ThermalTake Orchestra
"ThermalTake Orchestra"
Search News
  • Scrolling Image
thermaltake
ThermalTake have released their latest water cooling solution in the form of a near silent liquid cooling system.
 In order to create a near zero decibel operation environment, the Thermaltake Orchestra is equipped with oversized radiator fins, all-aluminum enclosure, and the following elements:
1. A 4-in-1 all-copper CPU waterblock: This waterblock is designed from the latest state-of-the-art silver brazing technology. The brazing technology enables the waterblock to be corrosion-resistant, pressure-resistant, and guaranteed leak-free. The waterblock incorporates a maze routing design to maximize the flow and surface area between the waterblock and the coolant. The patented clipping design is suitable for Intel LGA775 / P4, and AMD AM2 / K8.
2. High-efficiency P400 12V pump: The same favorite pump used in the BigWater 735 and 745 series. The pump supports up to 400 litres per hour and has built-in blue LED. The low volume output of the pump is rated at 16 decibels and will not be heard during normal computer usage.
3. High-capacity reservoir: The Orchestra has a 3,000cc reservoir built in. The reservoir is part of the main unit, thus, while the reservoir is holding coolant, it is cooling passively at the same time. The internal coolant flow logic will efficiently pass the heat to the outside of the Orchestra.
4. Clear water flow indicator: In order for the external appearance to be beautiful and functional at the same time, the Orchestra has incorporated a clear flow indicator that can easily be viewed from the outside to see how the coolant is flowing at any time.
5. Easy-fill cap: The Thermaltake logo alloy reservoir cap enables the user to easily refill the coolant whenever the coolant is low. The ergonomic design is simply superior to any of the external liquid cooling systems on the market.
6. CPC quick connectors: Enthusiasts will never need to worry about re-routing the coolant tubing since the easy-to-use CPC quick connectors will pop off quickly and easily without causing any spillage, protecting your investments.
Orchestra Specifications
For full detail on the product visit ThermalTake
To discuss this news visit our forums
«Prev 1 Next»
10-09-2006, 01:09:03
blawblaw
What are you asking us?
10-09-2006, 01:12:06
NoL
Not asking anything, but if you'd like a question in every thread,
Anyone else think like me?
10-09-2006, 01:14:18
blawblaw
[QUOTE=NoL]Not asking anything, but if you'd like a question in every thread,
Anyone else think like me?[/QUOTE]
We don't know what you think like because you haven't given any examples as to how you think.
There are more than six billion people in the world, I'm sure someone out there thinks like you :).
Also, why did you post this in show it off instead of off topic?
10-09-2006, 01:15:44
NoL
Fine if I can't rant then...
Does anyone else find that almost everyone finds them eccentric and a kook?
10-09-2006, 01:22:22
blawblaw
[QUOTE=NoL]Fine if I can't rant then...
Does anyone else find that almost everyone finds them eccentric and a kook?[/QUOTE]
Go ahead and rant on a computer enthusiast forum, no one's stopping you. Basically what you're saying is that people consider you odd, but you just think that you're misunderstood, right?
10-09-2006, 01:27:16
NoL
No I seem to find it more and more odd why they have the perception that I'm odd. I think most people are quite brainwashed by society in things of "normal" that most are hipocritical shells of others whom are the same of others.
EDIT: Oh crap I realized I put this in show it off, sorry if thats why your acting a bit angered I geuss ?
10-09-2006, 01:42:05
blawblaw
Brainwashed by society? Don't these people make up society? Society sets the standards. No one is really normal, everyone's definition of normal is different.
You don't understand why people think you're weird. Hmm, sound a lot like life to me.
10-09-2006, 01:51:55
NoL
Oh I'm not argueing really against you, and yes brainwashed by society. Thats what we call ethnocentric I beleive is the world, you only think society sets the standards because you live in a society.
I personally dont like the current standards.
10-09-2006, 02:03:41
blawblaw
[QUOTE=NoL]Oh I'm not argueing really against you, and yes brainwashed by society. Thats what we call ethnocentric I beleive is the world, you only think society sets the standards because you live in a society.
I personally dont like the current standards.[/QUOTE]
Well, I'm pretty sure you live in it too, and yes society does set the standards. Just because they're standards doesn't mean they're right.
10-09-2006, 06:42:47
Dav0s
guys, this is the most pathetic argument i have ever heard. id like to think that your debate about standards in society had raised a decent point at least once, but it has not. you are both just blabbering and the argument has no end, because neither of you know what you are arguing about!
thread closed before this gets nasty
