob a dumb question but how do i run in safe mode ? I know it gives that option if it crashes but if its normal i take it theres a way ? sorry if i ask lame things.
04-10-2007, 09:53:24
Mr. Smith
Just do a fresh install mate. Far FAR easier in the long run.
Safe mode, depends on mobo, sometimes F8 - see the manual
04-10-2007, 10:00:25
redwing
yes how do i do that ? all i did was started it and put the disk in i thought it would give me an option of fresh install or to keep old stuff and then id have to call MS to get a new code . I havnt had that option just black screen .
04-10-2007, 10:08:23
Mr. Smith
How many HDD's you got? Just connect the one you want up, go into the bios, set as your DVD drive as primary boot device, restart with vista in... Should just work...
04-10-2007, 10:14:59
redwing
I only have 1 , thats what i assumed it was doing .
04-10-2007, 10:18:50
Mr. Smith
Well do that and see if it works!
Set the HDD as the last possible boot device, DVD as first.
Let us know how you get on
04-10-2007, 10:19:26
nrage
If you only have 1 drive and it contains files you want to keep i.e. documents or save games etc then make sure it doesn't format the drive.
As Mr Smith said, make sure the DVD drive is the first boot device, there should be a boot device priority (or similar) menu in the bios.
04-10-2007, 12:56:21
redwing
DID IT GUYS !!!
sorry i took so long it was dowloading loads of files.
1 more dopey question though . Should i change the boot up option to Hard drive ?
I really appreciate all your help everyone cheers .
04-10-2007, 18:10:45
nrage
DID IT GUYS !!!
Well done. As for changing first boot device back to HDD, that's up to your own personal preference. I don't boot from CD at all often so I have HDD first, which means that when I do want to boot from CD I have to go into bios and change it.
05-10-2007, 06:20:09
redwing
that makes sense because its not gona boot from there much
cheers again
