Sharkoon Releases PC Fan With Modular Cable System
"Sharkoon Silent Eagle Modular Fan: QuickConnect port with four cables for mainboards (PWM) and power supplies (7, 9 or 12V) / available in 80mm and 120mm / MSRP starting at 11 euros."
Published: 28th February 2009 | Source: Sharkoon |
Sharkoon Releases PC Fan With Modular Cable SystemFour cables are included with the fan, and include a 4-pin PWM cable that can be controlled by the mainboard and three cables with Molex connectors that limit the voltage to 12, 9 or 7 volts. The 30cm long cables are individually labelled and colour coded for easy reference as well as featuring a robust casing. Sharkoon also offers separately a 60cm cable for users with large cases. The Silent Eagle SE operates with an efficient, low-noise motor that provides silent operation under each connection. The 80mm fan has a maximum rotation of 2000 rpm and, depending on rotation, a noise level of between 6.5 and 22 dB(A). The 120mm fan has a maximum rotation of 1200 rpm and maximum loudness of 20.5 dB(A).
For Optimal airflow the fan features the typical Silent Eagle golf ball design. The surface of each blade has countless dimples, lowering resistance and limiting turbulence, in order to reduce noise at all speeds. In addition, the rounded frame helps to increase the flow of air. Included with the fan, in addition to the cables, are four screws to attach the fan or four rubber bolts that further dampen fan vibrations.
End customers will find the Sharkoon Silent Eagle Modular Fan available immediately from authorized retailers for the suggested retail price of 11 euros (80mm) and 13 euros (120mm). The optional 60cm extended cable is available separately for the suggested retail price of 2.49 euros.
For more information, to request photos or other informational material, please contact us or go to www.sharkoon.com.
hey is it worth to upgrade my system to windows 7 i heared some good things about 7 but iam not really 100% sure if you guys advise me to upgrade to 7
it is a good os for a beta version. But remember that is it only a beta version and it will disable around august time.
