Scythe Release Kama Meter Multi Function Panel with Fan Controller
"Scythe Co., Ltd (Tokyo, Japan) announces the multi-function panel with card-reader & fan controller built-in device called "Kama Panel"!"
Search News
  • Scrolling Image
  • Scrolling Image
News <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 12/02/07
Author: PV5150
Source: Scythe
Official Press Release
Scythe Co., Ltd (Tokyo, Japan) announces the multi-function panel with card-reader & fan controller built-in device called "Kama Panel"! It features a 6 fan controller with a detachable unit (2 is built-in type and the other 4 are detachable) that you can exchange with a slim media drive (not included in the package). It's a 2-in-1 solution to save valuable space in your 5.25" Bay, and with this device, you won't need to purchase a separate fan controller and card reader media anymore.
Model Name: Kama Panel Model #: SCKMPN-1000-BK (Black) SCKMPN-1000-SL (Silver)
Manufacturer: Scythe Co., Ltd. Japan Dimension: 148 x 90.5 x 42mm (W x H x D)
Fan Controller: Up to 6 (2 built-in, 4 extra as slim slot-in attachment)
Compatibility:
Windows 2000/XP
Compatible Media:
SD Card, miniSD Card, MMC Card, RS-MMC Card, Compact Flash, Micro Drive, xD Card, Smart Media, Memory Stick (Including PRO, DUO, PRO-DUO).
Note: *Please purchase an adaptor to connect a small media such as minSD, RS-MMC, Memory Stick DUO.
Connectors:
2 x USB Cables, 1 x S-ATA Data, 1 x S-ATA Power, 1 x Line-In, 1 x Mic-In, 1 x Audio-Out,1 x IEEE1394.
Slot: Slim Optical Drive Slot
Scythe Kama Panel black
Scythe Kama Panel
Feel free to discuss this product in our forum
«Prev 1 Next»
11-02-2007, 04:03:25
weihk
http://www.mips-computer.de/
anyone know anywhere that stock these blocks in UK?
11-02-2007, 11:15:14
Allsorts
I bought a MIPS chipset waterblock from C&C but they don't seem to stock the CPU or GPU blocks. I like the MIPS all brass waterblocks but they are quite difficult to find in the UK. Maybe you can buy direct from Germany?
11-02-2007, 11:32:48
Allsorts
Oh well it seems that MIPS don't do GPU blocks, however the CPU blocks are found in the KTM CPU cooler section. Looks like C&C are the only official UK distributor for MIPS so I guess you could just email C&C if they don't have what you're after.
11-02-2007, 12:46:30
weihk
mmmmmm.............might send them a email about it......theres a few blocks im after....
not really wanting to go direct to germany, if something happens, it'll be UK>GER all the time......me no likey
off topic, anyone know where i can get some M2 x 10 and M4 x 50 Socket Cap Screws?
tried a few places (except B&Q, none local) and they dont stock any! bah..
11-02-2007, 12:56:27
Allsorts
Try ebay. There's always a great selection of bolts on there.
