ASUS Maximus Extreme Sneak Peek
"Another R.O.G. board from Asus has appeared online and this may be the real deal."
Search News
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
ASUS logo
Is this the ASUS Maximus Extreme?
Well here we are again, eagerly awaiting the release of Intel' next chipset offering the X38, and the proliferation of motherboards to follow. An interesting tidbit has turned up on the net hinting that one of ASUS' X38 based motherboards will be the ROG ASUS Maximus Extreme. The motherboard below features 3 x16 slots and overall connectivity appears to have had quite a shuffle around...namely the power and reset buttons, and the floppy and IDE connectors.
The water-cooled NB has seen a change from the one present on the Blitz Formula and Blitz Extreme motherboards, and the inclusion of 'meatier' looking heatsink solution.
Further; there are rumours suggesting that this may actually be one of Asus’ X48 based boards, but currently that hasn't been confirmed.
ASUS Maximus
ASUS Maximus 2
ASUS Maximus 3
Additional images available here
Like what you see? Feel free to tell us about it in our forum
«Prev 1 Next»
15-09-2007, 05:35:35
Rastalovich
If u take 3 processors: (Intel/AMD/whatever) Single, dual and quad.
Put each in a desktop rig that is identical each time. Install u`r OS and run a benchmark like SuperPI - and say the results at stock for all 3 were 10.00 for 1M +/- 0.05%. Essentially showing yourself that under a condition where core_0 of each of the cpus is/are identical.
Keeping them @ stock, drop them into a server environment, nothing to do with virtualization, something simple like managing a handfull of terras of shared drives, it`s security, a viral sweep at low access times and backup/maintenance etc. Arguments sake Win2k3.
Looking at the performances of the server, with each of these cpus, given maybe a week each in an office/building of 10-20 users.
Will there be any noticeable difference ?
15-09-2007, 05:58:01
Toxcity
Wouldn't a quad be better suited for the job?
Would be much better at multi-tasking. So like one core does back up.. one does networking.. and so on. :)
Thats my opinion. :D
15-09-2007, 06:26:26
mrapoc
Yea im on the same lines as tox as most of the time there will be more than one or even two high cpu useage tasks going on at the same time
15-09-2007, 07:12:20
Rastalovich
I think in terms of noticing a difference, u have to think as a user accessing the files.
What do u feel the servers biggest cpu % useage may be ?
15-09-2007, 07:19:07
Mr. Smith
This is all a bit vague...
A quad core would be the best for a server, for obvious reasons - multi-tasking.
The servers max cpu usage? :eh: 100%...
15-09-2007, 09:10:28
Kempez
And how many users? I mean it's not really a specific question.
If all three had the exact same usage and it was little enough for the single core to cope with, then the quad would have the least usage
15-09-2007, 09:16:50
PV5150
Agreed there are a few variables to the scenario.
15-09-2007, 13:20:30
nrage
It seems to me that for a file server the main bottleneck/performance concern is going to be hard disk speeds rather than cpu. Unless your IO devices use a significant amount of CPU (think older drives in PIO mode instead of UDMA). I'm not sure what sort of CPU usage a RAID array causes, nor am I sure what CPU usage a network attached storage device uses.
If we imagine a simple FTP server, for example. Typical architecture for that would be to have a main thread of execution "listening" for connections on a specific address and port. When a connection arrives a sub-thread is created (or re-used) and in this thread the connection is handled.
I imagine copying files using windows explorer has a similar architecture to what I described for the FTP server. The main process explorer.exe handles the copy requests but creates sub threads to handle the actual copy of data.
Therefore you could say that generally a multi-core CPU will have an advantage over a single core system simply because it can handle more connections simultaneously, devoting more CPU time to each.
That said, if the speed of the hard disks, or speed of the network connection are slow enough then these bottlenecks will prevent the cpu from ever reaching 100% usage, and in such a case the extra cores wont benefit you much.
So, if your IO devices require a lot of CPU to operate at full capacity, or your IO and network speeds and high, then you will want more CPU power in order to reach maximum potential.
If your IO devices require little or no CPU, or your IO or network speeds are low then you will not need as much CPU to reach maximum potential. This will be a lower potential than the high speed, high CPU situation.
My 2c :)
15-09-2007, 17:20:23
Rastalovich
I could have sworn I put 10-20 users in the OP :p
My 2c :)
This is precisely where the thoughts I had were going. There are oportunities to either use a board with it`s own i/o processors, or rely on raid controllers of something like a pci variety, that can take harddrive access away from the cpu up to 100%.
I`d be very keen to see a polled log of such a server to see whether the cpu does that much work at all outside of maintenance.
The arguement also came to mind when a talk on virtualization started and the opening statement was akin to "out of all the servers in the world, the average utilization of the cpu was xx%" (can`t remember if it was 18/15/8%) but either way that`s pretty darn low. And with the majority of non disaster maintenance taking place outside of regular office hours, why the heck do u need something like a Xeon quad ??
