Noctua introduces NF-P12 high-impedance fan
"Noctua releases the NF-P12 which has been specifically developed for high-impedance applications such as CPU coolers, water-cooling radiators or cases with tight fan grills. "
Search News
  • Scrolling Image
Official Press Release logo
Only 14 months after the release of the NF-S12 series, which has received more than 100 awards and recommendations from leading international websites and magazines, Noctua expands its line-up of 120mm fans with the NF-P12 high impedance fan. The NF-P12 has been specifically developed for high-impedance applications such as CPU coolers, water-cooling radiators or cases with tight fan grills and features psychoacoustic optimizations that make it less annoying to the human ear.
"One of the main difficulties in the design and development of axial fans is to achieve a good balance of the three key parameters of airflow, pressure and noise", explains Mag. Manfred Stadler from the Austrian Institute for Heat-Transmission and Fan Technology (Österreichisches Institut für Wärmeübertragung und Ventilatorentechnik, ÖIWV). "Even in the field of PC cooling, each application has different requirements though: Whereas CPU coolers require high static pressure, it's mostly the airflow to noise ratio that counts when it comes to case fans. Common fans are usually designed to be all-round solutions compromising in certain areas in order to achieve solid results in all typical applications. Noctua, on the other hand, is following a two-fold approach with its NF-S12 and NF-P12 fan series in order to achieve optimal results at various applications: While the NF-S12 was optimized so as to provide a class-leading airflow to noise ratio in the lower speed ranges and therefore makes for an excellent case fan, the NF-P12 was designed to produce high airflow and an outstanding amount of static pressure, which makes it perfect for use on CPU coolers and other high-impedance applications."
With its nine large, closely spaced blades, the NF-P12 achieves no less than 1.68mm H²O and 92.3m³/h at 1300 rpm. Thanks to psychoacoustic optimizations, the NF-P12 is nonetheless surprisingly quiet: The Vortex-Control Notches at the trailing edges allow for the flows along the suction and pressure side to mix more smoothly and spread the noise emission over a wider range of frequencies. As a result, the NF-P12's noise pattern is perceived as much less annoying.
Like the NF-S12, the NF-P12 is equipped with Noctua's tried and tested SSO-Bearing that guarantees maximum long-term stability and excellent running smoothness. On top of that, the NF-P12's running smoothness is further increased by Noctua's new Smooth Commutation Drive system, which ensures a smoother transition between the stator coils.
The NF-P12 has an MTBF of over 150.000 hours and comes with 6 years manufacturer's warranty. Using the supplied Low-Noise and Ultra-Low-Noise adaptors, the fan's speed can be reduced to 1100 resp. 900 rpm.
Price and availability
The NF-P12 is available with immediate effect at a recommended price of EUR 19.90 / USD 24.90.
Noctua NF-P12
Overclock3D were offered an exclusive preview of the Noctua NF-P12 high-impedance fan. See what our reviewer thought of the product here
It's great to see that Noctua has decided to keep the pricing of this new fan at the same level as their previous NF-S12 range.
Discuss in our forum
«Prev 1 Next»
05-11-2007, 07:02:19
d.bills
RMA 2943: Club 3D nVidia GeForce 7600GT 256MB GDDR3 TV-OUT/DVI (AGP) - Retail
Hi,
I returned this item to you on the 22nd October. I handed it in at the desk and was informed that the item would be tested there and then. Upon you actually seeing the item I was informed that if the item was found to be faulty then it would have to be returened to Norway for them to replace it.
I have given you several emails and messagers in MSN but have had not a single response. All I wish to know is where you are upto with regard to this item, has it yet been returned to the manufacturer.
05-11-2007, 10:06:53
kris[tek]
Hi,
the replacement is being sent out today for you, sorry for the slight delay in resolving this one.
