Corepad Skatez Pro
"Corepad Skatez Pro"
Search News
Well from what I can see any mouse can benefit from feet replacement with the Corepad Skatez Pro mouse skates. They make using any mouse much easier, and much quieter actually. They are very easy to install, except of course for the removal of the old feet on some mice. The Skatez that are made specifically for certain mice and very nice they fit exactly into the spaces that were made for. The regular Skatez are nice to and make things much nicer when using even a generic mouse.
«Prev 1 Next»
03-04-2007, 11:32:13
dbates
I can't seem to find any good/quiet coolers for my PCIe EVGA 7900GS (I'm having to move from H2O to air cooling :( )
Can anyone suggest one which would fit?
03-04-2007, 12:10:37
FragTek
Checked in to the AC Accelero X1? I believe that would fit and would do a hell of a good job to boot!
If that doesn't fit then the NV Silencer 6 should as Inno3D use one on their iChill edition 7900GS, also a great cooler.
03-04-2007, 12:19:13
Bal3Wolf
the nv silencer 5 will fit but you gota mod it and it dont fit on the memory perfect. i thk the nv silencer 6 fits perfect but you gota add ram sinks yourself.
04-04-2007, 05:25:09
dbates
Are you sure about the NV6? The Artic website doesn't show it as compatible.
The X1 also says "NVIDIA 7900 GTX, GTO" ?!
Ramsinks aren't a problem, as they are already fitted because I'm watercooling.
04-04-2007, 16:07:26
Bal3Wolf
well i could be wrong but from what iv heard a 7900gs uses same pcb as the other 7900 chips might wanna do more googling to find out for sure. My nv5 does a nice job but all of ram aint cooled perfect enugh that it runs 650mhz on core and 855mhz on memory.
