IBM's eight-core Power7 chip
"IBM looks set to join the seriously multi-core set with the Power7 chip"
Search News
  • Scrolling Image
IBM looks set to join the seriously multi-core set with the Power7 chip IBM Power chart
International Business Machines (IBM) or 'Big Blue' as it is more affectionately known, looks set to set to join the seriously multi-core set with its Power7 chip. According to our source,  with eight cores per processor and a clock of 4.0Ghz, IBM plan on building some very large boxes indeed.
IBM has an architecture that will let supercomputing types combine these 2U boxes to form a massive unit with 1,024 cores, hitting 32 teraflops of performance with 2TB of memory.
Furthermore, IBM is reportedly building a number crunching behemoth for the National Center for Supercomputing Applications (NCSA) called "Blue Waters" with a budget of around US$208 Million. Rumoured for a 2011 completion, it promises to be something extra special.
We've got documents showing IBM going after a 10 petaflop system (peak) comprised of 38,900 eight-core Power7 chips with each chip running at 4.0GHz. This monster will have an astonishing 620TB of memory and 5PB/s of memory bandwidth.
According to the documents, IBM will rely on a 1.30PB/s interconnect to link the systems and will feed them with 26PB of storage. As if that's not enough, IBM will offer an exabyte of archival storage. Why not?
This insane machine will be built out of more than 100 racks filled with servers and storage systems, taking up close to 4,400 sq. feet.
Insane, but impressive
Feel free to discuss this article in our forum
«Prev 1 Next»
10-07-2008, 09:57:02
Mr. Smith
Rich, your OC tests - is the 3.9 jiggahurtz stable or just a screenie? Also, how does that compare to other mobos you've had the chip on?
I think that is relevant...
Ta :)
10-07-2008, 10:15:55
w3bbo
Prime95 was run for overnight (8 hours) aswell as a 1hr hour OCCT run - not exactly proof of 24/7 stability but it's good enough imo. This is compared against similar results with the MSI and P5Q deluxe. I rated the Maximus higher as, along with the ridiculous amount of BIOS tweaks available with more time and a more mature BIOS it is my belief the Maximus can at least equal the P5Q, not only that but gaming wise the maximus is already ahead of the P5Q albeit not by much.
Also overclocking on air, as I'm sure you are aware, can be heavily influenced by ambient air temps which due to the recent hot weather is limiting the possibilities. Using phase change is not realy an option as it isn't indicative of the 'average' user and wouldn't give a fair representation of the possibilities of the motherboard.
Because the P45 uses PCIE 2.0 which is double the bandwidth of PCIe 1.1 the need for 16 lanes is debatable so going for an X48 (which appears not to clock as good as P45) is not a decision that should be taken lightly. I guess it comes down to if you want every last ounce of CPU or GPU power - CPU = P45, GPU=X48 imo.
10-07-2008, 11:20:50
Luigi
Wow, Nice review :)
One thing that was in the press release, but I didnt see demonstrated, was the removable part of heatpipe cooling on the NB?
Is this possible?
10-07-2008, 11:22:20
WC Annihilus
Edit: think I read that wrong
10-07-2008, 11:26:52
Luigi
Yeah, apparently just the NB part can be taking off for water cooling, so you dont have to do the whole board?
10-07-2008, 11:30:17
WC Annihilus
Looking at the removed assembly pic, I don't really see how that would work, but I suppose I should let webbo answer this one
10-07-2008, 11:38:19
w3bbo
Yes it is possible - I'll upload a pic of that for you but I didn't include it in the review due to space constraints and the fact I can't understand why anyone would want to as if you are going to apply an aftermarket solution, the whole heatpipe would be best to be removed. I thought it better to include the whole heatpipe removal than just the top of the NB.
Just for you ;):
[IMG]http://www.overclock3d.net/gfx/articles/2008/07/10163754119l.jpg[/IMG]
As you can see, if you used an aftermarket solution you would in effect be creating a sandwhich effect and the cooling would be hampered by having to battle with two lots of TIM. Hence, best to remove the whole lot if that is your aim.
10-07-2008, 12:55:17
Pjalchemist
Loving my bord. Right out the box been able to hit 600FSB after latest BIOS update. It is eye catching. I can see there point in regards to the NB WC option, not much room to play though. Glad they have ditched push pins and the so called TIM. Think they lost too many bords that way! Luck has it i have an X38 IHS so when it come to going DICE on the NB i'll lid it. Nice review and nice ES bord!
10-07-2008, 13:00:44
w3bbo
Cheers Pete;)
31-08-2008, 07:52:17
ogmw
Hello im new to these forums and to overclocking so hello...
I have the Same MB and a Q6600 CPU and OCZ DDR2 platinum 800 RAM...
Just wanting to know the settings for the 3.6ghz OC and also is it stable?
Thanks
