Watercooling Kits From Evercool, Nighthawk & Titan
"Watercooling Kits From Evercool, Nighthawk & Titan"
Published: 20th February 2006 | Source: N/A |
and see what happens!
think your right about the 1000hz when i go over 2.9 gig the mem must go over 1000 and thats when i hit problems maybe running x8 will get past that
will let you know what happens
thanks!
First of all i'm french so sorry for the bad english.
I have a striker extreme + Q6600 G0 + 4G ram
i tried the bios config MULLET gave and for some reason Windows XP wont start.
The comuter boots but when windows should load and start the screen stays black!!!
Any idea why??? plz :(
I'm so sad!!!
4 Ghz would be pushing it tbh....on the Q6600 G0 on that board. Here's the settings I use for my 3.6Ghz OC, am using the same board with dual 8800GTXs, the chip and the GTXs are all watercooled in a single loop, not sure if this will be of help:
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
CPU Multi 8
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1800
Actual FSB (QDR), Mhz: 1800
MEM (DDR), Mhz: 900
Actual MEM (DDR), Mhz: 900
Vcore Voltage:1.5 for actual of 1.41
Memory Voltage:2.05
1.2v HT Voltage:1.65
NB Core Voltage:1.5
SB Core Voltage:1.65
CPU VTT Voltage:1.4
DDRII Controller Ref Voltage: auto
DDRII Channel A Ref Voltage: auto
DDRII Channel B Ref Voltage: auto
tCL (CAS Latency): 5
tRCD: 5
tRP: 5
tRAS:15
Command Per Clock (CMD): 2
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 4x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
AI Tuning: Manual
LinkBoost: Disabled
CPU Multi 8
FSB - Memory Clock Mode: linked
x FSB - Memory Raio: 3/4
MEM (DDR), Mhz: 1200
Actual MEM (DDR), Mhz: 1200
Vcore Voltage:1.60 in bios in os 1.55
Memory Voltage:2.2
1.2v HT Voltage:1.95
NB Core Voltage:1.85
SB Core Voltage:auto
CPU VTT Voltage:1.55
tRCD:4
tRP: 4
tRAS:8
tRRD: AUTO
tRC: 25
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 125
PCIEX16_2 Frequency (Mhz): 125
PCIEX16_3 Frequency (Mhz): 125
BIOS VERSION 0901
LinkBoost: Disabled
CPU Multi 8
Memory Voltage:2.2
tRCD:4
tRP: 4
tRAS:8
tRRD: AUTO
tRC: 25
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
LDT Frequency: 5x
BIOS VERSION 0901
try these worked for me i had trouble getting past 3.2 even tho it is water cooled
q6600
asus striker
ballstix ram 2 gig
8800gts 512
thermal take water cooling big water 745
has any 1 got to 4 ghz yet on this setup
