Thermaltake Presents the New Heatpipe Memory Cooler – Spirit RS
"DDR memories are getting bigger and faster. Thermaltake has noticed this significant issue and presents the new DDR RAM Cooler - the Spirit RS."
Published: 15th January 2007 | Source: Thermaltake |
News Posted: 15/01/07Author: PV5150
Source: Thermaltake
DDR memories are getting bigger and faster. The heat output by these memory units are progressively going up as well. Thermaltake has noticed this significant issue and presents the new DDR RAM Cooler - the Spirit RS (P/N: CL-R0026).
The Spirit RS heatsink is separated into two compartments - the area that comes in contact with the chipset is made of extruded aluminum to effectively transfer the heat to the heatpipes. The heatpipes then transfers the heat towards the aluminum fins on top of the unit. The thermal efficiency of the Spirit RS is extremely high and can quickly cool off the memory module. In addition, the heatpipe and the heatsink are adjustable in angle so that the users can install them however way they would like to minimize compatibility issues and increase performance efficiency. The Spirit RS can be used on DDR and DDR2 memory modules and includes two separate contact patches to maximize compatibility among single-sided and double-sided memory modules.
Someone decided to be argumentative today, erm... everyday.Dont tell that to my "bent" Zalman Heatpipe video cooler. Thing works like a charm. Or rather any other video card heatpipe cooled solution for that matter. Like the one found on my 7950GT.
It doesnt look that good tbh, kinda looks like something i'd make.
Thermaltake copied Thermalright. See Here --> http://www.thermalright.com/a_page/main_product_hr07.htm
It's thermaltake and let's just take a stab in the dark saying yes it almost certainly will suck
Personal experience says it will suck
I think you are forgetting that the ram coolers in the picture are mounted at 90* when installed, meaning the gel will pool in one end. On the Zalman it is mounted at 0* meaning the fluid can do its job via convection + displacement when its state changes
:rolleyes:Almost every heatpipe out there is curved in some sort of way. Let's be a retard today and say it sucks.
True.I think you are forgetting that the ram coolers in the picture are mounted at 90* when installed, meaning the gel will pool in one end. On the Zalman it is mounted at 0* meaning the fluid can do its job via convection + displacement when its state changes
I love the look of the Thermalright though, thanks NickS
