Phobya Cases
"New cases from Phobya"
Published: 11th January 2012 | Source: Phobya |
Phobya have a new pair of new cases, details are given below, no info on a release date yet.
The first purely designed for water cooling housing Phobya WaCoolT UltraBig Water Case Black!
The manufacturer Phobya is a luminary in the field of water cooling and modding. So it was only a matter of time until the series of different models, manufacturers do not meet the requirements of the manufacturing consortium. We developed a basic concept of modular design which constantly adapted according to customer requirements and evolving.
The housings are made of 1.5 mm thick steel and therefore extremely durable, which is frequent in the water cooling conversion extremely beneficial. Each of the black powder-coated parts, ie, front & rear, interior, side panels, everything can be removed and remounted. No rivets fastened with M4 screws everything! This allows modders a new dimension of a housing modification.
But not only are case modders in this system have their fun. These cases are just the beginning, because all parts can be replaced according to your wishes. It may be a side panel with Plexi, the lid should be a different radiator installed, the back should be equipped with 2 power supplies, all of these optional components are available from the manufacturer as soon Phobya commercially.
Individually, the front! Supplied have been omitted on purpose to push buttons or switches. Each two 19mm holes for it. These are optimized for the variety of commercially available switches. Who swears to quality is also suitable probe of Phobya. Of course there'll be too different front options to make this in the future can be as individual as possible.
The case is in spite of the completely modular design
Water cooling is the issue that was brought in these types of housing in the focus. Thus, hose and cable penetrations were optimised. All rubber holes for hoses and cables can be removed to install there Fillport, 19mm. Different radiator, reservoir and pump assembly devices are integrated. This case is the first of its kind in as much detail on water cooling!
Special features of the Phobya WaCoolT mATX-1 Case Black case:
radiator or fan assembly:
Back: 1x 120 fans (no 140s)
front: 1x 200 Radi, 1x 280 or less, 1 x 240 or less - the whole assembly for hard drives can also be move backwards and screw because of different radiator sizes
cover: 1x 400 Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
Floor: 1 x 400-Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
shelf: 1 x 400-Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
side wall to the right: 1x Nova or Super Nova can also be mounted with Nova box
side wall to the left: 1x Nova or Supernova mounting option ONLY with Nova Box and Shroud 1x 200 or 180 fans
-Fillport:
2x back , 19mm opening
4x top, 19mm aperture
6x hose guide, 19mm opening
2x mounting device pumps on the shelf:
internal, middle, underneath the motherboard
M4 threaded holes
compatibility: eg Laing, Laing D5, Eheim 1046 (HPPS, Aqua Stream, Watercool 12V), Eheim 1048, Magicool 12V DC 260 and DC 400 Phobya, EK-DCP and 2.2 DCP 4.0
-reservoir
internally, alternative to the radiators
outside, the back
5X Slotin holes for mounting possibility of Conditions (tube up to 400mm)
-ON/OFF and reset
the left and right in the front 19mm hole size
Mainboard Compatibility:
ATX, mATX (Micro ATX), eATX, μATX
graphics types of length up to 400mm, according to slot distance 580mm
wheels as feet
-10x 5.25 "drive bays with 9 front-panel
-9x 3 , 5 "drive bays
3x power seats - of which 2 to 80 with cover and fan assembly option, length 400mm
Technical details:
Material: Steel
Color: black powder coated
Dimensions (L x W x H): 585 x 243 x 760mm
Weight: 22000g
A multilingual, illustrated assembly instructions can be found here. (To follow)
Delivery:
1x Phobya WaCoolT UltraBig Water Case Black
mounting hardware
Allen
To see the mATX version please visit the next page
You can discuss in the Forums
When you have your OC linx-stable,add a nudge or two to vcore,that should be [email="f@h-stable"]f@h-stable[/email].
Thanks for the fast answer mate, will download and use them
but i must be honest, i couldn't wait and started Folding at 3400Mhz, (for now) climbing later...
i forgot i could just copy paste the work folder
Greetings Ray.......
That said, I could be being a complete n00b. Either CPU-Z isn't reporting voltage properly, or I'm getting massive VDroop (1.355v set, CPU-Z reports 1.296
of course I KNOW it IS F@H that is the best stress tester
and of course don't lose the WU...
2800Mhz and BIGadv is meh
Sorry for these questions, but its a bit of a long time ago, i did overclocking/folding....
thanks for reading, Ray.......
